Zaslal: pá srpen 18, 2006 7:05 pm Předmět: |
VNavigator napsal: | Please send me reports on vnavigator.at.gmail.com. Logs to do "PortMon" in HEX mode. |
I sent it, phone M55 FW10. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí.
Naposledy upravil hanni dne pá srpen 18, 2006 7:28 pm, celkově upraveno 1 krát |
Johny007 všeználek
Založen: 27. 07. 2004 Příspěvky: 642 Bydliště: Olomouc
Zaslal: pá srpen 18, 2006 7:17 pm Předmět: |
VNavigator napsal: | Please send me reports on vnavigator.at.gmail.com. Logs to do "PortMon" in HEX mode. | Povedlo se vam nekomu udelat ten log v HEXu???? Mne teda ne kód: | 0 0.00008325 TOTALCMD.EXE IRP_MJ_CREATE Serial0 SUCCESS Options: Open
1 0.00001509 TOTALCMD.EXE IOCTL_SERIAL_SET_QUEUE_SIZE Serial0 SUCCESS InSize: 16384 OutSize: 16384
2 0.00002291 TOTALCMD.EXE IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS
3 0.00000279 TOTALCMD.EXE IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS
4 0.00000223 TOTALCMD.EXE IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS
5 0.00000223 TOTALCMD.EXE IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS
6 0.00000168 TOTALCMD.EXE IOCTL_SERIAL_GET_BAUD_RATE Serial0 SUCCESS
7 0.00000168 TOTALCMD.EXE IOCTL_SERIAL_GET_LINE_CONTROL Serial0 SUCCESS
8 0.00000168 TOTALCMD.EXE IOCTL_SERIAL_GET_CHARS Serial0 SUCCESS
9 0.00000168 TOTALCMD.EXE IOCTL_SERIAL_GET_HANDFLOW Serial0 SUCCESS
10 0.00001117 TOTALCMD.EXE IOCTL_SERIAL_SET_BAUD_RATE Serial0 SUCCESS Rate: 115200
11 0.00000866 TOTALCMD.EXE IOCTL_SERIAL_CLR_RTS Serial0 SUCCESS
12 0.00000782 TOTALCMD.EXE IOCTL_SERIAL_SET_DTR Serial0 SUCCESS
13 0.00000670 TOTALCMD.EXE IOCTL_SERIAL_SET_LINE_CONTROL Serial0 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
14 0.00003017 TOTALCMD.EXE IOCTL_SERIAL_SET_CHAR Serial0 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
15 0.00001844 TOTALCMD.EXE IOCTL_SERIAL_SET_HANDFLOW Serial0 SUCCESS Shake:1 Replace:0 XonLimit:8192 XoffLimit:2048
16 0.00000223 TOTALCMD.EXE IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:30 RM:1 RC:200 WM:0 WC:0
17 0.00001620 TOTALCMD.EXE IOCTL_SERIAL_SET_RTS Serial0 SUCCESS
18 0.00000950 TOTALCMD.EXE IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR
19 0.00000922 TOTALCMD.EXE IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:30 RM:1 RC:1000 WM:0 WC:0
20 0.00000894 TOTALCMD.EXE IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR
21 0.00003967 TOTALCMD.EXE IRP_MJ_WRITE Serial0 SUCCESS Length 5: ATE0.
22 1.00069003 TOTALCMD.EXE IRP_MJ_READ Serial0 TIMEOUT Length 0:
23 0.00001229 TOTALCMD.EXE IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS
24 0.00001034 TOTALCMD.EXE IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR
25 0.00119987 TOTALCMD.EXE IRP_MJ_WRITE Serial0 SUCCESS Length 28: AT+CCLK="06/08/18,20:15:28".
26 1.00111104 TOTALCMD.EXE IRP_MJ_READ Serial0 TIMEOUT Length 0:
27 0.00001285 TOTALCMD.EXE IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS
28 0.00001201 TOTALCMD.EXE IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR
29 0.00004107 TOTALCMD.EXE IRP_MJ_WRITE Serial0 SUCCESS Length 10: AT^SQWE=1.
30 1.00030339 TOTALCMD.EXE IRP_MJ_READ Serial0 TIMEOUT Length 0:
31 0.00001201 TOTALCMD.EXE IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS
32 0.00000754 TOTALCMD.EXE IOCTL_SERIAL_SET_TIMEOUTS Serial0 SUCCESS RI:30 RM:1 RC:2000 WM:0 WC:0
33 0.00000922 TOTALCMD.EXE IOCTL_SERIAL_PURGE Serial0 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR
34 0.00004246 TOTALCMD.EXE IRP_MJ_WRITE Serial0 SUCCESS Length 10: AT^SQWE=0.
