:: Zobrazit téma - [Sgold] - Elfy
[Sgold] - Elfy
Jdi na stránku Předchozí  1, 2, 3 ... , 13, 14, 15  Další
Odpovědět na téma    Obsah fóra -> Elfy
michalkopecky
Založen: 30. 11. 2004
13617.60 SMM
PříspěvekZaslal: so září 01, 2007 7:24 pm    Předmět: KeyExten Odpovědět s citátem
KeyExten v2.0/Lite/mod v1.0 button switch
kód:
KeyExten
Version 1.0
(C) Abbing
V1.1 in the fourth floor!
V1.5/v1.51 the ninth floor!
V1.8/v1.81 the 13th floor!
Lite version of the amendment for the other 65 with the 20th floor!
V1.9 of the 21st floor!
V2.0, the 22 floor liteX
Mod v1.0 by crack4000, 23rd Floor,
I do not know where to start. . .
SK maker's eight keyboard, which is now basically can enter text, feeling rather wasteful, wrote this patch, where they can have a keyboard on the keyboard functions, it can also alleviate the pressure on the keyboard (on my keyboard some poor oh). . .
Not to the other 65 models can not be used, but not necessary, not so much SK keys on the keyboard has been basically a complete application
This patch is a change in the basic tenets of keys keys. . . Want to change the keys of the other models can also give it a try!
The best change in the law should be a general state, under the keyboard on the keyboard in full possession of the function, when the need to edit the text input when switching back to the original keyboard functions, but at present not to judge the state of importation, but the use of long-functional! Only two set up short by function. . .
Talk about basic configuration (keys are metric) :
QUOTE :
Key objectives will not affect repeat keys! But the key change was best not to repeat keys!
Keys can test if keytest java software, or if IWatch elf, keytest
Started four options, namely, a short set by the two buttons (I think the two keys, and the blanks on the stalls bond to be released one)!
APs set to : / / set up the first goal of a button keys, which defaults to 26, which is key
APs : / / modification button keys, which defaults to 98, that is the right space bar
/ / Through the above two, we can achieve our goal of the right side of the space bar replaced the functional purpose of the keys
Ibid Key2 ...! The default is on the right side stalls to the right softkey button!
Below Long Press Keys : by entering long keys settings here, including all of the keys on the keyboard
Enter Key : / / key target set for the bond, which defaults to 67, which is set to d keys bond
Left Soft Key : / / default 86, which is set to w left softkey
Default settings :
Bonding : d
The left softkey : w, right softkey : o, green keys : z, the red button :,
: E, : x, left : s right : f
A : z, 2 : u, 3 : i
4 : h, 5 : j, 6 : k
7 : b, 8 : n, 9 : m
: * T, 0 : g # : v
Side : p Side :.
The problem :
QUOTE :
1. The importation of English law, under a long letter on the keyboard is capital letters, the elf disable the corresponding function keys
2. Standby mode is short and functional, some by the time the result is not, by the second time, then it is a time of two effects, such as bond set to, the short time I did not effect the second time flash JiuGongTu menu, direct access to the information menu, but if you set for the three key figures not such a problem
3. Long is not the time by the master, must slowly familiar with the
4. Some still can not completely replace, for example by entering XTask of key tasks menu, I set up a space to the right of key time, not long out by the mandate of the menu may also need another wrote!
. . . Please add. . .
Vypadá to na elf upravující kódy kláves...
Download:
kód:
http://uloz.to/35535/KeyExten2.0.zip
http://droidik.blogspot.cz
michalkopecky
13617.60 SMM
PříspěvekZaslal: po září 03, 2007 10:11 pm    Předmět: MC 0.9 Odpovědět s citátem
MC 0.9
kód:
http://forum.siemens-club.org/attachs.php?action=getfile&attachID=18979
michalkopecky
13617.60 SMM
PříspěvekZaslal: út září 04, 2007 9:40 am    Předmět: Odpovědět s citátem
MC 0.9.1
ExtraInfo 1.5
IcqGps
CallCenter CZ s NSD
Svátky 0.52
michalkopecky
13617.60 SMM
PříspěvekZaslal: út září 04, 2007 10:22 am    Předmět: Nové elfy Odpovědět s citátem
Protože jsem měl problémy s mým "Gadget-chladičem" obaleným natvrdo prachem a počítač se mi vypínal, tak nové elfy jsou v archívu všechny najednou.
