:: View topic - potrebujem radu...
potrebujem radu...
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x65, x70
shadowkiller369
PostPosted: Thu May 19, 2005 4:55 pm    Post subject: potrebujem radu... Reply with quote
mate niekto skusenosti s mh media player???ja ho mam...je v celku dobry ale dal som si do mobnilu mp3(mal by ju podporovat ten prehravac)...rozozna ju v playliste a aj ukaze ikonu mp3 ale mi ju neprehra...skusal to niekto_???
vbvbvb
PostPosted: Thu May 19, 2005 4:58 pm    Post subject: Reply with quote
mp3 ti to neprehra. Bolo to tu milionkrat. na x65 mp3 NEPOJDU. aspon zatial Rolling Eyes
shadowkiller369
PostPosted: Thu May 19, 2005 5:03 pm    Post subject: Reply with quote
ale cez ten prehravac by mali ist...
cooler5
3061.00 SMM
PostPosted: Thu May 19, 2005 5:07 pm    Post subject: Reply with quote
NEIDÚÚÚÚÚÚ!!!! Miliónpäťstokrát vyriešené!!!!! CX65 nepodporuje Mp3.
vbvbvb
PostPosted: Thu May 19, 2005 5:08 pm    Post subject: Reply with quote
tak ked ti pojdu tak to sem napis
NEPOJDU. Ten prehravac neinstaluje nijaky kodek ani nic len prehrava podporovane subory a x65 mp3 nepodporuje
shadowkiller369
PostPosted: Thu May 19, 2005 5:10 pm    Post subject: Reply with quote
takze keby sa to dalo na nejaky co ich prehrava tak by to slo???
shadowkiller369
PostPosted: Thu May 19, 2005 5:12 pm    Post subject: Reply with quote
a este nieco...co je nove na fw 50?ked som ho skusal tak tam dol novy patch na audio-9..to znamena ze pojdu wavka v lepsiej kvalite???inac do noveho fw by mohli dat podporu mp3...
vbvbvb
PostPosted: Thu May 19, 2005 5:13 pm    Post subject: Reply with quote
http://www.siemensmania.cz/forum/viewtopic.php?t=6871&highlight=mh+player
http://www.siemensmania.cz/forum/viewtopic.php?t=10972&highlight=mp3
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x65, x70 All times are GMT + 1 Hour
