Jaffe kolemjdoucí
Založen: 03. 02. 2005 Příspěvky: 5
Zaslal: čt prosinec 22, 2005 9:49 pm Předmět: Slow 3D-Java |
I recently got my CX75, and I really like it (apart from slow MP3 on the internal memory), but 3D Java games run just as bad as on my CX65, which is not normal. What is the problem here? I've tried FW5, 12 and 13, with the same results. The "normal" Java programs run as normal, I actually have the best result in Jbenchmark 1 and 2. So, what's wrong with the 3D Java thing? |
gabos začátečník
Založen: 23. 07. 2005 Příspěvky: 84
Zaslal: út prosinec 27, 2005 1:15 am Předmět: same problem |
I have same problem as you, but it is not as slow as you are describing... But it is slower than I want it to be _________________ Ericsson T28s (dedictvo po dedovi) -> Siemens A50 -> Siemens SX1 , 256 MB RS-MMC -> Siemens CX75, 256 RS - MMC, headset -> SE W710i komplet... -> Nokia 6120 classic |
