:: View topic - Patche pre SX1
Patche pre SX1
Goto page Previous  1, 2, 3, 4, 5  Next
Krouta
PostPosted: Mon Jan 30, 2006 10:49 am    Post subject: Reply with quote
Disable clear logs after SIM change
www.oslik.ru
Code:
; * Отменить очистку списков вызовов при смене SIM*
; * Disable_clear_logs_after_SIM_change*
; by Vovan888 ([email protected]) 29.01.2006
; oslik.ru
; Использован список функций O2_14 от FCA00000
; Made with help of O2_14 func list from FCA00000
; Отключает функцию CSysApAppUi::DoSimChangedFromPreviousBootL(void)
; 0x50854846
replace:03F01BFF041C03F01EFF002C05D0:10BC01BC0047
Krouta
PostPosted: Wed Feb 01, 2006 2:42 pm    Post subject: Reply with quote
Code:
; *** CallerBigPicture 0.7 ***
; *** Caller Big Picture ***
; Author: fca00000 , fca00000-at-yahoo-dot-es
; Date: 2006.01.29 Version for beta-testing
; Firmware: Siemens-SX1 Possibly all versions. Tested on Iberia15.2 and O2-14
; Omap: Core-Img (Z1)
; Usually you can assign a thumbnail to a contact. When he/she calls you, you see the picture.
; But this picture is too small.
; This patch allows to use a bigger thumbnail.
; First you need to copy z:BMImages.mbm into your PC and edit picture 064.bmp to make it
; completly black and size 120*120
; Then copy into c:\system\data\BMImages.mbm
; Probably you also want to make the following pictures into size 1*1 :
; 000, 001, 002, 003, 004, 060, 062 . And also change 069-086 .
; I do not provide a modified BMImages.mbm because yours might already be customized.
; Be aware that you need to restart the phone if you update this file.
; Issues:
; 1) all thumbnails become big. This might be a problem in other applications.
; 2) If you don't copy BMImages.mbm into C: , it will be taken from Z: and looks ugly.
; 3) Some pictures overlap others. Play with the images mentioned above to make it nicer.
; 4) It is a bit tricky to use a photograph as a thumbnail. Try to use sizes smaller than 64*64
; For the curious people: I changed BubbleManager.dll in
; method BubbleUtils::PlaceThumbnailToBottom, when uses structures 50685B18 and 50685B34
; Also CBubbleOutlookTwoLined::ConstructL before CFbsBitmap::Create
; And PAlbView.dll in
; method CPAlbImageFactory::CreateThumbFromBitmapWithNoSaveLC before CFbsBitmap::Create
replace:04C0FFFF04C0FFFF03000000FAFFFFFF04C0FFFF280000002800000004C0FFFF04C0FFFF03000000FAFFFFFF04C0FFFF2800000028000000
:04C0FFFF04C0FFFF03000000FAFFFFFF04C0FFFFA90000002800000004C0FFFF04C0FFFF03000000FAFFFFFF04C0FFFFA900000028000000
replace:282200924A60062202F050FD02F014F9:782200924A60062202F050FD02F014F9
replace:2C20302204904A60301C0A2205F0A4FD:D020F42204904A60301C0A2205F0A4FD
; As far as I know, nothing is broken. But I decline all responsability, of course.
; Anyway, here it is. Enjoy
; Normalmente puedes establecer una imagen reducida para un contacto. Cuando te llaman, ves el dibujo.
; Pero esta imagen es muy reducida.
; Este parche permite usar imagenes mayores.
; Primero tienes que copiar z:BMImages.mbm al PC y editar 064.bmp para que sea totalmente negro y ocupe 120*120
; Luego lo copias en c:\system\data\BMImages.mbm
; Probablemente tambien quieres hacer que los siguiente archivos ocupen 1*1 :
; 000, 001, 002, 003, 004, 060, 062 . Tambien cambias 069-086 .
; Con este parche yo no te doy el archivo completo BMImages.mbm porque posiblemente el tuyo ya lo hayas modificado.
; Si metes un nuevo fichero BMImages.mbm tienes que reiniciar el telefono.
; Problemas:
; 1) Todos los dibujos reducidos aumentan el tamanio. Esto puede ser un problema en otras aplicaciones.
; 2) Si no copias BMImages.mbm a c: entonces usara el de Z: que aparece un poco feo.
; 3) Algunos dibujos aparecen encima de otros. Juega con los ficheros anteriores hasta que te aparezca bien.
; 4) Es un poco complicado usar fotos. Intenta usar tamanios menores de 64*64
; Hasta donde yo he comprobado, no he roto nada. De todos modos yo no me hago responsable.
; end of CallerBigPicture
www.oslik.ru
PekabOo
PostPosted: Sun Feb 12, 2006 12:36 pm    Post subject: Reply with quote
at je to tady pohromade pac sem to dlouho hledal....
