hotter badatel
Založen: 04. 12. 2004 Příspěvky: 141 Bydliště: Lithuanian Telefon: M55 47266.46 SMM
Zaslal: čt srpen 18, 2005 3:04 pm Předmět: x65 flasher |
x65 flasher - 1072
With what highest phone sw i can use this program generaiting boot password? Can i use it with siemens cxv70 sw50
Mey be someone know cz to eng translator? |
karci (člen klubu SM) začátečník
Založen: 17. 12. 2004 Příspěvky: 60 Bydliště: Bratislava - prdel pri Modre
Zaslal: čt srpen 18, 2005 3:09 pm Předmět: Re: x65 flasher |
hotter napsal: | x65 flasher - 1072
I guess so, I used it successfully with CXT70 sw54
Save the Px65v4 midlet into the phone and run it, wait until it says OK (that takes appr. 10 minutes). Then run the x65flasher (with the phone still running the midlet) and you get your codes very quickly. |
lacibogi čestný člen
786.46 SMM
Zaslal: čt srpen 18, 2005 3:18 pm Předmět: |
It works with all firmwares without doing testpoint. _________________ C(ME)75
Lasky |
hotter badatel
Zaslal: čt srpen 18, 2005 3:34 pm Předmět: |
It's cool at last my phone will be patching and mey be someone know it is dangerous to generate boot password via px65v4 midlet and X65 flasher??? |
786.46 SMM
Zaslal: čt srpen 18, 2005 3:43 pm Předmět: |
I think it´s dangerous like generating with PapuaUtils.
Now you can compare it. _________________ C(ME)75
Lasky |
hotter napsal: | It's cool at last my phone will be patching and mey be someone know it is dangerous to generate boot password via px65v4 midlet and X65 flasher??? |
No, the Java midlet does not alter anything in the phone software, it only communicates with x65flasher. Generation of codes is pretty safe; however, you may damage your phone later when you modify the firmware or EEPROM. Therefore be cautious and as the first thing, make the fullflash backup! It is also useful if you unlock all EEPROM blocks of your phone, there is a special patch for this. |
