mobile kolemjdoucí
Založen: 01. 01. 2005 Příspěvky: 14
Zaslal: po leden 09, 2006 4:35 am Předmět: who knows english? please someone help me... |
who knows english? please someone help me... ı m gettıng ınto here ın turkey .. who wants to help me ınfo of theme patch to sx1 fullscreen. ı have to do this patch only eidpic and wallpaper but ı dont know what m ı doing this patch on standby mode left softkey and right softkey mode.. ıf someone helps me ı thanks alot him... _________________ zoxir |
jiji2004 všeználek
Založen: 22. 09. 2004 Příspěvky: 743
Zaslal: po leden 09, 2006 9:38 am Předmět: Re: who knows english? please someone help me... |
mobile napsal: | who knows english? please someone help me... ı m gettıng ınto here ın turkey .. who wants to help me ınfo of theme patch to sx1 fullscreen. ı have to do this patch only eidpic and wallpaper but ı dont know what m ı doing this patch on standby mode left softkey and right softkey mode.. ıf someone helps me ı thanks alot him... |
Hi. Can you please write again what exactly is your problem? I´m affraid it´s difficult to understand. You would like to know what is the "theme patch" (whitch moves EidPic.mbm from Z: to E: ) doing with right and left softkey? Is this your problem?
Naposledy upravil jiji2004 dne po leden 09, 2006 3:41 pm, celkově upraveno 1 krát |
Jopo začátečník
Založen: 02. 09. 2004 Příspěvky: 73 Bydliště: Slovakia, SNV
Zaslal: po leden 09, 2006 2:13 pm Předmět: |
to mobile
You wants change on standby mode left softkey and right softkey wallpaper?? This is at the moment imposible. You can use program Wildskinz, but isnt compatible with SX1 and its problem.
sorry for my bad english _________________ SX1 + 9 patchov |
Gwin čestný člen
0.84 SMM
Zaslal: po leden 09, 2006 2:45 pm Předmět: |
2Jopo: Jestli to chápu dobře, tak to vyřeší prog sProfiles.
Translation: 2Jopo: If I understand well, solution is prog sProfile. _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
mobile kolemjdoucí
Zaslal: po leden 09, 2006 11:40 pm Předmět: |
Sorry me to bad english ı use this forum hardly becouse ı dont understand your language.. ı know how to do it eidpic.mbm Z: to E: ıts ok but ı saw in this forum 1 theme ı give u a link please look
http://www.siemensmania.cz/forum/viewtopic.php?p=201825
in this link themes who did it ıdont know but he do it stndby mode right and left soft keys color is different what to do this?
please someone convert me the moderator writes me what? _________________ zoxir |
Sirus čestný člen
7909.00 SMM
Zaslal: út leden 10, 2006 8:05 am Předmět: |
I think you must change pallete.dll directly in firmware and its not so easy. _________________ C35i>ME45>>S45i>ST55>S55+BT>SX1
jaramara věrný diskusník
Založen: 30. 09. 2004 Příspěvky: 403 Bydliště: Zlín
Zaslal: út leden 10, 2006 11:52 am Předmět: |
You visit it www.siemens-mobiles.org There is English help for you.... _________________ Siemens SX15en(czT9)/ja_ma mod 36patches core 168Mhz !!DEATH!! =); Trancend512MB; joy 6600 and Samsung X200 (vodafone)
NOW_NOKIA_ /\/70 _ rulezz =) |
mobile kolemjdoucí
Zaslal: st leden 11, 2006 6:28 pm Předmět: |
Sirus napsal: | I think you must change pallete.dll directly in firmware and its not so easy. |
yes my friend ı want to change pallete.dll ... aRe u do it? or how ı do it? _________________ zoxir |
Gwin čestný člen
0.84 SMM
Zaslal: st leden 11, 2006 8:17 pm Předmět: |
Here's how you change the colors of your SX1:
1. Copy Z:\System\Libs\palette.dll to HDD. Remove Attribut "ReadOnly"
2. Open Palette.dll with the Tool.
3.Change the colors to whatever you want to!On some colors you notice a "." Like: There you can change the visual colors.
4. Press Button "Patch palette.dll". choose the file, which you copied from Z:. Then you could rename it to pallette_patched.dll
5. Open APatcher
6.Press Button "Any file replacer" First, you need to open the original palette.dll. Then you take the patched one.After that you save the sxpr-patch-file.
7. Then you apply patch in RAM.
8. do the same as usual...
Meanwhile Hoschie collected those interesting details for you...
FF is the color of background in the telephone
F5 is Background with the bell
F4 is Isolation in the menu
EF is gradient 2
EE is gradient 3
ED Strip between the cap and the background
EC is gradient 4
EB is gradient 5
EA is gradient 6
E9 is gradient 7
E5 is Background of the lower button
D6 is Font
E9 is up-arrow in the menubar
EF is down-arrow in the menubar
download Palette tool _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
mobile kolemjdoucí
Zaslal: st leden 11, 2006 10:28 pm Předmět: |
THANKS A LOT MY FRIEND sEE U SOON _________________ zoxir |
mobile kolemjdoucí
Zaslal: čt leden 12, 2006 4:09 pm Předmět: |
which patcher r u use ? ı use a powerhex. is it a true patcher ? _________________ zoxir |
ZeeRaX všeználek
Založen: 11. 12. 2004 Příspěvky: 784 Bydliště: mam
Zaslal: čt leden 12, 2006 9:18 pm Předmět: |
mb the best software for applying patches is Apatcher _________________ Sagem RC 825-->Sony CMD-J5-->M55 FW 91 +novej kryt(od vyroby seka)-->SX1 FW: SMO_VII-->15CZ_patched->N70MOD
mobile kolemjdoucí
Zaslal: so leden 14, 2006 4:20 am Předmět: |
ZeeRaX napsal: | mb the best software for applying patches is Apatcher |
can u give me a this patcher or a link ı want to download it? very very thanks 4 u to help me ...... _________________ zoxir |
cuir ostřílený diskusník
Založen: 14. 09. 2004 Příspěvky: 526 Bydliště: Brno
3072.76 SMM
Zaslal: so leden 14, 2006 9:53 am Předmět: |
mobile napsal: | ZeeRaX napsal: | mb the best software for applying patches is Apatcher |
can u give me a this patcher or a link ı want to download it? very very thanks 4 u to help me ...... |
link for Apatcher
http://cuir.wz.cz/mobil/apatcher.rar
this is a programm for aply patch *.sxp or *.sxpr
download patches can you on this page http://www.siemens-mobiles.org/
you must be registred.
After registration click for Pach Generator. _________________ M35i->C45->M50->C55->S55->M55->SX1
http://cuir.wz.cz |
mobile kolemjdoucí
Zaslal: so leden 14, 2006 11:34 pm Předmět: |
cuir napsal: | mobile napsal: | ZeeRaX napsal: | mb the best software for applying patches is Apatcher |
link for Apatcher
After registration click for Pach Generator. |
my friend this link is true download it but winrar not extrackt it program has been broken down winrar says brake a operation understand me _________________ zoxir |
