:: View topic - Zmena M65 na CX70 ci CX65
PostPosted: Sun Jan 15, 2006 1:54 pm    Post subject: Reply with quote
Pre zmenu v patchi dyn. provider skús pomeniť znaky podľa tabulky hneď v prvom riadku (myslím tie nastvenia v java aplikácii).
Ten patch čo si hľadal som na Sm fakt nevidel ani ja. Preto ti ho sem postnem.
Neviem aké zväčšenie pamäte si použil, ale kombináciu s master patchom je špeciálna verzia. Smile
A len pre info, master patch je aj na M65v50, takže ak si prechádzal len preto bolo to zbytočné.
Code:
;CX70v56
;Talking Phone
;Talking Phone
;(c) avkiev
;(r) avkiev
;(p) me-at
;Version: 3-MP
;PatchID: 1140
;Details: http://patches.kibab.com/patches/details.php5?id=1140
;1. Shortcut
09436C0: "ELSE_COUNT_DOWN",00,A3F98EA0 "ELSE_COUNT_DOWN",00,0xA0FC3001 ;  CX70v56 - ELSE_COUNT_DOWN
;0943A68: "ELSE_REMOTESYNC",00,510CFCA0 "ELSE_REMOTESYNC",00,0xA0FC3001 ;  CX70v56 - ELSE_REMOTESYNC
;0943A00: "ELSE_PUSHTOTALK",00,CD038FA0 "ELSE_PUSHTOTALK",00,0xA0FC3001 ;  CX70v56 - ELSE_PUSHTOTALK
;2. Alarm
;Spell time instead of Alarm (doesn't work if phone is off)
0ACC4A4: 0F2098F666E93080 00488047,0xA0FC30A7   ;cx70v56
0FC30D4: 20 30
#pragma enable old_equal_ff
0FC3000: FFB57048FDF7FCFD4CD020210902F068
0FC3010: 884229D0F160301C1430306118307061
0FC3020: 0020311C2E31321C76320B8813800130
0FC3030: 02310232002BF8D10138B0850638311C
0FC3040: 743108803167311CA031301CB030C860
0FC3050: 062008822E20C8827720088361204883
0FC3060: 76208883012008840020311DFCF7C8FF
0FC3070: 341CCC340025632000F05CF83179B078
0FC3080: 002803D13C2700F02AF801E000F04EF8
0FC3090: 7179002903D1622000F04CF802E04627
0FC30A0: 00F01DF8FFBD7EB5FDF73AFBF878A828
0FC30B0: 01D0002005E04348FDF7A2FD01D07078
0FC30C0: 00287EBC03D10F20FDF766F802E00F20
0FC30D0: FFF796FF2080012080BC0437384700B5
0FC30E0: 14290CD30A2080B4FCF79AFF80BC4200
0FC30F0: C000801800F01EF80520002912D0081C
0FC3100: 01290AD0022908D000F014F805200029
0FC3110: 08D0052906D2022004E0C019143000F0
0FC3120: 09F8081CC01900F005F800BD00B53D20
0FC3130: A027F4E782B52060201D291C0FA20132
0FC3140: FDF792F821680A20FCF76AFF30303031
0FC3150: B28D52002232B0520232B152301C0C30
0FC3160: FDF762F8716A88000918091809183C20
0FC3170: FCF756FF2D180C3482BDC046FCB51148
0FC3180: FDF73EFD1AD0FF20341CC0340C342168
0FC3190: 8142FBD020600A20FCF742FF30303031
0FC31A0: 321CAC32D0801181A7200090311CC031
0FC31B0: 01910C2050390023FDF74AF8FCBD
0FC31C0: 0xB1C2D3E4,0x0000AB05,0000000000000000,"\
{patch=TalkingPhone ver=3 cp=avkiev id=AB05 mem=288}\
{1 cb UseAsAlarm v=1}\
{2 o Language `Russian`=0 `Polish`=1}\
{46 u WAVs maxlen=32 v=`0:\\Sounds\\Time\\xx.wav`}",00
#pragma disable old_equal_ff
cyber-j
mecenáš
mecenáš
3.28 SMM
Příspěvky na SM: 1460,-
PostPosted: Tue Jan 17, 2006 8:14 pm    Post subject: Reply with quote
[/code]
Dik, uz mi to fachci, Dyn providera aj GPS patch som si stiahol najnovsie verzie a ide to OK. Za ten Talking phone tiez vdaka, ale medzitym som niekde zohnal verziu 3. Ten M65@CX70 som robil len kvoli imidzu, mam rad experimenty. Ten phone pilot standard, tie kocky mi uz zopar ludi zavidi. Do konca mesiaca mam v plane prerobit dve CX65, ludia uz otravuju, len cakam na koniec skuskoveho obdobia na VS. Potom dam vediet, ako som dopadol, na ake zaludnosti som narazil.
