prihlaseny táta fóra
Posted: Mon Nov 28, 2005 8:18 pm Post subject: KTO NAJDE NA NETE LOADER PRE CF 62 PRE FW12 TOMU KUPIM.... |
10 PIV A KYTICU RUZI FAKT, MUSI TO EXISTOVAT ABO TO PRAVTE NIEKTO |
Drobcek9056 táta fóra
7860.92 SMM
Posted: Mon Nov 28, 2005 8:41 pm Post subject: Re: KTO NAJDE NA NETE LOADER PRE CF 62 PRE FW12 TOMU KUPIM.. |
vinco321 wrote: | 10 PIV A KYTICU RUZI FAKT, MUSI TO EXISTOVAT ABO TO PRAVTE NIEKTO |
Toto si precitaj http://www.siemensmania.cz/content.php?id=109 _________________ momentalne SL55  |
Posted: Mon Nov 28, 2005 9:21 pm Post subject: |
hej len to ze je to do fw07, na fw12 to nejde |
tom-as rozumbrada
 Joined: 19 Mar 2005 Posts: 332 Location: FIT VUT Brno CZ, občas Piešťany SK, ještě míň Tábor CZ
0.00 SMM
Posted: Mon Nov 28, 2005 9:22 pm Post subject: Re: KTO NAJDE NA NETE LOADER PRE CF 62 PRE FW12 TOMU KUPIM.. |
mas holku nebo tu kitici das mamince?
vinco321: na novejsi FW nic nebude, musis s nim dolu  _________________ ( Siemens C35i -> S35i ) + Sony CM-DX1000 + Nokia 5110 + Siemens C35i + Siemens A55@C55@888kB +
Posted: Tue Nov 29, 2005 9:09 am Post subject: |
takze, ak nahram fw07, co sa moze stat? bude telefon reagovat ako doteraz?nic sa nezablokuje? bude sa dat s5 nahrat fw12 uz s aplikovanym loaderom,respektive vyssia fw21? |
7860.92 SMM
Posted: Tue Nov 29, 2005 2:23 pm Post subject: |
vinco321 wrote: | takze, ak nahram fw07, co sa moze stat? bude telefon reagovat ako doteraz?nic sa nezablokuje? bude sa dat s5 nahrat fw12 uz s aplikovanym loaderom,respektive vyssia fw21? |
Ano da sa to, lenze neviem ci ti pojde nahrat nizsi FW ako FW12, pokial si ho mal uz od zakupenia. Bol tu jeden clanok, tusim od hanniho, ako sa to da zariadit, aby si mohol urobit aj downgrade FW. A upgrade FW mozes potom robit hocaky, lebo ikony, ktore chces zmenit su zapisane vo FF a nie vo FW. Zmenou FW sa ti nestane nic, akurat tam budes mat mensie chybicky, ale na ten cas, pokial si vytiahnes FF, upravis si FF a naspat nahras FF sa ti nic nestane, a potom kludne mozes dat aj FW12.
Aspon by to tak malo byt. Ale patche si hladaj pre FW, ktory aktualne mas, t.j. ak si tam nahras FW07 a vyberies potom FF, tak patche by si mal aplikovat pre FW07, pokial sa nemylim, ak sa mylim, tak ma opravte.
To Tom-as : Jasne ze mam holku, a co si cakal? Kvety mame? ved nema ani narodky.  _________________ momentalne SL55  |
