Sefinko elfmaster
6980.53 SMM
Zaslal: út srpen 14, 2007 9:27 pm Předmět: ExtraInfo v1.2 |
ExtraInfo v1.2
+ opravene niektore chyby z predchadzajucich verzii
- odstranena chyba s vypisovanim neznameho CSM
- opravena chyba s ukazovanim (°) pri teplote, treba prepisat cislo obrazka 2224 na 2142
- a mnozstvo dalsich chyb...
+ pridane nastavenia zvlast pre Lock a UnLock
+ pridane nastavenia niektorych textovych sprav
+ nastavenie vysky stlpca pri AdvNet _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
Sefinko elfmaster
6980.53 SMM
Zaslal: st srpen 29, 2007 12:18 am Předmět: |
XTask v3.0
- pridany NewStyleDaemon's
- tlacidlom "#" sa vypinaju procesy
- tlacidlom "*" sa prepina medzi zobrazenim spustenych elfov
Screen:
SndDemon v1.48
- podpora NewStyleDaemon's
- opravene niektore chyby predoslej verzie
- pridane klavesy na prepinanie skladieb (dlhe stlacenie vol+ alebo vol-)
GPSlogger v3.0
- taktiez opravene niektore chyby predoslej verzie _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71
Naposledy upravil Sefinko dne st srpen 29, 2007 1:24 pm, celkově upraveno 1 krát |
Sefinko elfmaster
6980.53 SMM
Sefinko elfmaster
6980.53 SMM
michalkopecky redaktor
13617.60 SMM
Zaslal: so září 01, 2007 7:11 pm Předmět: EC Dict |
English-Chinese Dict
kód: | ECDict English Dictionary -- original (source code has been)
English-Chinese dictionary I always wanted the elf, used x618 know who own a mobile phone dictionary benefits. . Although some good java dictionary, speed is relatively slow and not very cool, sometimes is quick to point o (∩ _ ∩) o. ..
I have been amended six versions, version 0.6 is now out, although there are some bug, but individuals feel they have more satisfied ..
On the function, they do not have to explain it. .
Please see screenshots :
Use :
1. Put unpacked the two dictionaries, put 0 : \ ZBin \ dict \ or 4 : \ ZBin \ dict Lane :
Part I : dict.part1.rar (468.75 KB)
Part II : dict.part2.rar (457.18 KB)
2. Download your models with the elf, where casually put :
SGOLD I tested, and it should be no problem : ECDict_SGOLD.rar (569 KB)
ELKA NEWSGOLD and, without trying can use : ECDict_NEWSGOLD_ELKA.rar (5.7 KB)
QUOTE :
This is an English version of the allocation, if the above configuration of the Chinese version has a problem, please try this :
ECDict_v0.6 English configuration. Rar (16.89 KB) (includes SGOLD, NEWSGOLD, ELKA)
3. If you like the above picture kind of layout and interface, can download the configuration file : (non-essential, the best configurable)
SGOLD suitable for the configuration file : ECDict.bcfg.rar (475 Bytes)
Note :
1.非sgold请先修改下配置再用,主要是修改字号!
2. This procedure larger RAM occupied, please do not and other large elf together, they will easily lead to lockups. Java and the running but nothing together, and I found that only a small java running of RAM.
3. Many word phonetic transcription showed [] is not bug, this is also a lot of words had not been included phonetic transcription information.
Shortcuts :
* Does it show that the switch keys floating interpretation;
Green explained float switch keys show phonetic transcription functions;
See more configuration installed it. Chinese configurations, the need to 4.19 after CfgEdit support.
V0.6 known BUG :
1. Many phonetic transcription symbols not normal, have shown, as a point, I think the test is the lack of phone own font symbols of the phonetic transcription. . They can not hope to have the fonts will get brothers will help change includes a phonetic transcription symbol fonts it.
2. View detailed explanations of the word to word input interface and English T9 input state could not maintain. (Back to the words of each input interface, and if you set up phone-based Lane priority of T9 is the No.9 importation of state, the absence of even the general state of importation). I know the bug, but temporarily unsolved.
3. Over the long words and his party could not show rolling. But such cases are not, and will not changed.
In addition, the document itself dictionary some bug, I have no time to amend. This dictionary is the StarDict dictionary format, in order to save memory, a slightly revised StarDict under linux is a famous dictionary software, many of my friends should understand.
(Levy basically completed ... ... napping go home a bit recently, the procedure hope like to wish the people healthy and my family ... thank you.)
Neměl jsem možnost to vyzkoušet. Soubory pro slovník jsou celkem velké 2,5MB a já mám volno pod 1MB. Je to pro SGOLD, NewSGOLD i ELKA. Jsem zvědavý na tu čínštinu, jak se zobrazí.
