:: View topic - SPC2 ???
SPC2 ???
PostPosted: Fri Dec 03, 2004 3:26 pm    Post subject: SPC2 ??? Reply with quote
MAM TAKY MALY PROBLEM S PROGRAMOM SPC2. KED HO OTVORIM A DAM OTVORIT FULLFLASH TAK JU OTVORI ALE HNED ZAMRZNE A NEDA SA NIč S NIM ROBIť IBA ZRUšIT A AJ TO S PROBLEMAMY. DOTERAZ MI IšIEL ALE ZRAZU NEJDE. NEVIETE PORADIT čO S TYM?? Brick wall
Stefi
PostPosted: Fri Dec 03, 2004 3:39 pm    Post subject: Reply with quote
A proc nezkusis SPC3 Question
Zadny uceny z nebe nespadl
N5110=>N3310=>N3310blue light => Bosch GSM-COM607=>N3210=>CX65-Fw12=>Fw16=>Fw12=>Fw16=>FW25
PostPosted: Fri Dec 03, 2004 3:53 pm    Post subject: Reply with quote
SPC3 SA MI ZDA DOST KOMPLIKOVANY, KED MUSIM TUKAT NA KAžDY JEDEN OBRAZOK ATD. JE ZLOžITEJšI AKO SPC2 A JA MAM M55 TAKžEHO NEPOTREBUJEM ZATIAL.
PostPosted: Mon Dec 06, 2004 7:41 am    Post subject: Reply with quote
problem je v tom,ze v SPC2 uz neotvoris FF modelov x65 a ani niektorych x60..takze odporucam SPC3.
PostPosted: Sun Jan 30, 2005 7:19 pm    Post subject: Reply with quote
A aku farbu tam mam pouzit aby to bolo transparentne? Stale to mam sede ked daco zmenim. Bodlo by cislo tej farby. Brick wall
PostPosted: Mon Jan 31, 2005 8:11 am    Post subject: Reply with quote
Uz dnes bude na stranke clanok,kde sa vsetko docitas.
