:: View topic - SX1 BLBNE, PREHRATIE WINSUPU NEPOMOHLO, STALE VYBITA BATERIA
Goto page 1, 2, 3  Next
prihlaseny
PostPosted: Wed Jun 28, 2006 12:12 pm    Post subject: SX1 BLBNE, PREHRATIE WINSUPU NEPOMOHLO, STALE VYBITA BATERIA Reply with quote
nerozumiem testpointu sx1, treba tam rezat, alebo spijit odpor, vypocitat kody ako u x65, alebo ako? chcem to izivit v JOKEROVI, je tu aj FF pre joker, tak prosim o radu, ci ten testpoint treba spojit, a drzat, alebo rezat, alebo ako, mam mrtvu sx1, co bzuci, winsup nahraje, ale nezabera
prihlaseny
PostPosted: Wed Jun 28, 2006 12:12 pm    Post subject: Reply with quote
v servisnom rezime v Jokerovi pise:
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
BFB Speed 115200 Baud - Ok.
HWID: 194 (SX1)
SX1 lg44 Sw15 07.10.04 11:11:57
IMEI: 352079001391547
DisplayID: 0, Unknown or misses
Code(05): OTP closed
Code(0A): BootKEY misses in EEPROM
Code(0D): Keys are registered in BCORE
Code(10): Minimal access to BFB
Code(15): Complete condition
Code(19): Monitoring is switched on
Code(1D): Blocks 5121,5122,5123 are present
Battery Voltage very low! 2205 mV!
SecurityMode: Customer
info:
Get Info...
HWID: 194 (SX1)
Battery Voltage very low! 2206 mV!
DSP Firmware Version 09, Power Asic Project ID: B3, RF Chipset ID: 05
EELITE Info: free buffer 53632 bytes, free at all 55622 bytes, free for deleted 55622 bytes.
EEFULL Info: free buffer 22524 bytes, free at all 35424 bytes, free for deleted 27376 bytes.
Battery Ri measurement: CutOff Idle: 3478mV, CutOff Talk: 3528mV, CutOff Idle: 3366mV, CutOff Talk: 3441mV, CutOff Idle: 3469mV, CutOff Talk: 3569mV, CutOff Idle: 3469mV, CutOff Talk: 3569mV.
Operating time: Total 9123777 sec, Current SW 9082175 sec.
Talk time: Total 243704 sec, Current SW 243704 sec.
CSD: Total 251595 bytes, Current SW 251595 bytes.
GPRS: Total 4294967295 bytes, Current SW 0 bytes.
KDE JE CHYBA, NIEKEDY SA ZAPNE, NABEHNE CELY TELEFON, BATERKU UIKAZE PLNU, HNED PRAZDNU, INOKEDY BZUCI, INOKEDY ZAPINAM LEN IDE ZVUCKA PRI TOTALNE VYBITEJ BATERKE, ANI DISPLEJ NESVIETI, PORADTE, TELEFON JE AKO NOVY, DOSKA NEPOSKODENA, PROSTE BABIKA JE, V POVODNOM STAVE, ANI RAZ NESPADOL
prihlaseny
PostPosted: Wed Jun 28, 2006 12:14 pm    Post subject: Reply with quote
ked dam na nabijacku, telefon zabzuci a nenabija
dps
676.28 SMM
PostPosted: Wed Jun 28, 2006 12:38 pm    Post subject: Reply with quote
Dával si tam patche? Jetstli si tam dával čistej FW a jeho nahrání proběhlo bez problémů, tak běž radši do servisu. S testpointem nic nedělej jestli máš na telefon ještě záruku. Možná můžeš zkusit zapnout telefon bez MMC (jestli nemáš patche)
Mio
10930.24 SMM
PostPosted: Wed Jun 28, 2006 12:41 pm    Post subject: Reply with quote
Napeti baterie je polovicni nez ma byt, zkus ji nabit mimo telefon, navod najdes nekde tady v prispevcich. taky ocisti vnitrni i vnejsi kontakty baterie ..... . Baterie taky muze byt vadna.
Tespointy (jsou 3 moznosti) se u SX1 bud rezou (pokud je oznaceny spoj) nebo pres odpor uzemni (pokud je oznacen kontakt soucastky).
Jejich zobrazeni naleznes v Siemens Testpoint Station v sekci Utility
Joker funguje velmi podobne jako PapuaUtils, s testpointem se spojis a das vypocitat a pote zavest SKEY, pote muzes TP zrusit a mas telefon normalne pristupnej k flashovani odbloku atd..
N95-8GB
prihlaseny
PostPosted: Wed Jun 28, 2006 9:28 pm    Post subject: Reply with quote
bateriu som nabil mimo telefon, ma 4,1 V , a telefon v jokerovi stale hlasi voltage very low 2469 V, som uz fakt zufali, je to uplne novy telefon, dovezeny, povodny stav, bateria cista kontakty, proste nic mechanicky neposkodene, moze to byt chybny symbian? telefon jak dam na nabijacku, tak sa rosviti, nabehne ikonka nabijania na 2 sekundy, telefon zabzuci a konec
PostPosted: Wed Jun 28, 2006 9:31 pm    Post subject: Reply with quote
Mal som podobny problem ale akurat taky ze telefon nesiel vobec ale s jokerom fungoval a niekedy zabzucal ze je vybita bateria. Nepomohol ani TP teraz je uz 2 tyzdne v servise a stale nevedia co je s nim.
prihlaseny
PostPosted: Wed Jun 28, 2006 10:56 pm    Post subject: Reply with quote
ty si vistihol moj problem s tym bzucanim, spravil som TP, nahral FF cez jokera, telefon sa zapne, a stale bzuci, sem tam nabehnew, nenabija, prsote bude asi cely symbian poskodeny, ale ako ho dostat do telefonu? hm?
prihlaseny
PostPosted: Wed Jun 28, 2006 11:45 pm    Post subject: Reply with quote
PO OZIVENI CEZ JOKER SA TELEFON ZAPNE, NO VYPISE HLASKU: PRI ZAPNUTI SA VYSKYTLA CHYBA, KONTAKTUJTE PREDAJCU, A TELEFON SA VYPNE, CO S TYM? PREHRAT SYMBIAN?
