Cieniu pisatel
Založen: 14. 04. 2006 Příspěvky: 242 Bydliště: -Poland- .:Szczytno:. Telefon: EL71 v45 PL I Csl65 v53
Zaslal: čt listopad 16, 2006 11:02 pm Předmět: |
yes I had Make So as You have written and further PIK _________________
www.forum.siemensiak.pl |
Sefinko elfmaster
6980.53 SMM
Cieniu pisatel
Zaslal: čt listopad 16, 2006 11:31 pm Předmět: |
yes acc temperature Already act < gun > < happen > _________________
Sefinko elfmaster
6980.53 SMM
Sefinko elfmaster
6980.53 SMM
Zaslal: so listopad 18, 2006 4:01 pm Předmět: |
Drop Call On Certain Time v1.2 pre SL65fw 53 8)
kód: | ;SL65v53
;Drop Call On Certain Time
;(c) 1nvisible
;(r) (i) ~Jhellico
;(p) Benlux
;Version: 1.2
0B43F2C: 00F029FD01300004000C 004CA047,0xA0FC4B01,C046
#pragma enable old_equal_ff
0FC4B00: FEB5FBF745FC041C0E48FCF779F810D0
0FC4B10: 0120FBF741FC022803D0032809D1B078
0FC4B20: 00E07078012804D17268A24201D1FBF7
0FC4B30: FBFB601CFEBC0004000C0AF07AEA
0FC4B40: 0xB1C2D3E4,0x00001E01,0000000000000000,"\
{patch DropCallOnCertainTime cp=1nvisible id=1E01 ver=1.2}","\
{1 cb DropOutgoing v=1}","\
{2 cb DropIncoming}","\
{4 int Second r=0..1000 v=5}",00
#pragma disable old_equal_ff
Download VKP
EDIT: patche stahujte radsej cez Download VKP (prave tlacidlo - Ulozit cil odkazu jako...), lebo ak len skopirujete kod tak môzu blbnut, a treba ich potom doupravovat... _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
Sefinko elfmaster
6980.53 SMM
Zaslal: ne listopad 19, 2006 4:52 pm Předmět: |
Turn vibra on-off on keypad lock-unlock v0.3
kód: | ;Turn vibra on/off on keypad lock/unlock
;SL65v53
;(c) ~Jhellico
;(r) empeka
;(p) Benlux
;Version: 0.3
1150CB4: 1039886001210320 004FB847,0xA0FC7001
115103C: 0120886001210320 004FB847,0xA0FC7005
0FC7000: 002200E0012278B5F9F74EFB3A600948
0FC7010: F9F7F6FD07D004B4F9F7F2F804BC9042
0FC7020: 01D0F9F741F978BC0121032008F000E8
0FC7030: 0xB1C2D3E4,0x00003101,0000000000000000,\
"{patch=VibraOnKeyLock id=3101 cp=`~Jhellico` ver=0.3}",00
Download VKP _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
nerow tuner
8011.36 SMM
Zaslal: st listopad 22, 2006 7:13 am Předmět: |
Tak jsem rozběhal MP14 a z třídeního používání se oběvily mouchy.Když mám v MP zapnutý extra info 7.1 a Big Digi na MS 5.5 tak se mi nezobrazjue extra info.POkavad vypnu Digi, tak extra info zase bezi.Jinak na Mp14 si nemuzu stěžovat a hlavně mi tam jdou patche, co na Mp3.1b nešly... _________________ Windows Mobile 6 | Mac OS X Leopard | Mobile Mac OS X | Project X |
Sefinko elfmaster
6980.53 SMM
Sefinko elfmaster
6980.53 SMM
Zaslal: st listopad 22, 2006 7:05 pm Předmět: |
nerow napsal: | Tak jsem rozběhal MP14 a z třídeního používání se oběvily mouchy.Když mám v MP zapnutý extra info 7.1 a Big Digi na MS 5.5 tak se mi nezobrazjue extra info.POkavad vypnu Digi, tak extra info zase bezi.Jinak na Mp14 si nemuzu stěžovat a hlavně mi tam jdou patche, co na Mp3.1b nešly... |
Aplikuj namiesto Mainscreen-dispatcher v3.1 patch GraphPatchManager v3.1 av a pouzivaj extra info 7.1 a ostatne patche pre GraphPatchManager 8) _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