35 2.00117920 TOTALCMD.EXE IRP_MJ_READ Serial0 TIMEOUT Length 0:
36 0.00002430 TOTALCMD.EXE IOCTL_SERIAL_GET_COMMSTATUS Serial0 SUCCESS
Tohle se mi povedlo.. A kdyz to neni v hexu, tak to nema cenu posilat.. _________________ M55 Iridium - TestPoint , FW11 + mojepatche.txt HP iPAQ 514 WM6 |
Zaslal: pá srpen 18, 2006 7:25 pm Předmět: |
takto som mu to poslal aj ja...inac to nejde urobit _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
Johny007 všeználek
Zaslal: pá srpen 18, 2006 7:27 pm Předmět: |
hanni napsal: | takto som mu to poslal aj ja...inac to nejde urobit |
Jj, snazil jsem se, ty volby jsem zatrhl a stejne nic.. Ok.. tak dobre, ze uz je to vyrizeno.. _________________ M55 Iridium - TestPoint , FW11 + mojepatche.txt HP iPAQ 514 WM6 |
VNavigator kolemjdoucí
Založen: 04. 08. 2005 Příspěvky: 8
Zaslal: pá srpen 18, 2006 7:47 pm Předmět: |
2 Johny007
Check DTR or RTS if cable mark Noname (made in China)!!! Please write you questions on English!!! I"m understand CZ , and please send me log to mail. _________________ S75 (sw40 lg03). |
Johny007 všeználek
Zaslal: pá srpen 18, 2006 8:41 pm Předmět: |
VNavigator napsal: | 2 Johny007
Check DTR or RTS if cable mark Noname (made in China)!!! Please write you questions on English!!! I"m understand CZ , and please send me log to mail. |
I have 2 cables and one is original Siemens. But in anyone case, phone doesn't connect.. Simply I missing the opinion x55/x65. Log of both cables I sent to your mail. SiMoCo working correct. Maybe it will be usefull, so there is log of internal TC communication kód: | SOFS plugin for Siemens x55-x65-x75 Cell Phones 1.7.0 build 519
CONNECT...
Send AT Command "ATE0"
Send AT Command "AT+CCLK="06/08/18,21:36:48""
Time synchronize failed
Send AT Command "AT^SQWE=1"
PhoneName -
Send AT Command "AT^SQWE=0"
No answer from command
OBEX Disconnect
Close port
Zaslal: so srpen 19, 2006 5:37 pm Předmět: |
New version here:
+ Fixed some bugs for connect M55;
+ Small correct OpenHiddenDisks;
+ Corrected error at determination of accessible ports in the system;
+ Two baudrates added (28800 and 19200);
Download _________________ S75 (sw40 lg03). |
Zaslal: so srpen 19, 2006 6:05 pm Předmět: |
Super, working OK. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
stano.mania siemensmaniak
14311.82 SMM
Příspěvky na SM: 160,- |
Zaslal: ne srpen 20, 2006 8:42 am Předmět: |
VNavigator napsal: | New version here:
Download |
But on CX75 by Bluetooth do not work OpenHiddenDisks and OD2 Single
For me is the same as previous versions Plugin could be used only as "normal TM". I hope, future version solve these problems.
(žiaľ, ani táto najnovšia verzia nerieši odkrytie skytých súborov, na CX75 to nejde určite, tak ako v predošlých verziách)
Naposledy upravil stano.mania dne ne srpen 20, 2006 9:02 am, celkově upraveno 1 krát |
mlcuchv badatel
Založen: 15. 02. 2005 Příspěvky: 136 Bydliště: Chomutov
Zaslal: ne srpen 20, 2006 8:55 am Předmět: |
Me se take osvedcila verze 1.6 Pouzivam ji s telefony C72, C75 a S75 bez jedineho problemu. Pro me nevidim duvod menit neco co bezvadne funguje 8) _________________
14311.82 SMM
Zaslal: ne srpen 20, 2006 9:04 am Předmět: |
mlcuchv napsal: | Me se take osvedcila verze 1.6 Pouzivam ji s telefony C72, C75 a S75 bez jedineho problemu. Pro me nevidim duvod menit neco co bezvadne funguje 8) |
verzia 1.6 ale na S75 cez Bluetooth určite nezvládne otvoriť skryté súbory, cez Irda a kábel to ide, ak Ti ale ide aj cez Bluetooth, popíš ako, lebo sa to zatiaľ nikomu nepodarilo |
Zaslal: ne srpen 20, 2006 11:21 am Předmět: |
For bluetooth connection entering in BFC mode ( special mode of mobile that carry out special operation, for example get IMEI, accu voltage, read memory etc) impossible (blocked by mobile). That is why it is impossible to open the hidden disks. _________________ S75 (sw40 lg03). |
14311.82 SMM
Zaslal: ne srpen 20, 2006 11:24 am Předmět: |
Odskúšal som:
Keďže ide i ten istý obsah Pluginu ako od Vnavigator,
nejde Otvoriť skyté súbory cez Bluetooth na mojom CX75 a zrejme aj na mobiloch cez BT
v protokole AT príkazov vidím, že štartuje OpenHiddenDisk, wait 2-5 sec, a po AT "SGWE=1" Answer OK, a potom Can't enter BFC mode, a po AT "SGWE=0" je No answer from command, Obex disconnect... |
14311.82 SMM
Zaslal: ne srpen 20, 2006 11:29 am Předmět: |
VNavigator napsal: | For bluetooth connection entering in BFC mode ( special mode of mobile that carry out special operation, for example get IMEI, accu voltage, read memory etc) impossible (blocked by mobile). That is why it is impossible to open the hidden disks. |
Thanks for information,
now is clear that Open Hidden Disks is IMPOSSIBLE by Bluetooth,
it works only by Irda or cable.
Vďaka za vysvetlenie, teraz je jasné, že otvoriť skryté súbory nie je možné cez Bloutooth, ide to OK len na Irda alebo cez kábel. |
