konga kolemjdoucí
Založen: 01. 03. 2005 Příspěvky: 4
Zaslal: st červen 13, 2007 3:37 pm Předmět: Mini GPS for EL71? or ELF |
hello,
does anyone have a suggestion for the MiniGPS patch on EL71?
on simens-club there is an elf. but it only shows the cell id on mainscreen.
no profile change was changed..
konga |
Sefinko elfmaster
6980.53 SMM
Zaslal: st červen 13, 2007 8:28 pm Předmět: Re: Mini GPS for EL71? or ELF |
konga napsal: | hello,
konga |
You try apply patch Dynamic Provider v17. In master midlet you must set "F" in first or second line, and check box "CreateNewTMO". _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
konga kolemjdoucí
Zaslal: čt červen 14, 2007 7:57 am Předmět: |
yes this still works, tmo files has been writen to \misc\gps but to change the profile by 1-8 in tmo file doesn't work.
konga |
