:: Zobrazit téma - Balicek s multipatchem MIOv1.62 a navody. ENG: Basic package
Mio
Založen: 22. 11. 2004
10930.24 SMM
PříspěvekZaslal: st červenec 26, 2006 9:48 pm    Předmět: Balicek s multipatchem MIOv1.62 a navody. ENG: Basic package Odpovědět s citátem
Vzhledem k tomu ze se nekolika lidem libilo snadne pouziti meho multipatche pro SX1, doplnil jsem jej, aktualizoval a pridal doplnkove aplikace a jednoduche navody.
Obsah:
(Included:)
- Multipatch MIOv1.62 - Vsechny patche v jednom. Odladene. (All patches in one. Debuged.)
- Dimmer v 0.95 - Aplikace pro ovladani podsviceni atd. (Applicattion to control keyboard and display lighning)
- SX1Speed - Aplikace pro pretaktovani za chodu (App to control overclocking from phone)
- MsvDriveE - Presmeruje prichozi udalosti z C na E (Redirects incoming events(SMS, MMS, BT-files etc.) to E(MMC))
- flashsize.exe - Zjisti velikost pameti FLASH v telefonu (Inform about size of FLASH, if is posible increase drive C to 11,8 MB)
Pribalene mini navody:
(Included instructions:)
- Zmena zvuku budiku (How to change Alarm sound)
- Zmena/odstraneni zvuku fotaku (How to change/remove Camera sound)
- Zmena midi banky (How to change midi bank to increase gualiti of playing midi)
- Instalace Temat a zakladni soubory grafiky (How to use Themes)
- Navod na MsvDriveE (How to usem app MSVDRIVEE)
- Navod k flashsize.exe a pro pouziti patche na zvetseni C ma 11,8 MB (How to use app Flashsize.exe and posibly increase size C to 11,8MB)
Multipatch MIOv1.62:
- Obsahuje tyto patche http://mio.unas.cz/MIOv1.62.txt
(Have a look to ENG multipatch to see included patches - is different from CZ version)
- Obsahuje vsechny mozna vylepseni ktere SX1 nabizi krome Linuxu
(Includes all posible improves without Linux)
- U kazdeho patche je vystizny popis a patch lze "Vypnout" zakomentovanim (pridanim ; pred replace...)
(Any patch is posible to switch off(switch on) adding semicolon before word replace (remove semicolon before replace will switch on the line))
Vysledek je zde.
(Download here.)
http://mio.unas.cz/Package_SX1_MIOv1.62.zip
http://mio.unas.cz/Package_SX1_MIOv1.62_ENG.zip - fist version done, sory for that English and mistakes
Zname problemy a nedostatky:
(Found problems or errors)
- doposud zadne zjistene
(nothing found)
Cely balicek je otestovan na mych dvou SX1 s MMC Kingston a Pretec.
Pri jakychkoli problemech piste na ICQ: 177192494 nebo skype: mio_cz
Predem upozornuju ze je NUTNE si precist nejprve vsechny navody a prostudovat uvedene odkazy, jinak mi ani nezkousejte psat.
(Whole package is tested on my 2 pieces of SX1, firmware V 15 CZ, should posibly work on all FW15 versions. If any problem, fist read again all instructions, if no solution found contact me on ICQ: 177192494)
UPDATE:
v1.41 - pridana aplikace MsvDriveE a navod k MsvDriveE
v1.5
- odebran nefunkcni patch,
-pozmenen zpusob nahravani viz. Navod.txt kvuli odstraneni sekani po vyndani MMC za chodu.