Sirus
7910.50 SMM
PostPosted: Thu Jun 29, 2006 6:32 am    Post subject: Reply with quote
Tuto hlasku som pri mojich testoch s SX1 videl par krat a stacilo prehrat FW a bolo po probleme. Ale ci vyriesi aj ten tvoj, boh zna. Na TP a ozivovanie je na SM najvacsi kapo Krokodyl, upozornim ho na tento thread, snad pomoze.
prihlaseny
PostPosted: Thu Jun 29, 2006 8:25 am    Post subject: Reply with quote
lenze tu hlasku mi vypise ked zalozim baterku z a50 siemensu, mam rozobraty, a len zo zadu na cistu dosku prilozim tu bateriu, a nabehne s tou hlaskou, o originalnou bateriou sx1 proste to nejde, nechapem
TP som spravil ten s odporom, joker nacital, tu je hlaska z neho po prehrati flashu:
tart...
HWID: 194 (SX1)
SX1 lg44 Sw12 23.04.04 08:59:17
Code(09): BootKEY is written in EEPROM
Code(0C): Keys miss in BCORE (CleanBCORE)
Code(1A): Block 76 is accessible
Code(1C): Block 5123 is not found
Battery Voltage very low! 2207 mV!
info:
Get Info...
MobileMode: Service
HWID: 194 (SX1)
FSN: 21E72CAB
SW FlashID: 0089/8854 (0090/0090)
Code(13): Complete access to BFB
Battery Voltage very low! 2198 mV!
SecurityMode: Factory
EELITE Info: free buffer 54360 bytes, free at all 55622 bytes, free for deleted 55622 bytes.
EEFULL Info: free buffer 14374 bytes, free at all 35424 bytes, free for deleted 27376 bytes.
Battery Ri measurement: CutOff Idle: 3462mV, CutOff Talk: 3512mV, CutOff Idle: 3374mV, CutOff Talk: 3466mV, CutOff Idle: 3454mV, CutOff Talk: 3512mV, CutOff Idle: 3469mV, CutOff Talk: 3569mV.
Operating time: Total 15254880 sec, Current SW 15254880 sec.
Talk time: Total 31932 sec, Current SW 31932 sec.
CSD: Total 3861 bytes, Current SW 3861 bytes.
prihlaseny
PostPosted: Thu Jun 29, 2006 8:28 am    Post subject: Reply with quote
hlaska po recal keys:
Loading BootsModel(SX1)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com4 921600 BAUD: Ok.
Warning: HASH data error!
SIEMENS SX1 lg44 Sw12
Soft FlashID: 0089/8854 (0090/0090)
FlashID: 0089/8854
Flash Size: 8Mb
Region(1): Blocks 127, Size 64Kb
Region(2): Blocks 8, Size 8Kb
Start EEPROM segments at addres 0xFE0000
FSN: 21E72CAB -> PhoneID: AB2CE721
OTP IMEI: 352079001391547
HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Use OTP IMEI: 352079001391547
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
Read BCORE addr: 0x800000 size: 0x020000...
BCORE Clean! Use Freeze!
Read EEPROM addr: 0xFE0000 size: 0x020000...
EEPROM backup in ".\Backup\SX1lg44Sw12_EEPROM_060629092759.bin" file.
Write EEPROM addr: 0xFE0000 size: 0x020000...
Change BOOTKEY - Ok.
Change EEP0076 - Ok.
Change EEP5009 - Ok.
Change EEP5077 - Ok.
Change EEP5121 - Ok.
Change EEP5122 - Ok.
Change EEP5123 - Ok.
Mio
10930.24 SMM
PostPosted: Thu Jun 29, 2006 8:44 am    Post subject: Reply with quote
Dable nedelal bych to touhle rychlosti, bezpecnejsi je 57600
Jinak HASH mi pride prinejmesim podezrele. vzhledem k tomu ze hazi pri nacitani chybu.
Myslim ze sis svou aktivitou ten telefon dostal do daleko horsiho stavu, proc si sakra delal recall keys??
Udelej Freeze a pak zopakni prepocet klicu. (pri rychlosti 57600)
Pak odeber TP a dej tam novy FW winswup.
N95-8GB
prihlaseny
PostPosted: Thu Jun 29, 2006 8:50 am    Post subject: Reply with quote
jak mam odobrat TP? ten som spojil, a uz ide stale, v jokerovi nacita stale ho, jak to mam odobrat, nechapem, prilozil som len odpor, a spravil TP, ziaden pevny TP tam nieje
Mio
10930.24 SMM
PostPosted: Thu Jun 29, 2006 8:51 am    Post subject: Reply with quote
To je OK, Joker si zavedl SKEY, takze ted se spoji i bez TP, odeber jako odeber ten dratek s odporem :-)
Jo jinak jestli ti funguje blbe s baterii, ale ta ma odpovidajici napeti, zkus prelepit prostredni kontakt baterie.
Mas skype? Zavolej mi poresime to.
N95-8GB
Page 1 of 3
