:: View topic - El71 a Skey - ako to vyzera...
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
bojler
300016.12 SMM
PostPosted: Sun Nov 26, 2006 11:36 pm    Post subject: Reply with quote
mam v telefonu 41ku, loader sem vytvoril, fullflash vytvoril, ale sKEY vlozit nejde. viz. topic http://www.siemensmania.cz/forum/viewtopic.php?t=27435
2002 C35i -> 2003 C55v24 -> 2004 S55v20 -> 2005 S65v58 -> 2006 EL71v38 -> 2007 EL71v45 + S65v58 -> 2008 EL71v45 + S65v58 -> 2009 EL71v45 -> 2010 EL71v45 patches revival -> 2013 dualSIM a konec Siemensu
yoyanec
PostPosted: Sun Nov 26, 2006 11:38 pm    Post subject: Reply with quote
no na to upozornoval aj 1nvisible...ak najdem na to ruskom fore sposom ako pomoct, dam vediet
Ericsson GA-628 -> 688 -> T10 -> Nokia 5110 -> 3210 -> 3310 -> 6510 -> 3510i+cable + Siemens A50 -> CX65@CX70 + DCA-510 ->EL71+1GB Kingstone + DCA-510@DCA-110
bojler
300016.12 SMM
PostPosted: Sun Nov 26, 2006 11:40 pm    Post subject: Reply with quote
pruser je v tom, ze sem byl moc rychlej...
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Sun Nov 26, 2006 11:41 pm    Post subject: Reply with quote
Pri pokuse nacitat vo vklay FF mi napise:
Quote:
An unknown error occured while accessing COM6
Loader not ready!
V com moze byt chyba?
>Daruj krv<
bojler
300016.12 SMM
PostPosted: Sun Nov 26, 2006 11:42 pm    Post subject: Reply with quote
mozna operatorova customizace
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Sun Nov 26, 2006 11:53 pm    Post subject: Reply with quote
Brick wall No obavam sa ze mas pravdu Crying or Very sad . Ak sa to nebude dat obist tak ho asi predam Crying or Very sad Evil or Very Mad
Mohol by mi niekto poslat necustomizovany disk Config?
>Daruj krv<
yoyanec
PostPosted: Mon Nov 27, 2006 12:03 am    Post subject: Reply with quote
ak by niekto potreboval prelozil som vam navod, ktory je prilozeny k x65hlasheru:
Volny preklad:
Aby bol Vas telefon "viditelny" pre flasher, potrebujete vediet SKEY alebo BOOTKEY. Su tri metody, ako ich ziskat.
1. Pouzitie midletu (bsReader alebo px75v1).
Nakopirujte midlet bsReader do priecinka s Aplikaciami v telefone (pre S75/SL75 a telefony BenQ-Siemens) alebo px75v1 do Java\Jam\Aplications(pre ostatne modely), potom spustite midlet z polozky menu Aplikacie. Po 5-15 minutach vam midlet ukaze HASH a ESN.
Pustite flasher, vyberte "Keys" -> "Calculate SKEY and BOOTKEY", vlozte opis telefonu(Description), HASH a ESN. Vypocet trva obvikle do 10 minut. Program tiez vygeneruje loader pre V_Klay, nakopirujte ho do <cesta_ku_Vklay>\data\loaders. Potom vyberte COM-port a tiez rychlost a opis vasho telefonu(Description), a stlacte "Connect".
Ak si zelate, mozete vlozit SKEY do telefonu("Keys" -> "Enter SKEY")
O aplikacii bsReader a px71v1: vyuzivaju chybu v jave, aby mohli citat priamo v pamati telefonu. Aplikacia nefunguje vzdy stabilne, niekedy spadne, niekedy vygeneruje Exception, niekedy vypne telefon. Ak sa vam nepodari vygenerovat kody na prvy krat, skuste to znova. Raz bude tato chyba opravena. Ak aplikacia generuje rovnaku Exception stale, pravdepodobne bola tato chyba opravena. Tak skuste metodu 2 alebo 3.
2. Ak uz mate SKEY pre vas telefon, vyberte "Keys" -> "Enter SKEY". Po vlozeni tohto kluca, bude flasher normalne pracovat bez dalsich potrebnych akcii.
3. Ak nepoznate SKEY a midlet nefunguje, jedina varianta je testpoint. Obrazky testpintov pre vela typov telefonov, mozete najst na http://allsiemens.com/testpoints. Testpoint sa musi skratovat na zem cez 10-50 ohmovy odpor. Mozete pouzit nejaky kovovy predmet, ale s obrovskou opatrnostou, pretoze skratovanie zleho bodu plosneho spoja moze poskodit telefon. Vyberte "Testpoint", ako metodu bootovania vo flasheri, potom stlacte "Connect", potom skratujte testpoint, stlavte cervene tlacitko a podrzte tespoint asi 3 sekundy. Teraz mozete vybrat "Keys" -> "Calculate SKEY and BOOTKEY" (HASH a ESN su uz precitane z telefonu)
krtek.cz
PostPosted: Mon Nov 27, 2006 12:13 am    Post subject: Reply with quote
A fungujeto i s kablem DCA-140????
Siemens CX70 fw 56 --> EL 71 fw 38
yoyanec
Flasher can work with a phone only through a COM-cable or USB-cable with the USB-to-COM converter. A cable that goes in the package - DCA-540, it is clean USB-cable, flasher doesn't work with it. Most Chinese USB-cables work without problems. A simple test: cable must be recognized by a computer, even if a phone is not connected. Also in USB-to-COM cables you can see a small box in the middle of a cable. In the case of COM-cable, the power must go from the COM-port (you cannot check this by look).
Original cables DCA-510, DCA-512 does work; DCA-500, DCA-540 doesn't.
You cannot work with flasher via IRDA or bluetooth.
takze nie...
krtek.cz
PostPosted: Mon Nov 27, 2006 12:21 am    Post subject: Reply with quote
dekuju...je to skoda no nic jdu budu si muset koupit servisni kabl Crying or Very sad
Drobcek9056
7860.92 SMM
PostPosted: Mon Nov 27, 2006 9:43 am    Post subject: Reply with quote
nehodi tu niekto spravny zapis ESN pre x65Flasher a Papuu?Akosi to neviem najst.
EDIT : tak uz som to nasiel :
ESN : ABCDEF12
PapuaUtils : 12EFCDAB
x65Flasher : ABCDEF12
Skusal niekto ci po zavedeni SKEY idu otvorit uz aj skryte disky?
momentalne SL55 Smile
bojler
300016.12 SMM
PostPosted: Mon Nov 27, 2006 10:33 am    Post subject: Reply with quote
nechcu nejak spamovat. ale potreboval bych, kdyby mne nekdo poslal zalohu fw do x65flasheru, winswup verzi 38ky nebo 31ky (nevytvorenou smeltrem) nebo jakkoli pomohl s naladavanim downgradu do telefonu. bojim se bojim, aby to vubec slo.
Mispulin
PostPosted: Mon Nov 27, 2006 11:09 am    Post subject: Reply with quote
A ta winswup verze 31ky tady na SM ti nefunguje? Moc rád bych ti pomohl, jenže má EL71ka se i se servisním káblem zatím krčí ve skříni a čeká na ježiška. wink
bojler
300016.12 SMM
PostPosted: Mon Nov 27, 2006 11:12 am    Post subject: Reply with quote
nejde mne stahnout.
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Mon Nov 27, 2006 3:07 pm    Post subject: Reply with quote
Skusal som. Disky su otvorene Smile
>Daruj krv<
Page 4 of 7