M35->ME45i -> M65@CX70 -> M75 ->
Utano Barrier T180 -> Cat B15
dubacik22
67.00 SMM
PostPosted: Tue Jan 31, 2006 2:44 pm    Post subject: Reply with quote
a co stratim keby som si z cx65-ky spravil m65-ku. Ha???
Moc sa v tom neviznam ale asi nic. Len co mi na m65-ke pri prehravani melodii bude podla intenzity zvuku blikat dinamic light.
PostPosted: Tue Jan 31, 2006 4:15 pm    Post subject: Reply with quote
Dynamické led blikajú aj na M65 do rytmu. Záleží na fw, nie na modely.
Zmenou myslím nestratíš nič.
kodein
PostPosted: Sun Feb 26, 2006 4:13 pm    Post subject: Reply with quote
Mam takovy asi blby dotaz..... Chtel jsem se zeptat, jestli je mozné pridat walki talki do m65ky, aniž by se musel měnit nazev a firmware?
Šlo by jenom nahrat určité bloky epprom do m65 z cx75?
PostPosted: Sun Feb 26, 2006 6:33 pm    Post subject: Reply with quote
Nie,takto to nepojde.
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Tue Feb 28, 2006 3:28 pm    Post subject: Reply with quote
a ptt pro s65 fakt není? Sad
imothep
PostPosted: Fri Mar 03, 2006 6:40 pm    Post subject: M65 na CX65 a CX70 Reply with quote
Hele lidi muzu vedet vcem jsou tyto tel lepsi nez M65?diky
a12a
3074.50 SMM
PostPosted: Tue May 09, 2006 8:18 pm    Post subject: Reply with quote
kdyz chci zmenit M65 na CX65 tak musim mob prejmenovat? bez toho by to neslo? d'oh!
nebo to prejmenovani je jen pro "poradek"
Palio
veterán
veterán
PostPosted: Mon May 29, 2006 1:58 pm    Post subject: Reply with quote
Musis.
SGS2
DavidT
PostPosted: Mon May 29, 2006 2:05 pm    Post subject: Reply with quote
No ono by ti to nepřehrálo FW protože by zahlasilo že nemáš FW ten druh mobilu.A když to přejmenuješ po přehrátí tak zase ti nepůjde GPRS.
S: C65>M75 >Sony Ericsson P1i
Firmware:13
Operátor: Vodafone
Kabel: DCA-510
Stav telefonu: OK
Karta: RS-MMC DV 1024 MB
dubacik22
67.00 SMM
PostPosted: Fri Jun 02, 2006 9:59 am    Post subject: Reply with quote
tak laicky sa opýtam: ked na telefone spravim TP a nahram tan FF ineho modelu(CX65=>M65 aj so zapisom do Boot core)tak mi to prepise komplet software telefomu?
ak hej, takpreco musim aplikovat vselijake tie patche. Vsak CX65 a M65 je to iste, lem v inom obale. Ja som to uz davnejsie vyskusal, lebo mam CX-kovu dosku v M-kovom kryte, tak som chcel, by som mal M-ko ako sa patri. ale ono to nic. Pcas nahravania M-koveho FF sa tp vyplo. Vraj loader not entry alebo co. A to som mal loader od papui ze V_klay*_*-TP.vkl ci co. potom som to horko tazko zbuchal do povodneho stavu. Odvtedy mi to akosi vrta v hlave. Ak viete vysvetlite.......
a12a
3074.50 SMM
PostPosted: Wed Oct 18, 2006 8:59 pm    Post subject: Reply with quote
no taxem se dozvedel ze jdou na M65 elf patchy, takze davam zpatky z CX65 na M65.. ale jak na to??
mam zrusit patch
Code:
1225A70: 0E 00
1184DC8: 000053E1 030053E1
pak prejmenovat tel a pak nahrat M65 FW ??? prosim poradte
M65@CX65, FW50
a12a
3074.50 SMM
PostPosted: Sat Oct 21, 2006 11:17 am    Post subject: Reply with quote
Eh? poradite mi nekdo pls? Pray
M65@CX65, FW50
alkaba
10903.00 SMM
PostPosted: Sat Oct 21, 2006 11:18 am    Post subject: Reply with quote
Přejmenuj telefon na M65 a potom nahrej FW50 pro M65 wink
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
Page 4 of 6
