P4C3 kolemjdoucí
Založen: 18. 01. 2006 Příspěvky: 6
Zaslal: st leden 18, 2006 11:20 pm Předmět: Siemens SL65 unlock?? |
Hi!
I wannt to unlock my SL65, but in this language i can't find the software - if this exists- i tried to download the SST, but don't understand the regedit part... please!! Someone help me!! Thanks a lot! |
lacibogi čestný člen
786.46 SMM
Zaslal: čt leden 19, 2006 5:32 pm Předmět: |
Use Papua Utils. _________________ C(ME)75
Lasky |
P4C3 kolemjdoucí
Zaslal: čt leden 19, 2006 7:03 pm Předmět: |
Hm... i have dowloaded it, but can you tell me what button is the UNLOCK button? Can't find it... |
786.46 SMM
Zaslal: čt leden 19, 2006 7:18 pm Předmět: |
Oh fuckin´...it´s not so easy to say it. You must generate all codes and SKEY write in. Than if you want to unlock only a phone code use 5008 button. It´s in fourth part of the program. _________________ C(ME)75
Lasky |
P4C3 kolemjdoucí
Zaslal: pá leden 20, 2006 12:21 am Předmět: |
So, if i wannt to unlock the phone, i have to do not just a step?! Oh shit
In this hieroglyfican write will be not easy
Isn't exists english software for unlocking SL65?
Or can you write down what i have to do? |
786.46 SMM
786.46 SMM
P4C3 kolemjdoucí
Zaslal: ne leden 22, 2006 9:57 pm Předmět: |
HI! Thanks for the tut! I had downloaded MPM and SiMoCo too, but these don't connect to the phone, i don't know why... The cabel is in the COM1 and in the phone, the phone is on and on the network, but the software by the search didn't find any phone...why? Have i forget something?
p.s.: I have this cable:
The shop gave me this "With this will be okay..." i think he was wrong... |
786.46 SMM
Zaslal: po leden 23, 2006 10:19 am Předmět: |
This cable is for x55. I think you need to do this.
Lasky |
P4C3 kolemjdoucí
Zaslal: po leden 23, 2006 12:45 pm Předmět: |
Okay! The cabel problem is fixed The PC now see the phone! I have put on the px65v4, it has given me the codes, but the papua don't wannt to red the codes, and if i write in manually by the generation it gives me:" Not a valid integer..." Interesting... |
786.46 SMM
Zaslal: po leden 23, 2006 2:12 pm Předmět: |
Great, step by step we will solve it.
Now you must change ESN like this ABCD-EF12 -> 12EFCDAB. _________________ C(ME)75
Lasky |
P4C3 kolemjdoucí
Zaslal: po leden 23, 2006 3:32 pm Předmět: |
Great! The program now get the values!!! And generates the SKEY and the bootkey! The tut says: "Enter correct HWID" in the program or on the phone? On the phone i don't know how, but in the program i have selected it!
Under the bootkey and Skey generate button are 2 ???? SKEY ?????? buttons (??? becouse my hungarian characters) one of them is: Write SKEY other: unlock SKEY! I have to press only the Write SKEY button??
After this my phone should accept any SIm cards, right?
EDIT.:
in time i have made it! Great! The phone accept all SIM's i give him )
Thanks for the usefull help! Thanks a lot!!! |
786.46 SMM
Zaslal: po leden 23, 2006 4:14 pm Předmět: |
You are welcome. _________________ C(ME)75
Lasky |
