swimm3r kolemjdoucí
Založen: 08. 12. 2005 Příspěvky: 8
Zaslal: čt prosinec 08, 2005 11:49 pm Předmět: M55 dead |
hello world!
I put "Tuningový FW10 pre Siemens M55" in my Siemens, and I don't Power On any more? Update went OK o the end but I can't do anything
I can't power up, or Update Firmware... What can I do????
HELPPPPPPPPPPPPPP! |
Zaslal: pá prosinec 09, 2005 10:54 am Předmět: |
You must unlock your phone.
Program Freia - Unlocking function - Direct unlock no map is saved - write your IMEI and push OK + red button on your phone...
http://www.siemensmania.cz/download.php?file=/software/Freia15Setup.exe _________________ Kdo umí, ten umí. Kdo neumí, ten čumí.
Naposledy upravil hanni dne so prosinec 10, 2005 1:51 pm, celkově upraveno 1 krát |
swimm3r kolemjdoucí
Zaslal: pá prosinec 09, 2005 8:49 pm Předmět: |
hello again
FREIA - Engine build 15, Frontend build 11
Thanks goes out for the following:
Maxim, Rolis, Sergey, PapaJoe, Lead,
TheWizard, Jozso (for hardware and cable
support and of course beta testing),
Nico, Pinker, Tom, Crew
and all the others who supports ...
COMM_LoadBoots : selected phone family is 10
TTY_OpenCOMPort : opening Prodigy
COMM_IsBootRunning : bootcode does not seem to be running
COMM_LoadBoots : Waiting to power on the phone ...
COMM_LoadBoots : phone is not powered on
I can't power it up
all others programs give to me "No Ping" (all the settings are good )
What the **** do I do now : |
swimm3r kolemjdoucí
Zaslal: pá prosinec 09, 2005 9:42 pm Předmět: |
I can't do anything with it
what happend?
all firmware program show only errors
I push Power On button, but no effect |
swimm3r kolemjdoucí
Zaslal: so prosinec 10, 2005 8:16 am Předmět: |
when I install "M55_040101.exe"
with Pre-Check Skip all system freeze, and if I unplug Serial Cable, it unfreeze and I get this message "Error on waiting for Ack EOT";
with Pre-Check I get this message "Could not Ping Mobile";
I have Original Serial x55 Cable
All these things happend after I flash "FUBU_M55v10_3.6MB_tuning.bin" with JokerV0306.exe !!!
I can't power on and all software give "Could not Ping Mobile" ERROR |
Little_S čestný člen
Zaslal: so prosinec 10, 2005 12:32 pm Předmět: |
do you have your own EEPROM backup?
rewrite it using v-klay (or something alike) then you'd be able to turn your phone on.
kód: | COMM_IsBootRunning : bootcode does not seem to be running
COMM_LoadBoots : phone is not powered on |
this seems like you haven't pushed the red button. _________________ Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. |
swimm3r kolemjdoucí
Zaslal: so prosinec 10, 2005 2:31 pm Předmět: |
I pushed the red button, I'm not so dumb... the ****ing phone doesn't start |
swimm3r kolemjdoucí
Zaslal: so prosinec 10, 2005 2:35 pm Předmět: |
I made FullFlash from my phone, but I can't use it !!!
when I push the button nothing happend... can it be phisicaly broken?! |
lacibogi čestný člen
786.46 SMM
swimm3r kolemjdoucí
Zaslal: so prosinec 10, 2005 3:42 pm Předmět: |
Torx 5 is for Siemens M55 ? |
786.46 SMM
Zaslal: so prosinec 10, 2005 3:46 pm Předmět: |
Yes, I think so. It´s universal. _________________ C(ME)75
Lasky |
swimm3r kolemjdoucí
Zaslal: so prosinec 10, 2005 4:22 pm Předmět: |
thanks to all of you for your help. Now I will find the right tool to open my Siemens and cut that "thing".
I will write new things when I'm done with that !
thanks again! |
