sassaki kolemjdoucí
 Založen: 21. 12. 2005 Příspěvky: 8 Bydliště: Brasil
Zaslal: út leden 31, 2006 9:34 pm Předmět: CX65 Help me |
Somebody can help me, does not obtain to modify imei of cx65, inserts the PATCH, but not itself that it programs to use and as to use.
D4X (o(^^)o)
lacibogi čestný člen
Zaslal: st únor 01, 2006 12:49 pm Předmět: Re: CX65 Help me |
sassaki napsal: | Somebody can help me, does not obtain to modify imei of cx65, inserts the PATCH, but not itself that it programs to use and as to use.  |
You can apply patch with V_Klay. But firstly you need to generate loaders in PapuaUtils.
Here you can find it in english.
http://www.repairing.nl/d_repairing/s_unlocken.rar _________________ C(ME)75
Lasky |
sassaki kolemjdoucí
Zaslal: st únor 01, 2006 8:27 pm Předmět: Re: CX65 Help me |
Lasky napsal: | sassaki napsal: | Somebody can help me, does not obtain to modify imei of cx65, inserts the PATCH, but not itself that it programs to use and as to use.  |
http://www.repairing.nl/d_repairing/s_unlocken.rar |
OK, I generated the porter, and I obtain to communicate perfectly, but I do not obtain to find which field to modify the IMEI to record a new. I applied the PATCH V50, and later what I must make?
tanks men.
Douglas Sassaki
Brasil
Zaslal: st únor 01, 2006 8:33 pm Předmět: |
Patch is only a visual change. Real change you can do with Papua. In the Various part. _________________ C(ME)75
Lasky |
sassaki kolemjdoucí
Zaslal: čt únor 02, 2006 4:58 pm Předmět: |
Lasky napsal: | Patch is only a visual change. Real change you can do with Papua. In the Various part. |
I make this process!!!
Read IMEI from phone-Set IMEI.
Because I am trying and I do not obtain to modify it.
Please you it could place the process for me to be able to carry through the exchange.
Thanks |
sassaki kolemjdoucí
Zaslal: po únor 06, 2006 10:56 pm Předmět: H A Y |
