:: Zobrazit téma - clear fw after sw update
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
hungeri
Založen: 21. 02. 2005
PříspěvekZaslal: ne leden 13, 2008 10:53 pm    Předmět: clear fw after sw update Odpovědět s citátem
Hi Guys,
I search the net since 3 days but I simply can't get the 'clear fw after sw update' patch for my C75. I've found only the x65 version, but of course it doesn't work, and there is a result file called 'clear_0006.bin'. I tried to flash this with V-Klay, but after flashing no answer from the phone. Maybe I started from wrong address??
Basically, why do I need this? I installed some patches to the phone, after this some freezes were occured and, in the *#06# menu, after pushing 'more' button the phone freezes. I tried to undo all the applied patches, but no result, after that tried with winswup, but still no result. My other option, that I have some C75 full backups, but unfortunately not with this IMEI. EEPROM Tools won't read out any EEPROM block, so that I didn't try to write an other fubu...
Do You have any suggestion?
Thx in advance!
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