Download
Obsahuje:
Freespaced
- poup při nedostatku místa
Freepaste
- zobrazení text. poznámky na MS
Matrix
- spořič
SieGet
MP3 for Call 1.1
- nová verze
STime
- poup s časem v EN/RU
Rotate
XTask Plug for XTask 2 a vvyšší
- plugin informacemi o čase, baterii...
exotické XTasky
- x tasky s grafickým prostředím a dalšími vychytávky, ale je probléím s lokalizací. Na screenu zrovna 1 takový vidíte. Myslím taky, že by se k tomu daly sehnat zdrojáky.
Trochu jsem upravil screeny a odkazy na stazeni. simp
michalkopecky
13617.60 SMM
PříspěvekZaslal: st září 05, 2007 12:15 pm    Předmět: Weather Odpovědět s citátem
Weather
- potřeba elf GprsD
michalkopecky
13617.60 SMM
PříspěvekZaslal: čt září 06, 2007 3:42 pm    Předmět: Odpovědět s citátem
MC 0.9.5
- to je rychlost - několik verzí denně
simp
moderátor
moderátor
Založen: 23. 07. 2005
Telefon: S65
11968.90 SMM
PříspěvekZaslal: so září 08, 2007 10:38 am    Předmět: XTask SGOLD Odpovědět s citátem
XTask
Toto je XTask z archivu od Michala Kopeckého (o 3 příspěvky výš)
Sice je čínský, ale skvěle funkční, kromě nastavení nemá problémy s češtinou ani diakritikou, při používání se nikde nezobrazují žádné klikyháky.
Hlavní okno vypadá jako standardní součást telefonu, mění se podle skinu a zobrazuje čas.
V archivu je plugin který mezi spuštěnými úkoly zobrazuje čas, volnou operační paměť a zbývající kapacitu baterie, CSM list pro CX70 FW56 s diakritikou, elf samotný a můj soubor BCFG s nastavením.
V mém případě se spouští dlouhým stiskem nuly a na hlavním displeji je vpravo nahoře číslo oznamující počet spuštěných procesů bez ikonky.
Další ovládání:
Zelené sluchátko: Ukončení procesu
Stisk číselného tlačítka: Spuštění nastavené zkratky
Nula: Zobrazení seznamu zkratek (Pokud mám nastaveno spuštění XTasku na dlouhý stisk nuly, tak mi toto nefunguje)
Nastavení BCFG souboru
Druhý obrázek
První položka: Cesta k CSM listu
Druhá položka: Způsob spuštění (Dlouhý stisk, Hvězdička + další tlačítko (postupně), hvězdička + křížek + hvězdička (postupně))
Třetí položka: Kód spouštěcí klávesy v DEC. (V mém případě 0)
Třetí obrázek:
Třetí položka: Formát času (12/24 hodin)
Čtvrtá položka: Povolit při zamčené klávesnici
Pátá položka: Vstup do nastavení zkratek
Šestá položka: Vstup do nastavení informací o spuštěných procesech na hlavním displeji
Čtvrtý obrázek - Zkratky
Bohužel mi lze nastavovat pouze soubory, nikoli funkce (jako např. MESG_WRT_NEWEMS pro psaní nové zprávy). Ale lze spustit např. vestavěný Card explorer pomocí elfu CardExplorerExecuter, po jehož spuštění se prohlížeč souborů spustí.
Pátý obrázek - Nastavení zobrazování informací o spuštěných procesech na hlavním displeji
První položka: Zobrazovat informace na hlavním displeji
Druhá položka: Číslo ikonky ve FW, která se má zobrazovat
Třetí položka: Souřadnice čísla na hlavním displeji (počet spuštěných procesů)
Čtvrtá položka: Souřadnice ikonky
Pátá položka: Nevím
Poslední dvě položky: Barva čísla na hlavním dipleji (vnitřní a vnější)
Vyzkoušeno na CX70 FW56 Elf pack 2.3 CZ - funguje bezchybně - vřele doporučuji.
EDIT: Omlouvám se za nefunkční screen. Ale už ho nemám a nemám možnost ho udělat znovu...
Naposledy upravil simp dne čt duben 03, 2008 8:12 pm, celkově upraveno 1 krát
michalkopecky
13617.60 SMM
PříspěvekZaslal: st září 12, 2007 7:45 pm    Předmět: Odpovědět s citátem
DApp beta - nový elf od truhlik(a)
EDIT:
- MikeMaster:
Dokáže zobrazovat poznámky z kalendáře na mainscreenu... Avšak verze pro SGoldy není vyzkoušená a mě PXovala (i po změně fontu, jak je doporučeno)... Tak to můžete zkusit vy...
Jinak je verze i pro ELka a NewSgold - ty jsou 100% funkční...
