metink kolemjdoucí
Založen: 13. 07. 2004 Příspěvky: 19
Zaslal: st srpen 04, 2004 6:46 pm Předmět: |
I have got one last question in this topic
Please tell me how you make the langpacks with the Siemens Language Editor!
I thought that it only makes .lgp files _________________ MT50 --> M55 fw11 3,625 MB |
Little_S čestný člen
Zaslal: st srpen 04, 2004 7:42 pm Předmět: |
this is header of a S55 LGP, for M55 is it little bit different
PhoneType S55_20, 000000, x0000,6,8,a,c,e,10,12,16,2a,3c,43,0
AllLangs x
MaxMsgId 3836
LgPackId lg1
; Language data
LangId 1
x means number of laguages, what you want (dont forget to delete other languages)
000000 is the adress of LGP....but it has to be 0, you will write adress in v-klay
x0000 is the size of LGP |
metink kolemjdoucí
Zaslal: čt srpen 05, 2004 6:38 pm Předmět: |
And how do you save the .lgp file (edited, with only one language) as a .bin file?
Opened:
citace: |
; Header info
PhoneType M55_10, 5A0000, 60000,6,8,a,c,e,10,12,16,2a,3c,43,0
AllLangs 1
MaxMsgId 3840
LgPackId lg1
; Language data
LangId 0
String 0, "<91>+Liste"
String 1, "<95>1 Stunde"
After changing "5A0000" into "000000" shall I also change "60000" into "x0000" ? _________________ MT50 --> M55 fw11 3,625 MB
Naposledy upravil metink dne čt srpen 05, 2004 6:57 pm, celkově upraveno 2 krát |
Zaslal: čt srpen 05, 2004 6:54 pm Předmět: |
metink napsal: | After changing "5A0000" into "000000" shall I also change "60000" into "x0000" ? |
yes, of you will have only 1 language, set the size 10000
then (in SLE) Compile LGpack in flash and save as new file something.bin (its size should be 54kB or more, but not more than 64kB for 1 language) |