Code:
//intenzita ovetleni u klavesnice 1/4
replace:2B30A0E32A30C4E52B30C4E5AA30A0E3:0A30A0E32A30C4E52B30C4E5AA30A0E3
//intenzita osvetleni pro displej 3/4
replace:0010A0E30120A0E1190000EB0400A0E10110A0E3:2130A0E32A30C4E50120A0E10400A0E10110A0E3
duuri
5874.50 SMM
PostPosted: Wed Feb 15, 2006 10:26 am    Post subject: nahravanie videa dlhsieho ako 1 minutu zo zvukom Reply with quote
Code:
; *** VideoLonger1minute 0.5 ***
; *** Video Longer 1 minute ***
; Date: 2006.02.13 v0.1
; Date: 2006.02.14 v0.5
; Omap: ROLF (A: drive)
; The program Camera->Video (aplicacion PVCamcorder) allows to take videos, but shorter than 60 seconds.
; This patch reduces that limitation to 3:42 . And another limit is the RAM memory of the phone, usually about 8 Mg.
; Depending on the image quality and the sound level, you might take up to 3:42 minutes.
; You must set the quality=High
; and also Settings->Advanced settings->Max file size= Maximun
replace:3B284ADD3C202060CDA800682D18:FF284ADD3C202060CDA800682D18
; Permite grabar videos de mas de 1 minuto con el programa Camara->Video (aplicacion PVCamcorder)
; Debes poner la calidad de grabacion=Alta
; y tambien configuracion->configuracion avanzada->Tamano maximo de... = maximo
; Tambien deberias grabarlo en la tarjeta de memoria, claro
; El limite al tiempo de grabacion viene dado por la memoria RAM disponible, que suele ser unos 8 Mb.
; Tambien depende de la calidad de la imagen y el nivel del sonido.
; A veces graba 3:42 minutos, a veces un poco mas de eso.
; end of VideoLonger1minute
treba aplikovat na rolf
duuri
5874.50 SMM
PostPosted: Wed Feb 15, 2006 10:30 am    Post subject: rozsirenie frekvencie radia do 124.8 Mhz Reply with quote
Code:
; *** IncreaseRadioFrecuencies 0.1 ***
; *** IncreaseRadioFrecuencies ***
; Date: 2006.01.16
; The radio allows a maximum frequency of 108.0
; This patch increases the upper limit to 124.8
; You must set it in Manual tuning
replace:00F36F06:0020A107
; La radio permite una frecuencia maxima de 108,0
; Este parche aumenta este limite superior hasta 124,8
; Debes sintonizarlo en Sintonizacion Manual
; end of IncreaseRadioFrecuencies
duuri
5874.50 SMM
PostPosted: Wed Feb 15, 2006 3:37 pm    Post subject: Reply with quote
Code:
; *** BoostHeadsetVolume ***
; Author: Bryan , [email protected]
; Date: 2006.01.19
; FirmWare: Siemens-SX1 Possibly all versions. Tested on V15 uk-it-de and Simplified Chinese V15
; This patch can boost headset volume in any case you use headset.
; If you use some special headset the volume may be very low. Then you can try this patch.
; This patch don't affect speaker.
; Warning: Too loud volume can hert your hearing!!!
; Thank you for FCA00000 for his O2_14.symbol
; CMdaRecordUtilityImplData::MaxGain(void)
; CMdaRecordUtilityImplData::MaxVolume(void)
replace:05680E68684669462C222C23:05680E686846694648224823
zosilnuje hlasitost sluchadiel...
Sirus
7910.50 SMM
PostPosted: Fri Feb 17, 2006 8:26 am    Post subject: Reply with quote
predlzuje cas diktafonu na 2 az 20 minut
Code:
Увеличивает длительность записи диктофона от 2 до 20 минут
replace:000E270770B5061C0D1C1048:000E274770B5061C0D1C1048
predlzuje cas diktafonu az na 30 minut
Code:
; increase  to 30 minutes
replace:000E270770B5061C0D1C1048:00D2496B70B5061C0D1C1048
duuri
5874.50 SMM
PostPosted: Mon Feb 20, 2006 7:45 pm    Post subject: ICQ namiesto pager v kontaktoch Reply with quote
;patch 70:
; *** ICQ patch ***
;Author: SR , [email protected]
;Date: 2006.02.18
;Firmware: SX1_RUSSIA-RETAIL-uk-de-ru_15
;Omap: Core-Img (Z1)
;Patch replaces item pager with ICQ in Contacts
;You can replace 156 and 157 image in avkom.mbm with icq image
http://duuri.szm.sk/icqpatch.rar
duuri
5874.50 SMM
PostPosted: Tue Feb 28, 2006 1:05 am    Post subject: Reply with quote
Code:
; Author: NightShift79
; public release:2006.02.25
; Version: 1.0
; Firmware: * * *ONLY FOR uk_de_it Variant! * * *
; THIS PATCH IS ONLY USEFULL IF YOU PATCH AVKON.MBM
; TO E:\SYSTEM\DATA.
; It modifies avkon.r01,r03,r05
; Now more icons in E:\system\data\avkon.mbm can be changed without
; showing wrong colors or errors on the precious.
