Paool kolemjdoucí
Založen: 12. 08. 2004 Příspěvky: 10 Bydliště: Poland
Zaslal: so červen 18, 2005 11:32 am Předmět: Problem with SieFS |
Hi there
I have fuse 2.2.1 module in kernel, compiled SieFS 0.5 and when I mounted my CX65 it doesn't wrok (no errors while mounting)
kód: | sudo mount -t siefs /dev/ttyS0 /media/mobile |
It creates a file, which I can't open
anyone know what I should do? _________________ Siemensinfo.pl |
circulus pisatel
 Založen: 13. 07. 2004 Příspěvky: 269 Bydliště: KOLÍN
Zaslal: so červen 18, 2005 2:32 pm Předmět: |
Hi,
try this as root user:
kód: |
mkdir -m 0777 /media/mobile
or
kód: |
chmod 0777 /media/mobile
and after this, try mount mobile as a normal user.
-m 0777 parameter sets permissions on directory /media/mobile to read,write and "browseable" for everyone. _________________ C25->C35i(fw18 with T9CZ!)->C45->C55->M55->C65 fw50(patched)->SE K510i->N70->K320i->Huawei Sonic.
jabber: circulus[at]njs[dot]netlab[dot]cz |
Paool kolemjdoucí
Zaslal: so červen 18, 2005 3:18 pm Předmět: |
that didn't change anything...  _________________ Siemensinfo.pl |
circulus pisatel
Zaslal: so červen 18, 2005 5:20 pm Předmět: |
Hmm, I don't have problem with SieFS. Post here output from command
and output from command
after doing a mount command
This seems to be like that /media/mobile is an file instead a directory. _________________ C25->C35i(fw18 with T9CZ!)->C45->C55->M55->C65 fw50(patched)->SE K510i->N70->K320i->Huawei Sonic.
Paool kolemjdoucí
Zaslal: so červen 18, 2005 6:11 pm Předmět: |
kód: | paool@ubuntu:~$ ls -l /media
ls: /media/mobile: Brak dostępu
razem 12
lrwxrwxrwx 1 root root 6 2005-06-16 20:28 cdrom -> cdrom0
drwxr-xr-x 2 root root 4096 2005-06-16 20:28 cdrom0
lrwxrwxrwx 1 root root 7 2005-06-16 20:28 floppy -> floppy0
drwxr-xr-x 2 root root 4096 2005-06-16 20:28 floppy0
drwxrwxrwx 9 root root 4096 1970-01-01 01:00 windows |
no access to /media/mobile
kód: | paool@ubuntu:~$ dmesg ¦ tail
Usage: dmesg [-c] [-n level] [-s bufsize] |
circulus pisatel
Zaslal: so červen 18, 2005 6:32 pm Předmět: |
Hmmm, mount point must be an directory (and you have none in /media), so that correct procedure is (as root user):
kód: |
mkdir -m 0777 /mnt/mobile
mount -t siefs /dev/ttyS0 /mnt/mobile
After this, the mobile files are in /mnt/mobile .
This must work, but only for root user. _________________ C25->C35i(fw18 with T9CZ!)->C45->C55->M55->C65 fw50(patched)->SE K510i->N70->K320i->Huawei Sonic.
Paool kolemjdoucí
Zaslal: so červen 18, 2005 7:02 pm Předmět: |
it's still the same...  _________________ Siemensinfo.pl |
circulus pisatel
Zaslal: so červen 18, 2005 7:50 pm Předmět: |
I don't know much more how to advice with your problem. I have tested siefs 0.50 with FUSE 2.3.0 on Fedora Core 2 and Fedora Core 3 without problem.
You may also try this command as root :
kód: |
fusermount /mnt/mobile siefs /dev/ttyS0
There are link to download files of fuse project http://sourceforge.net/project/showfiles.php?group_id=121684&package_id=132802
Functionality of siefs depends on correct order of compilation. First must be compiled and installed fuse (and fuse-dev package, if exist in Ubuntu) and then is possible to compile and install siefs.