Sefinko elfmaster
6980.53 SMM
Zaslal: st listopad 22, 2006 7:10 pm Předmět: |
Novy ELFlpack v1.8++ pre SL65fw53, ale treba najprv odstranit Patche: BigFunctinLibrary, elfLoader, SWI hook a FREAD32/FWRITE32 z patchu api, a potom by to malo slapat v pohode... _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71
Naposledy upravil Sefinko dne čt listopad 23, 2006 8:49 am, celkově upraveno 1 krát |
Sefinko elfmaster
6980.53 SMM
Zaslal: st listopad 22, 2006 8:02 pm Předmět: CSM list pre Sl65fw53 |
;SL65v53 CSM list
;18:55 22.11.2006
;32 processes
;(c) tick
CSM list.txt
;SL65v53 CSM list
;15:04 24.11.2006
;45 processes
;(c) tick
CSM list.txt
Nakopirovat do: 0:\ZBin\etc\ _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71
Naposledy upravil Sefinko dne so listopad 25, 2006 8:19 am, celkově upraveno 2 krát |
nerow tuner
8011.36 SMM
Zaslal: čt listopad 23, 2006 9:35 pm Předmět: |
A toto je alkabův překlad do češtiny...
citace: | ;SL65v53 CSM list
;18:55 22.11.2006
;32 processes
;(c) alkaba
A092649C Moje menu
A092C294 Test podsviceni
A0A0DE08 Card Explorer
A0A0E300 Media Player
A0A108B4 MMS Editor
A0A11DE4 Temata
A0A187C4 Prichozi MMS
A0AFB6DC SMS podpis
A0AFBE0C Textovy Editor
A0AFC10C Doruceno
A0AFD7C8 Ukoly
A0AFD8BC Poznamky
A0AFF060 Nova SMS
A0AFF14C Prichozi SMS
A0AFF320 Cteni SMS
A0AFF638 SMS Profily
A0B00FAC Adresar
A0B01548 Kalendar
A0B02CB0 Seznam volani
A0B02D00 Zaznam volani
A0B08934 Vzdal. Synch
A0B08CD0 MMS nastaveni
A0BDA210 Alarm
A0BE6814 Odpocitavani
A0BE6830 Stopky
A0BF3C38 SIM adresar
A1205340 Nejaky dialog
A1207A44 Java machine
A14880B4 Vstup. jazyk
A1662880 Kod telefonu
A1665ECC Nahravani zvuku
A16628A0 Doba hovoru |
Sefinko elfmaster
6980.53 SMM
Zaslal: čt listopad 30, 2006 9:50 pm Předmět: Pridanie Elf-zlozky do "MyStuff" |
Tento patch prida zlozku "Zbin" do menu "MyStuff" (Vlastní soubory)
Nahlad:
kód: | ;SL65v53
;Add Elf-Folder to the MyStuff
;(c) ZoZoLe
;(r) Crazy_heead
;(p) Benlux
;PatchID: 6450
;!There is a file attached to this patch, http://patches.kibab.com/cnt.php5?d=cx70v56&f=elf_mystuff_2.rar
;0:\ZBin -> 0:\Text
00A0960E: 30003A005C0054006500780074 30003A005C005A00420069006E
;------------------------- end -------------------------
Download VKP
- pomocou programu "mscx65" (MyStuff creator x65) pridajte zlozku: 0:\Text do suboru MyStuff.xml _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
Sefinko elfmaster
6980.53 SMM
Sefinko elfmaster
6980.53 SMM
Zaslal: so prosinec 09, 2006 6:40 pm Předmět: |
Neake patche pre SL65fw53:
- Remove GPRS sound
- Superfast main menu
- Timer signal louder and longer
kód: | ;Remove GPRS sound
;(c) AlexeyZ
;(p) НекрономикоН
13B8918: 5352544600000400C409D200000000000000000000000000
; Замена меню на супербыстрое
; Superfast main menu
;(c) SiNgle, § AsteriX
;(p) НекрономикоН
09224C4: 33448E A1B68C
; * Timer signal louder and longer *
; (c) StrikerX
; (p) Weron
13A3940: 208D 4885 |