Download
kód: | http://rapidshare.com/files/52715990/Ecdict.ZIP |
_________________ N3410 > Siemens CX70v56 WVA TNG 3.1 > C72 > SE K750i CID49 RED > Vodafone 845 > HTC Desire Z (Android 4.0.4)
http://droidik.blogspot.cz |
Duku uživatel roka 2008
Zaslal: út září 04, 2007 9:08 am Předmět: |
IdleLinks SK
PicPusk SK
Preklad hlavne PicPusku (posledna verzia) je sice dost biedny, ale lepsie kao rozsypany caj _________________ EL71 Black FW45 + Kingston 2GB + DCA-110 + DCA-140 + HHS-150
>Daruj krv< |
Sefinko elfmaster
6980.53 SMM
P4priX ostřílený diskusník
Založen: 25. 12. 2004 Příspěvky: 538
128.03 SMM
Zaslal: út září 25, 2007 10:16 pm Předmět: |
SPlayer v0.5.4 - Nová verze _________________ Siemens C60 -> Siemens M65 -> BenQ-Siemens EL71 -> BenQ E72 -> HTC Touch Pro -> HTC Desire Z -> SE Xperia Mini Pro |
Sefinko elfmaster
6980.53 SMM
Zaslal: pá září 28, 2007 9:20 am Předmět: |
XTAsk 3.0 Sk
(c) Rst7
- skompilovana a upravena verzia z poslednej upravy na SVN
- pridana podpora slovenciny a zmenene ovladanie
- obsahuje v sebe moznost vypinania elfov s podporou NewStyleDaemon's
Ovladanie specialne upravene pre ELKU:
GREEN_BUTTON - zobrazenie/skrytie spustenych elfov s podporov NSD
RIGHT_BUTTON - zobrazenie volby Zalozky
LEFT_BUTTON - vypinanie procesov (Kill proceses)
Screen:
PS: pridavam to sem, lebo mi nejak nejdu pridavat elfy, úpre ELKU...
EDIT: tak uz funguje to pridavanie vdaka za pomoc whitek-ovi _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
Sefinko elfmaster
6980.53 SMM
Zaslal: čt říjen 04, 2007 7:29 am Předmět: |
ExtraInfo v1.8
+ prelozene texty v elfe zobrazujuce CSM a hladanie siete do slovenciny
Dodane:
+ podpora traffika iba po súčasnom spusteni
+ podpora zobrazenia 4-textovych súborov s max. velkostou 4kb.
+ podpora systémov fontov s ladením farby a ohranicenia. (este som netestoval ako sa nastavuje )
+ zvyseny pocet fontov v nastavenie ExtraInfa
Opravene:
- Niektoré vnútorné chyby
- Optimalizácia zobrazenia
PS: Nemam este screen ani uplny popis a hlavne pristup k netu tak to davam zatial sem, no zajtra pridam do sekcie s ELFY aj s obrazkami atd... a aj nejake tie patche a elf-y _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
Sefinko elfmaster
6980.53 SMM
mart22 elfmaster
56669.28 SMM
mart22 elfmaster
56669.28 SMM
Zaslal: st říjen 17, 2007 8:23 pm Předmět: KeyBlock + AudioBuffer elf |
KeyBlock: přidáno nastavení pro časy: minuty + sekundy
EDIT: opravena chyba kdy se načítalo defaultní nastavení.
(mart22)
AudioBuffer: Elf změní velikost a počet audio bufferů. Nastavení v bcfg.
Defaulntí nastavení :5 bufferů, 120KB. Vhodné do daemons. Adresa je pro E71 (pokud nevíte jaká je pro další modely, tak jí zjístíte z nastavení elfu snddemon- je ve stejném formátu)
EDIT: Opraveny názvy parametrů v bcfg
(mart22)
Diskmon
+ funkční podpora podmínek zobrazení (Lock,Unlock,Both)
+ podmínka zda se má u každého disku zobrazit ikona
! cestu k obrázkům zakončujte \
(autor=windes,úprava=mart22) _________________ E71v45 + Testpoint, MasterPatch 14, ElfPack 2.3CZ , 1GB
Naposledy upravil mart22 dne pá říjen 19, 2007 4:26 pm, celkově upraveno 1 krát |
Sefinko elfmaster
6980.53 SMM
Zaslal: pá říjen 19, 2007 10:11 am Předmět: |
Pridane nove elfy:
- Alarm
- elfy by mart22
Alarm je zatial len vo vyvoji, a nie je na ELKE zatial možne menit zvuk alarmu standardne je nastaveny zvuk ktory mate nastaveny na normalny budik, zmenil som pozicie niektorych textov atd. no aj tak na ELKU je potrebne este toho dosť menit, ale podstatne je ze to funguje. PNG obrazky su v archive a kazdy si ich moze upravit podla svojho.
Vsetky zmienene elfy s popisom najdete k stiahnutiu v sekci: Elfy-S-Gold3 _________________ C(SL)65v53 + MP14 + ELfpack 2.01 | Patche, Elfy, atď. pre EL71 |
mart22 elfmaster
56669.28 SMM
Zaslal: ne listopad 11, 2007 6:33 pm Předmět: Elf : 208 MHz CPU x85 |
ELF na udržení 208 MHz všude kromě Screensaveru a Mainscreeenu
1. testovcí verze pro E71 a EL71
2. Pro EL71: soubor otevřít v hex editoru, na adrese 9C přepsat 849DF5A8 na DC94F5A8 (obrácená adresa RamNotOnMainscreen)
3. pište zda elf funguje dobře nebo nezpomaluje mobil. (Podpora NewStyleDaemons,ale po vypnutí funguje dál)
ZJIŠTĚNÉ BUGY:
Nejde kalendář
nejde vypnout telefon-napůl se zasekne
(mart22)
Extrainfo 2.00
změny
06.11
Added:
Conclusion id3 tagov
Corrected o:
Conclusion time to start is now in hh: mm: cc
Optimization of memory used zjistil jsem že původní verze žere 300 KB .. ještě jsem netestoval
Several errors rendering
(Miha_r) _________________ E71v45 + Testpoint, MasterPatch 14, ElfPack 2.3CZ , 1GB