Try use a version 2.3.0 of fuse. Now I will be offline (I am going to take some beer, because Saturday night begins ) _________________ C25->C35i(fw18 with T9CZ!)->C45->C55->M55->C65 fw50(patched)->SE K510i->N70->K320i->Huawei Sonic.
Paool kolemjdoucí
Zaslal: so červen 18, 2005 7:58 pm Předmět: |
paool@ubuntu:~$ sudo fusermount /mnt/mobile siefs /dev/ttyS0
Password:
fusermount: old style mounting not supported
Actually I've tried 2.3.0 version of fuse but... the same
In other distros I don't noticed this problem
circulus napsal: | (I am going to take some beer, because Saturday night begins ) |
yeah, me too  _________________ Siemensinfo.pl |
Anonymní
Zaslal: so červenec 02, 2005 3:23 pm Předmět: |
i have fuse 2.3.0, siefs 0.5 and it doesn't work
kód: | root@tweety:~# mount -t siefs /dev/ttyUSB0 /mnt/siemens/
mount: unknown filesystem type 'siefs' |
i really don't know what is wrong it SHOULD work but it doesn't |
Borix veterán
 Založen: 10. 07. 2004 Příspěvky: 1861
Opty kolemjdoucí
Založen: 02. 07. 2005 Příspěvky: 3
Zaslal: ne červenec 03, 2005 8:11 pm Předmět: |
cesky umim jen sem nechtel kazit thread
ten navod je moc hezkej ale to sem samozrejme udelal uz davno pred tim mozna je problem v tom ze to zkousim pod jadrem 2.6.x misto 2.4.x jak pisou na strankach siefs ale na netu sem nasel cloveka co to provozuje pod 2.6.11.11 a v pohode... dokonce sem zkousel i fuse 2.2 ale nic
no jak budu mit casu tak to pro jistotu testnu s 2.4.x a jestli to pujde tak me to paradoxne nastve  _________________ Linux is like a teepee -- no windows, no gates, Apache inside! |
circulus pisatel
Zaslal: po červenec 04, 2005 11:00 am Předmět: |
No ono to chodí i pod jádry 2.6.x . Možná je na vině ještě ta "bezvadná věc" udev. Nevím to jistě, ale fuse si možná musí vytvořit nějaké položky v /dev a pokud se použije udev a není správně nakonfigurované tak to fuse nejede. Nějaký takový menší problémek jsem s tím měl na Fedora Core 3, ale už nevím co to bylo přesně, avšak povedlo se to rozchodit. Teď budu doma instalovat FC4 tak uvidím co se bude dít. _________________ C25->C35i(fw18 with T9CZ!)->C45->C55->M55->C65 fw50(patched)->SE K510i->N70->K320i->Huawei Sonic.
Opty kolemjdoucí
Zaslal: po červenec 04, 2005 8:30 pm Předmět: |
to by mohlo byt ono to me nenapadlo i kdyz ted sem nedavno udev odinstaloval a taky to myslim neslo ale asi by to chtelo jeste zrevidovat
pokud to nepujde tak uz nevim dneska sem to zkousel na 2.4.x a ta sama chyba... takze jadrem to neni... no uvidime dik za tip _________________ Linux is like a teepee -- no windows, no gates, Apache inside! |
Opty kolemjdoucí
Zaslal: po červenec 04, 2005 8:51 pm Předmět: |
tak udev to neni v /dev mam
kód: | crw------- 1 root root 10, 229 2005-06-09 22:40 /dev/fuse |
a stejne nic nejde
btw kdyz pripojim telefon a pouziju slink i tak mi to neco vypise a pak uz nic...
EDIT: uz mi to konecne funguje...! mnou vytvoreny balicek pro slackware 10.1 totiz neobsahoval symbolicky odkaz /sbin/mount.siefs na siefs ktery se sice pri make install vytvori ale pokud clovek pouzije DESTDIR tak ne v adresari balicku _________________ Linux is like a teepee -- no windows, no gates, Apache inside! |