- opravena chyba v navodu na odstraneni zvuku fotaku, cesta je E:/System/Sounds/Digital
v1.51 - pridany pathe Urychleni pretaceni v MP3 prehravaci a Zachovani seznamu udalosni pri vymene SIM, drobne upravy
v1.52
- odstranen nefunkcni patch na presunuti Radio.cfg na disk E
- vypnut patch na zvetseni rozsahu ladeni radia a pridany instrukce pro ty kdo si jej zapnou(primo v multipatchi)
- restrukturalizace patche do 3 bloku, Softwarove, Dulezite pro temata, Hardwarove(jsou to jen nazvy, berte to s rezervou)
v1.60
- pridan patch na zvetseni disku C na 11,8 MB + flashsize.exe + navod - standartne patch vypnuty
- odstranen nefunkcni patch presunuti Nokia/Installs na D (Instalacni cache do RAM)
v1.61
- opraveny chyby v multipatchi, konkretne odstranena cast patche pro restart po dlouhem stisku vypinaciho tlacitka, a pridana chybejici cast patche na opravu chyb grafiky pri pretaktovani
- vracen patch Nokia/Installs presun na disk D nebot sice se ridi limitem velikosti volneho mista na C, ale presto urychluje nahravani
- Opraven navod na pouziti vlastni midi banky
v1.62
- pridana aplikace PhoneInfo zobrazujici skutecny takt procesoru
- zadne vyrazne zmeny v multipatchi, netreba zbytecne prehravat !!!
N95-8GB
Naposledy upravil Mio dne čt září 14, 2006 6:38 pm, celkově upraveno 29 krát
Mio
10930.24 SMM
PříspěvekZaslal: ne červenec 30, 2006 12:53 pm    Předmět: Odpovědět s citátem
REDATE pro multipatch do 1.51 vcetne: Kdo by mel problemy s aplikaci Radio, ze se mu sama zavira pri spusteni, resenim je smazani C:/System/Apps/Radio/Radio.cfg a restart telefonu, pred dalsim spustenim aplikace Radio nejprve pripojte antenu a po spusteni naladte alespon jednu stanici, problem se pak uz nebude opakovat.
RESENI PROBLEMU:
(Problem solutions:)
Dalsi drobna chybicka nalezena: Pokud mate cistou MMC
(naformatovanou v PC) je potreba na ni vytvorit nasledujici adresare:
(Create theese folders on MMC formated in PC will solve some problems)
System
System/Data
System/Install
Tyto slozky je potreba vytvorit pokud MMC kartu formatujeme v PC.
(I you format MMC in phone, phone creates these folder itself after format )
SX1 si je pri formatovani v telefonu vytvori sama.
Novy Problem !!!
Vyskytl se problem zamrzani telefonu ve chvili kdy ma vyjet pozadavek na PIN kdyz neni vlozena SIM s pozadavkem na PIN kod. Vyskytuje se pouze neprodlene po nahrani noveho patchovaneho FW a formatu C.
Problem je zpusoben patchem na zachovani seznamu volani pri vymene SIM, tento patch bude v pristi verzi multipatche implicitne vypnut.
Reseni:
1. po flashovani nebo formatu zapnout telefon se SIM se zapnutym pozadavkem na PIN, staci poprve, vytvori se tim potrebna konfigurace a dal uz to nebude delat problemy
2. vypnout tento patch v multipatchi.
N95-8GB
Naposledy upravil Mio dne st září 06, 2006 5:14 pm, celkově upraveno 2 krát
tomas.smetka
Založen: 22. 01. 2007
268.50 SMM
PříspěvekZaslal: út říjen 09, 2007 4:26 pm    Předmět: Odpovědět s citátem
Nahodou v tom souboru mio162.sxp (patchi) neni integrovan patche E:/ before Z:/ ?
Koukal jsem na to a ikony signalu a baterie to sosa z karty, ale nevim jka u ostatnich mbm souboru...
FIDES | AGAPE | FORTIS | VERITAS- LÁSKA VÍRA SÍLA PRAVDA
M75 (Dead) -> Nokia 6101 -> SexyOne
dangerelectronic
Založen: 02. 01. 2007
413.06 SMM
PříspěvekZaslal: út říjen 09, 2007 4:48 pm    Předmět: Odpovědět s citátem
tomas.smetka napsal:
Z karty idu vsetky graf. subory potrebne na start telefonu (ked ich tam nemas tak idu zo Z:/) - to jest subory hornej listy, pozadia, ikony menu, fonty, etc. (myslim si ze skratka bootuje vsetky subory najprv z karty a az potom z telefonu ak na karte nie su - ma to predsa nazov E:/ before Z:/)
C35i => [Funkcny]
Nokia E51
