:: View topic - A50 a patch
A50 a patch
Goto page Previous  1, 2
Reply to topic     Forum Index -> x62 a starší řady -> x50
mirrco
PostPosted: Fri Jun 24, 2005 12:52 am    Post subject: Reply with quote
mirrco wrote:
Potreboval by som info ako patchnut a50 a to firmware 11 a 12, neak to nejde a ked pouzijem akykolvek patch funguje ale len 10 min a potom vypne...ale vo verzii FW 10 slape vsetko ako ma.takze patchovat ide zatial FW v10.Ale to su len 4 patche. FV v11 a v12 zrusenie CRC nepomoze, pretoze tie maju zrusenie CRC na inej adrese ako u verzie FW v10 .neviem asi si tak myslim, ale rad by som pouzil patch "tunning C45"ktory fungje len na FW v12.Akurat ze sa tel vypne... Brick wall
Ale teraz to uz ide OK s mojim patchom na zrusenie CRC fo fakci v poho vsetko naczdy...
antoine
PostPosted: Sun Sep 25, 2005 11:48 pm    Post subject: Reply with quote
hmm, zakladny patch - disable CRC Razz
kill_me604
PostPosted: Wed Nov 02, 2005 2:28 pm    Post subject: Reply with quote
Tak nekdo zkuste vytahnout cestinu z FW 11 a dat ji do FW 12. Faka to, uz sem to delal na trech founech a je to OK.
http://siemensmania.cz/download.php?file=/software/SST_5.38_cracked.zip
Reply to topic     Forum Index -> x62 a starší řady -> x50 All times are GMT + 1 Hour
Page 2 of 2
