hotter badatel
Založen: 04. 12. 2004 Příspěvky: 141 Bydliště: Lithuanian Telefon: M55 47266.46 SMM
Zaslal: st září 21, 2005 2:52 pm Předmět: backup |
How to do backup for cxv70 sw56 with v_klay 3.3 (i generaited boot pass and put i v_klay/data/loaders)?
Please dont delete this temai i must to know how to do it!!!
You can tell me how to put backup back to phone it will be good in the future |
lacibogi čestný člen
786.46 SMM
Zaslal: st září 21, 2005 3:18 pm Předmět: |
Firstly you must to run V_Klay.
Above the buttons "Apply patch" and "Undo patch" there is a offer. (general patch, keyboard layout, flasher)
You must switch it to flasher than you must read memory of the phone an d finally save the file.
And if you want to write the backup you can do it per Write memory button.
Fuuu....I hope you understand it. _________________ C(ME)75
Lasky |
hotter badatel
Zaslal: st září 21, 2005 3:27 pm Předmět: |
Yes i understood you but what to put in:
From adress, size, user from upset, size?
How i know i have to do ff and eprom, is it true? and how to do it? |
786.46 SMM
Zaslal: st září 21, 2005 3:35 pm Předmět: |
FF backup:
From address: 0x00000000 (fullflash)
Size: 0x02000000 (fullflash)
Bootcore backup:
From address: 0x00000000 (bootcore)
Size: 0x00020000 (bootcore)
Lgp backup:
From address: 0x000E0000 (langpack)
Size: 0x000C0000 (langpack)
EEFULL backup:
From address: 0x00220000 (EEFULL)
EELITE backup:
From address: 0x00FE0000 (EELITE)
Size: 0x00020000 (EELITE) _________________ C(ME)75
Lasky |
hotter badatel
Zaslal: st září 21, 2005 3:42 pm Předmět: |
and which backup is needed for backuping mobile ff and eprom yes?
and how to pot them to phone (i undestod how to open and write but which i should to write first to phone(eprom or ff if they are needed for backuping mobile))? |
786.46 SMM
Zaslal: st září 21, 2005 4:05 pm Předmět: |
hotter napsal: | and which backup is needed for backuping mobile ff and eprom yes? |
I don´t know what do you mean with this.
hotter napsal: | and how to pot them to phone (i undestod how to open and write but which i should to write first to phone(eprom or ff if they are needed for backuping mobile))? |
Firstly you must to write FF and than EEPROM backup.
But it is not needed to write EEPROM backup everytime when you write FF.
It is needed only if you have writed not your own FF ar if you want to unblock mobile. _________________ C(ME)75
Lasky |
lapis badatel
Založen: 27. 02. 2005 Příspěvky: 116
291.18 SMM
Zaslal: st září 21, 2005 6:11 pm Předmět: |
So backup fullflash with x65flasher, it may be easier for you... |