Make sure you have avkon.mbm stored in E:\system\data, before starting your phone
nie vsetky icony v avkone presmerovanom na e: sa pouzivaju stsem si ich stale berie zo zSmile tento patch robi system ci taha z e:...
je pre firm uk-de-it ale ja ma uk-sk-cz v anglictine a ide to tiez:)
pripajam patch a avkon z unreal modu zmenenim ja_mom a mnou...ked tvorite vlastny pozor na palettu v mbm toole treba standart...
stahujte http://duuri.szm.sk/modded.rar
Sirus
7910.50 SMM
PostPosted: Thu Mar 02, 2006 11:25 am    Post subject: Reply with quote
MMS vacsie ako 100kB
Code:
; *** MMSbigger100Kb 1.0 ***
; *** MMS bigger 100 Kb ***
; Date: 2006.02.23
; The limit of sent MMS is 100 Kb.
; This patch eliminates that limitation.
; Be aware that some MMS might be limited by the network or the receiving phone. It is not garanteed
; that a big MMS will arrive as originally sent.
; For the curious people: I changed Mmscli.dll in
; method CMmsClientMtm::MaximumSendSize
; to get a max of 4 Mb
replace:006810BC02BC0847000010B5806A9424A4000019016010BC01BC0047:C04610BC02BC0847000010B5806A9424A4000019016010BC01BC0047
; end of MMSbigger100Kb
duuri
5874.50 SMM
PostPosted: Sat Mar 04, 2006 7:39 pm    Post subject: gsicon.mbm na e: Reply with quote
patch treba stiahnut je pre viacero jazykovych verzii aj sk a cd..funguje v poriadku...
premiestnuje gsicon.mbm na eSmile
http://duuri.szm.sk/gsicon_16bbp.mbm
http://duuri.szm.sk/gsicon16.mbm
http://duuri.szm.sk/gsicon_to_e_multi.sxpr
Upraven link - nešlo stahovat. Gwin
Gwin
0.84 SMM
PostPosted: Sun Mar 05, 2006 10:34 am    Post subject: Reply with quote
Code:
; *** MMSbigger100Kb 1.1 ***
; Date: 2006.02.23 v1.0
; Date: 2006.03.02 v1.1
; patch to receive more than 100 Kb is not tested, but should work.
; The limit of send/receive MMS is 100 Kb.
; method CMmsClientMtm::MaximumSendSize and MaximumReceiveSize
replace:006810BC02BC0847000010B5806A9524A4000019016010BC01BC0047:C04610BC02BC0847000010B5806A9524A4000019016010BC01BC0047
; El limite para mandar/recibir MMS es de 100 Kb.
; Este parche elimina esta limitacion.
; Ten en cuenta que la red de telefonia puede decidir recortar el MMS. No se garantiza que un MMS grande
; llegue tal cual ha sido enviado.
Lukasisko
PostPosted: Tue Mar 07, 2006 1:49 pm    Post subject: Reply with quote
Přenese Kalendář na E\:
Pro správnou fci je nutné nechat na C:\System\Data jakýkoli souborek s názvem Calendar (bez přípony)
www.sweb.cz/spc2/06_calendar_to_e.sxpr
Sagem MC920 >> S/ME45i fw04 >> SX1 fw15cz patched + 1GB PQI >> SE P990i
BT GPS i-Tec 339
Wayfinder Navigator
Život je hořký. Bohudík.
Lukasisko
PostPosted: Tue Mar 07, 2006 1:54 pm    Post subject: Reply with quote
Add-on pro patch "Restart" (no. 58 na osliku)
Code:
;Zmeni hlasku "Uzamknout telefon" na "Restartovat!"
;by: [email protected]
;------Auto generated sxpr file----
;replace:original:new
;original:F:\SX1Tool\Apatcher_nastaveni\SysAp.r25
;new:F:\SX1Tool\Apatcher_nastaveni\Hlaska_Restartovat.rsc
Česká verze: www.sweb.cz/spc2/restartovat.sxpr
Slovenská verze:www.sweb.cz/spc2/SysAp_sk.sxpr
Sk verzi věnuji kolegovi a kamarádovi Sirusovi.
BT GPS i-Tec 339
Wayfinder Navigator
Gwin
0.84 SMM
PostPosted: Mon Mar 13, 2006 3:13 pm    Post subject: Reply with quote
Patch No 74
Code:
; *** Move T9 dictonary on disc E ***
; *** Presunuti T9 slovniku na disk E ***
; Author: Gandalf and NightShift79
; require: copy files from Z:\System\T9Ldb\*.* to E:\System\T9Ldb\*.*
; Pred aplikaci patche je potreba zkopirovat vsechny soubory z
;Z:\System\T9Ldb\*.* do E:\System\T9Ldb\*.*
; potom je mozne pridat jakykoliv slovnik T9
replace:7A003A005C00730079007300740065006D005C00740039006C00640062:65
Page 2 of 5
