testbug kolemjdoucí
Založen: 20. 11. 2004 Příspěvky: 13
Zaslal: po červenec 23, 2007 8:31 pm Předmět: SL91 + BREW Commander |
Hi there!
Today i received my SL91!
But i cant get a connection with my DCA-140 and the "Brew Commander"!
MPM won't work with Vista, so i tried other Software..
I heard, there is a solution, how to get a successful connection with BMC and the SL)! Is it true?
Hope to egt useful answers!
Regards from germany |
adfree badatel
Založen: 10. 08. 2006 Příspěvky: 121
388.38 SMM
Zaslal: po červenec 23, 2007 10:35 pm Předmět: |
This is no Rumour... SL91 works also with BMC.
You need only the Driver from 3GSwup...
If you have 64 Bit Vista? Game over man. No Driver... |
testbug kolemjdoucí
Zaslal: pá červenec 27, 2007 6:41 pm Předmět: |
drivers from 3gswup?
from where? |
dnteam začátečník
Založen: 16. 12. 2006 Příspěvky: 34
Zaslal: ne srpen 05, 2007 9:29 am Předmět: |
testbug napsal: | drivers from 3gswup?
from where? |
u need to install usbdriver as the swup file does after install the program |
