Jaffe kolemjdoucí
Založen: 03. 02. 2005 Příspěvky: 5
Zaslal: st prosinec 14, 2005 7:54 pm Předmět: AX75 with IrDA problems |
I bought a cheap AX75 here in norway. It was sold as a AX72, but it is actually an AX75. But when I try to activate IrDA, it says "Interface conflict, IrDA temporarily unavaiable." maybe the provider (Telenor) have locked the phone's IrDA function so the phone will be the same as AX72? |
lacibogi čestný člen
786.46 SMM
Zaslal: st prosinec 14, 2005 8:10 pm Předmět: |
It writes that it´s just temporarily unavaiable. I think it can be blocked by old fw version. _________________ C(ME)75
Lasky |
Vladimir Curcic badatel
Založen: 30. 04. 2005 Příspěvky: 127 Bydliště: Serbia
Zaslal: čt prosinec 15, 2005 10:43 am Předmět: AX72 does not have IrDA! |
Well, it obviously depends on what they really sold to you. Because these are not the same phones the main difference is in hardware: Siemens AX72 DOES NOT HAVE IrDA BUILT IN, and AX75 HAS IrDA! So if you bought AX72 it will NEVER work because of the hardware...
_________________ S65(FW58) | IFL-600 (External flash) | DCA500
MY CURRENT COLLECTION: ME45 | S45i | CX65-LtdEd | S65 | SL75 |
Jaffe kolemjdoucí
Zaslal: čt prosinec 15, 2005 3:32 pm Předmět: |
But it IS a AX75! |
BEZY čestný člen
81.16 SMM
flemo ostřílený diskusník
Založen: 06. 04. 2005 Příspěvky: 537 Bydliště: Trnava
3205.06 SMM
Zaslal: čt prosinec 15, 2005 4:02 pm Předmět: |
Is it written on phone, that it is AX75? If you have real AX75 instead of AX72, maybe it has only software block on IrDA. Maybe you should try to load AX75 software into it, WinSWUP version. _________________ ....S65-AX75-CX75-EL71-E71-SXG75-E71-S68-C81-M81 |
3205.06 SMM
Zaslal: čt prosinec 15, 2005 4:04 pm Předmět: |
Or maybe it is so, that AX75 with damaged IrDA are sold as AX72 :-). Just like during stone age of home computers Sinclair used damaged 32k memory chips as 16k :-))) _________________ ....S65-AX75-CX75-EL71-E71-SXG75-E71-S68-C81-M81 |
Jaffe kolemjdoucí
Zaslal: čt prosinec 15, 2005 4:46 pm Předmět: |
I didn't have time to try updating with a new firmware until now, so I downloaded the official FW16 with LG2, updated the phone, and now IR works like a charm! So now I've got a really cheap AX75
Thanks for all answers and suggestions! One other thing... in www.mobile-review.com 's review, the menu looks different than my - is this something that has to do with a operator-customized firmware? In that case, maybe Telenor had disabled IR in the AX75 firmware of my phone. |
