:: View topic - JAVA hry na sl45i - HELP
Goto page 1, 2  Next
Reply to topic     Forum Index -> x62 a starší řady -> x45
ladislav.olsak
PostPosted: Mon Jun 27, 2005 5:51 pm    Post subject: JAVA hry na sl45i - HELP Reply with quote
Zravim potreboval bych poradit. jak mam spustit java hry na sl45i? ty soubory maji koncovku .jar vubec nefim co s tim:) HELP!
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Mon Jun 27, 2005 6:55 pm    Post subject: Reply with quote
JAR a JAD soubory nakopiruj do MMC:\Java\Jam\JmenoHry\
a pak v menu Surf.&Zábava vyber Java a tam to budes mit wink
Koupím Siemens, který nemám.
Seten
3061.00 SMM
PostPosted: Thu Jun 30, 2005 1:37 pm    Post subject: Reply with quote
Neviem isto ci to musi byt ale niektore hry mi isli len vtedy ked subor x1x1x.jar a x1x1x.jad bol v priecinku x1x1x. (x1x1x -priklad mena)
SX1 , SL45i, SL45i.
Guest
PostPosted: Fri Jul 01, 2005 5:55 pm    Post subject: Reply with quote
ja nemam v surf a zabava slozku java nemam a uz sem to zkousel a ani ve hrach se mi ta hra co chci neobjevi:( HELP
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Fri Jul 01, 2005 6:20 pm    Post subject: Reply with quote
tak to nemas SL45i
Seten
3061.00 SMM
PostPosted: Fri Jul 01, 2005 7:07 pm    Post subject: Reply with quote
Len tak aky mas firmware?
Lebo na starom firmware neukazovalo javu ale iba nejake hry, ktore pripominali javu.
SX1 , SL45i, SL45i.
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Fri Jul 01, 2005 7:33 pm    Post subject: Reply with quote
SL45i je tusim od fw42 vyse. Pri preflashovani z SL42 nebo SL45 na SL45i se muselo jeste nejakym aktivatorem zprovoznit javu. Pak to je SL45i (ale jenom SW wink )
ladislav.olsak
PostPosted: Thu Jul 07, 2005 6:50 pm    Post subject: Reply with quote
proste sem v prdeli a java hry na sl45i asi nikdy nerozjedu:(
Seten
3061.00 SMM
PostPosted: Thu Jul 07, 2005 6:56 pm    Post subject: Reply with quote
Ak mas dokovaciu stanicu tak skus podla nejakeho navodu si to prerobit. Ak nie a moc sa vtom nevyznas tak servis(bazar). Alebo skus znamych. prpadne si vyrob kabel.
SX1 , SL45i, SL45i.
nezn
Guest
PostPosted: Mon Jul 11, 2005 3:51 pm    Post subject: povolení javy Reply with quote
mohli byste sem dát link na návod na odblokování javy, nebo aspon odkaz na nejaký java enabler?
Seten
3061.00 SMM
PostPosted: Mon Jul 11, 2005 3:56 pm    Post subject: Re: povolení javy Reply with quote
Nechcem byt hruby, ale toto by som bral ako drzost. V downloads je nato program a uz aj keby tam nebol tak sa opytam pana Googla.
SX1 , SL45i, SL45i.
Guest
PostPosted: Mon Jul 11, 2005 4:37 pm    Post subject: Reply with quote
tak to se ti teda omlouvám, ale pan google mi vyhodil akorát tunu ruskejch stránek a jeden java enabler kterej se nedokáže ani za zlatý prase spojit s telefonem. je to asi týden co sem na seznamu našel kompletní česky psanej návod na odblokování javy, ale dneska po asi 2hodinovým hledání sem ho nenašel....no holt když člověk něco nehledá tak se mu to samo nabízí, ale když to hledá tak najít nemůže Smile
Guest
PostPosted: Mon Jul 11, 2005 4:42 pm    Post subject: Reply with quote
jo a ten co je v downloadsech je ten co už mám akorát v němčině :-)
SetenI
Guest
PostPosted: Mon Jul 11, 2005 7:13 pm    Post subject: Reply with quote
Pozri si historiu tvojho prehiadaca.
Inak ak si pozries "kamaratov siemensmanie" tak je tam jeden odkaz na stranku na SL45i. Robil ku "truhlik". Ale neviem ci tam je presne napisane odkaz na sl45i.
truhlik
elfmaster
elfmaster
8069.50 SMM
PostPosted: Tue Jul 12, 2005 8:04 am    Post subject: Reply with quote
nevim jestli bude fungovat, ale muzes zkusit tenhle java enabler http://sl45i.wz.cz/archive/javabysky.zip rozdhodne uz sem s nim nejakou javu odemknul, myslim na mt50ce a mozna i na a/c55 (ale tim si nejsem moc jist, jestli sem pouzival zrovna tohle:) snad ti to pomuze
hodne stesti
Reply to topic     Forum Index -> x62 a starší řady -> x45 All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
