:: View topic - text info v1.2
text info v1.2
DarkLegion
1453.28 SMM
PostPosted: Thu Sep 13, 2007 12:01 pm    Post subject: text info v1.2 Reply with quote
ako mam pomocou .dat suboru nastavit toho elfa aby bol taky ako na tom obrazku Question
skusal som repisovat ten .dat subor ale som z toho jelen Brick wall
SIEMENS VEČNE ZIVÝ
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Thu Sep 13, 2007 12:19 pm    Post subject: Re: text info v1.2 Reply with quote
Poradim... vyskusaj novu verziu ide nastavovat cez *.bcfg subor ako ostatne elfy a je v nom pridanych kopa dalsich nastaveni, a ma aj podporu NewStyleDaemon's... wink
Arrow TextInfo SGold
Arrow TextInfo NewSGold
Arrow TextInfo Elka
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Thu Sep 13, 2007 12:22 pm    Post subject: Reply with quote
A ak sa ti to nechce nastavovat vsetko v tel tak zdlhavo... Tak spust v tel. ten elf, potom si nakopiruj nastavovaci subor TextInfo.bcfg do PC a vsetko potrebne si nastvav pomocou tohto programu: BCFG-Editor, uloz a naspat nakopiruj nastavovaci subor do tel. a uh ho len otvor a naspat uloz aby sa zmeny prejavili a musi to fachat...
DarkLegion
1453.28 SMM
PostPosted: Thu Sep 13, 2007 12:44 pm    Post subject: Reply with quote
dik..je to super..funguje to bezchybne Applause
SIEMENS VEČNE ZIVÝ
DarkLegion
1453.28 SMM
PostPosted: Thu Sep 13, 2007 1:11 pm    Post subject: Reply with quote
este mam otazku...na displeji mi nalavo pise 4126Kb a kusk nizssie zase 49%...co to je? da sa to vypnut?...povipinal som vsetko co suviselo nejak s CPU a RAM a stale to tam je...co to znamena ten vypis?
SIEMENS VEČNE ZIVÝ
Sefinko
elfmaster
elfmaster
6980.53 SMM
PostPosted: Thu Sep 13, 2007 2:20 pm    Post subject: Reply with quote
Tie percenta moze byt napr. kapacita baterie, a to 4126kb moze byt volne mieso na disku alebo take nieco, skus pozriet este raz... Urco to musi ist vypnut... wink
DarkLegion
1453.28 SMM
PostPosted: Thu Sep 13, 2007 2:28 pm    Post subject: Reply with quote
uz som to nasiel...je to volne miesto v telefone a na karte a zobrazuje sa v % aj v Kb Applause
SIEMENS VEČNE ZIVÝ
