:: View topic - Graficke patche GPF
Graficke patche GPF
Goto page 1, 2  Next
coyotelada22
PostPosted: Fri Oct 20, 2006 11:28 am    Post subject: Graficke patche GPF Reply with quote
skusam prejst na GPF patche ale je tu problem.
podla navodu som chybu nespravil, zlozka gpf je vytvorena aj s GPF suborom nasledne na to som dal refresh a ........ nic sa nestalo?
Moze byt problem v mojej S 65?
> 1 GB MS DV RS MMC Apacer
> 16 GB Micro SD class 2
>JBenchmark1 27 638 bodov
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Fri Oct 20, 2006 12:10 pm    Post subject: Reply with quote
vypni a zapni mobil... mi to taky obcas nejde...
-> Nokia Lumia 800
coyotelada22
PostPosted: Fri Oct 20, 2006 12:27 pm    Post subject: Reply with quote
nejako to nejde ani po zapnuti
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Fri Oct 20, 2006 12:56 pm    Post subject: Reply with quote
tak si stahni GPFactory 0.98beta a ukladej pokazde max jeden obrazek... az budes ukladat tak tam pripis koncovku .gpf a pojede to wink
-> Nokia Lumia 800
coyotelada22
PostPosted: Fri Oct 20, 2006 2:11 pm    Post subject: Reply with quote
bohuzial nejde a ani po zapnuti
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Fri Oct 20, 2006 2:16 pm    Post subject: Reply with quote
to je divny... mi to vali...
-> Nokia Lumia 800
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Fri Oct 20, 2006 2:22 pm    Post subject: Re: Graficke patche GPF Reply with quote
A mas Master Patch 3 alebo 3.1b3???
coyotelada22
PostPosted: Fri Oct 20, 2006 2:22 pm    Post subject: Reply with quote
este sa s tym skusim pohrat asi s tym nieco bude
coyotelada22
PostPosted: Fri Oct 20, 2006 2:27 pm    Post subject: Reply with quote
jasne ze mam ved master patch je dolezity a mam toto:
Master patch v3.1 by 1nvisible
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Fri Oct 20, 2006 2:30 pm    Post subject: Reply with quote
hm... tak to je fakt zaujimave... d'oh!
skus si stiahnut uz neake vytvorene GPF-cka a vyskusaj tie... alebo skus rovno GPP
coyotelada22
PostPosted: Fri Oct 20, 2006 2:44 pm    Post subject: Reply with quote
prave teraz spm vyskusal GPP ratch a nejde ani ten,
v tomto momente neviem co je s tym ale vsetko podla postupu mam spravne, vyskusany refresh a znovuzapnutie S 65 nefunguje
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Fri Oct 20, 2006 5:49 pm    Post subject: Reply with quote
mi to taky nijak nejde wink ani GPF ani GPP... fachci mi jen GPP prejmenovane na GPF z programu GPfactory 0.98beta
-> Nokia Lumia 800
PostPosted: Fri Oct 20, 2006 5:52 pm    Post subject: Reply with quote
Problem moze byt v samotnom GPF subore,ak si si ho robil Ty,tak si mohol dat nespravne cislo obrazku,lebo tie cisla treba zadavat v HEX sustave. Ja robim GPF vyhradne pomocou Smelteru a idu vsetky bez problemov.
coyotelada22
PostPosted: Sat Oct 21, 2006 10:01 am    Post subject: Reply with quote
a v smelter programe sa tvoria ako prezrel som cely a nic mozno som nieco prehliadol smelter mam 6.12
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Sat Oct 21, 2006 10:26 am    Post subject: Reply with quote
otvoris fullfash v SPC nahras tam obrazky ktore chces, ulozis zalohu a otvoris si ju v Smelteri 8.30 (ten co mas ty este Gpf asi nepodporuje) a tam si najdes ten zmeneny obrazok a das ho pravym tlacidlom ulozit ako gpf. To iste spravis aj s ostatnymi zmenenymi obrazkami
Goto page 1, 2  Next
Page 1 of 2