Tyto informace jsou přímo od truhlíka, mluvil jsem s ním... Applause
- truhlik:
Verze se scrollovanim si nevsimejte. to je jen zabugovana ukazka, ktera ma spoustu nedodelku.
ted se soustredim na verzi 0.4. ta bude obsahovat podporu pro vsechny typy pripominek. skrolovani (se pokusim Wink ) pridam az do verze 0.5.
btw verze 0.4 rc1 uz je hotova, a az se mi ji podari hodit na net, tak ji muzete okostovat Very Happy
Mně ani Sefinkovi nePXoval.
Spojeno několik příspěvků do jednoho. simp
michalkopecky
13617.60 SMM
PříspěvekZaslal: po říjen 08, 2007 12:58 pm    Předmět: MC 1.0 Odpovědět s citátem
Konečně vyšel elf MC ve verzi 1.0!
MC 1.0 CX70 edition
Novinky:
- největšími změny prošlo přiřazování ikon - už se dají přiřadit adrsářům, souborům s určitým jménem a také nemusíte už přiřazovat pouze k obrázkům z firmwaru, ale i z disku
- s první změnou souvisí i nová adresářová struktura
Odstraněn nefunkční screen. ("Odkazování na obrázky z http://kopecky.unas.cz je zakázáno"). simp
//no jo, dělal jsem změnu na webu
Naposledy upravil michalkopecky dne so prosinec 29, 2007 10:37 pm, celkově upraveno 1 krát
braun21
Založen: 19. 03. 2006
324.74 SMM
PříspěvekZaslal: pá listopad 02, 2007 4:31 pm    Předmět: Odpovědět s citátem
Elf-Stopky.
Jsou to primitivní stopky,které ovšem nezobrazují milisekundy:(
Jde tam nastavit pozadí,barva a velikost čísel.
http://forum.allsiemens.com/download.php?id=75406
S65fw58
(Mým nejvěrnějším a přitom nenáviděnym přítelem je PX)
Založen: 27. 10. 2005
PříspěvekZaslal: ne březen 30, 2008 7:59 pm    Předmět: Odpovědět s citátem
MP3 Player 3.0 CZ
Arrow Download
Screeny:
PříspěvekZaslal: pá duben 04, 2008 6:47 pm    Předmět: MP3 Player 4.00 CZ Odpovědět s citátem
MP3 Player 4.00 CZ
Arrow Download
Screeny:
V archívu jeden skin (Amarok, další si musíte dodělat Very Happy ).
Řekl bych, že je stabilní než verze 3.0 (nePXuje mi s ním telefon), ale opět neumí rip do wavu.
Btw, co říkáte na můj vlastní skin? Patří do mého nového tuningu.
PříspěvekZaslal: st duben 09, 2008 1:12 pm    Předmět: XTask3 CZ a XTaskPluginManager CZ Odpovědět s citátem
XTask3 CZ
Arrow Download
Arrow Download
Fijo666
Založen: 20. 10. 2006
382.24 SMM
PříspěvekZaslal: po červen 16, 2008 7:15 am    Předmět: Odpovědět s citátem
DeskTop - "emulator" desktop
Nedokoncena verzia Mr. Green projekt bude este pokracovat Applause Mozno to raz nahradi Mainscreen. Applause
Download
Priecinok DeskTop nakopirovat do Zbin.
Ikony sa nastavuju pomocou icon.dt
SX45i + 32MB MMC
hotter
Založen: 04. 12. 2004
Telefon: M55
47266.46 SMM
PříspěvekZaslal: út červenec 27, 2010 6:19 pm    Předmět: Odpovědět s citátem
Explorer by Hotter - file explorer for SGold, like native card explorer Very Happy
Changelog:
v1.2
Mark/Unmark all added in one place
Option to create new file added
Move cursor while marking (set in 0:\ZBin\etc\Explorer.bcfg)
Show system files option (set in 0:\ZBin\etc\Explorer.bcfg)
Mark/unmark all with long press of softkey
Paste only appears only if you cut or copy something
Added Send to... Makes shortcut to apps/games folder.
v1.1
Search added
MMC support (set in 0:\ZBin\etc\Explorer.bcfg)
Apps and Games disable/enable added (set in 0:\ZBin\etc\Explorer.bcfg)
v1
created Explorer
Screenshot:
Icons not included! Edit 0:\ZBin\Explorer\icons.cfg yourself.
 Explorer_1.2.zip | Komentář:  | Soubor: Explorer_1.2.zip | Velikost: 12.96 kB | Staženo: 353 krát
N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb
Odpovědět na téma    Obsah fóra -> Elfy Časy uváděny v GMT + 1 hodina
Strana 14 z 15
