joshuacarr kolemjdoucí
Založen: 17. 04. 2005 Příspěvky: 1
Zaslal: út duben 19, 2005 3:48 am Předmět: Transforming an S66 into an S65? |
Hi there! Sorry for the post in English, but is it possible to flash an S66 and transform it into an S65? The S65 seems to be a much better telephone. I have tried using the V-Klay 3.x boot patch, but it does not respond with an S66.
Thank you!
thrasher začátečník
 Založen: 16. 01. 2005 Příspěvky: 53
Zaslal: út duben 19, 2005 12:24 pm Předmět: Re: Transforming an S66 into an S65? |
joshuacarr napsal: | Hi there! Sorry for the post in English, but is it possible to flash an S66 and transform it into an S65? The S65 seems to be a much better telephone. I have tried using the V-Klay 3.x boot patch, but it does not respond with an S66.
Thank you!
Yes, it is possible. I have an S66 myself and have successfully flashed someone else's fullflash with firmware 43 and I unlocked the phone by flashing my original EEPROM. I've done this in x65flasher. But first of all make a backup of your fullflash and EEPROM, because you will need your original EEPROM and you should always have a fullflash backup just in case something goes wrong. To backup fullflash I use "Read Flash", not Backup... but I suppose either one is fine. _________________ S66 FW58
Motorola SLVR L7
Nokia 3300 |
BEZY čestný člen
81.16 SMM
Zaslal: út duben 19, 2005 1:37 pm Předmět: Re: Transforming an S66 into an S65? |
joshuacarr napsal: | I have tried using the V-Klay 3.x boot patch, but it does not respond with an S66.
Do you have patched bootcore or generated loader? _________________ C35i -> M35i -> M50 -> CX65 -> SX1McLaren -> SXG75 -> HTC HD
http://www.bezysoftware.net
Brew Mobile Commander 2.0 |
Anonymní
Zaslal: po květen 02, 2005 7:40 am Předmět: Re: Transforming an S66 into an S65? |
BEZY napsal: | joshuacarr napsal: | I have tried using the V-Klay 3.x boot patch, but it does not respond with an S66.
Do you have patched bootcore or generated loader? |
I have patched bootcore. Sorry it took me so long to reply! |
