:: Zobrazit téma - drivers sl55
drivers sl55
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
rotar
Založen: 02. 09. 2010
88.54 SMM
PříspěvekZaslal: st leden 26, 2011 9:12 am    Předmět: drivers sl55 Odpovědět s citátem
hi guys...
i need drivers for sl55...my pc does not recognise phone when i try to upgrade firmware by winswup...
thanx in advance
Založen: 09. 11. 2004
14311.82 SMM
PříspěvekZaslal: st leden 26, 2011 10:38 am    Předmět: Odpovědět s citátem
I recommend drivers from here Arrow http://www.siemensmania.cz/drivery.php
or after instalation Mobil Phone Manager there are drivers on PC.
I hope you a service cable (DCA-510 or kompatible) Angel
rotar
88.54 SMM
PříspěvekZaslal: st leden 26, 2011 11:09 am    Předmět: Odpovědět s citátem
stano.mania napsal:
thanx very much fella...yes i have dca-510 ..
i tried now with winswup and firmware 20..
"error on waiting for ack eot"
something gone wrong
Založen: 01. 04. 2008
15518.64 SMM
PříspěvekZaslal: st leden 26, 2011 11:57 am    Předmět: Odpovědět s citátem
Hello rotar, have a look on settings at winswup and device manager, if you have well configurated port where your cable is connected... if is it correct... This may be the reason why it can not find the phone...
rotar
88.54 SMM
PříspěvekZaslal: st leden 26, 2011 12:52 pm    Předmět: Odpovědět s citátem
rattle-snake napsal:
ok rattle snake... :-)
now i check the port and let you know..
EDIT: thanks rattle-snake...i finally made it...there was a problem with the port..winswup was using number 4 instead of number 3..both ports were checked but the right one was 3...
now my sl55 is working with svn20...
thanks very much indeed
15518.64 SMM
PříspěvekZaslal: čt leden 27, 2011 9:34 am    Předmět: Odpovědět s citátem
Yeeeaaaah Applause I am very pleasured that your SL55 is running again and that I could help someone Very Happy
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
