:: Zobrazit téma - Patche pre SX1
Patche pre SX1
Jdi na stránku Předchozí  1, 2, 3, 4, 5  Další
Toto téma je zamknuto bez možnosti úpravy příspěvků a psaní odpovědí    Obsah fóra -> Siemens SX1
Sirus
Založen: 06. 08. 2004
7909.00 SMM
PříspěvekZaslal: út duben 11, 2006 9:01 am    Předmět: Odpovědět s citátem
Umoznuje preklad Firmware
kód:
; *** AllowOtherLanguages 1.0 ***
; *** Allow Other Languages ***
; Author: fca00000 , fca00000-at-yahoo-dot-es
; Date: 2006.04.07 v1.0
; Firmware: Siemens-SX1 Possibly all versions. Tested on Iberia15.2 and O2-14
; Omap: Core-Img (Z1)
; Requires patch DriveCbeforeDriveZ
; In fact, this is only a trick, not a real patch.
; Firmware version 15 is not available in all languages. But sometimes you need it. Imagine that you are swedish and
; are using uk-sw-da-14  which supports swedish, but you would like to use uk-es-pt-15 because it's more advanced.
; Then install uk-sw-da-14 and extract all *.r06 to your PC.
; Rename them as *.r13
; Copy into the mobile drive C:
; Install DriveCbeforeDriveZ
; Choose language Portuguese (has code 13)
; Restart mobile. Everything (almost) is in swedish.
; As far as I know, nothing is broken. But I decline all responsability, of course.
; Anyway, here it is. Enjoy
; end of AllowOtherLanguages
Naposledy upravil Sirus dne út duben 11, 2006 9:03 am, celkově upraveno 1 krát
Sirus
7909.00 SMM
PříspěvekZaslal: út duben 11, 2006 9:02 am    Předmět: Odpovědět s citátem
Umoznuje tahat subory z C namiesto zo Z.
kód:
; *** DriveCbeforeDriveZ 1.0 ***
; *** Drive C: before Drive Z: ***
; Date: 2006.04.08 v1.1 Also allows drive E: (DriveEbeforeDriveZ)
; Unresolved bug: crashes if file name lenght>110. Noticeable when sending files (maybe also SMS)
; First of all: make a backup. Now !
; There are several patches that allow using some file from C: or E: , instead of Z:
; This patch improves that: EVERY file will be searched in C: before using the file in Z:
; If file doesn't exist in C: , it will use the file in Z:
; For example, transfer  Z:\System\Apps\About\About.mbm
; to your computer, modify using MBMTool by Alezz (great program), and
; copy back to mobile into  C:\System\Apps\About\About.mbm
; Open Menu->Setup->About . Now uses the picture from C:
; For the curious people: I changed EFSrv.dll in
; method RFile::Open
; I also used some free space in Fault::TClientFault and other routines
; Be aware that not all files can benefit from this patch.
; It works with: *.mbm , *.r01, *.r?? , *.mid, *.aif *.ini *.rsc *.bmp
; It doesn't work with: *.app *.dll
; I didn't test with: *.ldd *.pdd *.exe *.csy *.mdl
; Also remember that some files are cached. You might need to restart the phone after copying into C:
; It might also happen that a corrupted file in C: crashes your phone. Format and restore from Backup.
replace:00B584B0009201931B226B4604F00EFB04B002BC08470000:F0B47546BCB002F07AFF01931B226B46BE68DF24264005E0
replace:6B4604F002FB04B002BC08470000:0AE0014C5A2E03F06CF963003A00
; use the following line if you prefer DriveEbeforeDriveZ . In this case do not use line above. But seems to crash more often
; replace:6B4604F002FB04B002BC08470000:0AE0014C5A2E03F06CF965003A00
replace:30B582B0051C6C460549201C01F054F8201C291C01F096FA02B030BC01BC0047:08D1BC60061C01F08FF9002804D0301C034CBC6001F088F93CB0AE46F0BC70477A003A00
replace:F0402DE91CD04DE20050A0E10160A0E10270A0E10340A0E1:FE402DE91CD04DE20050A0E10160A0E10270A0E10340A0E1
replace:F040BDE81EFF2FE110402DE910D04DE20040A0E1043094E5:FE40BDE81EFF2FE110402DE910D04DE20040A0E1043094E5
replace:031C0091506801900292002805D0181C34216A4601F098FB00E0002004B002BC08470000:031C00915068342114E002AEE0271468346004320436043F002FF8D102AF009770470000
replace:01900292002805D0181C35216A4601F082FB00E0002004B002BC08470000:352101900292002804D0181C6A4601F082FB00E0002004B002BC08470000
; end of DriveCbeforeDriveZ
Sirus
7909.00 SMM
PříspěvekZaslal: út duben 11, 2006 9:05 am    Předmět: Odpovědět s citátem
Skratenie casu pri pisani
kód:
; *** DecreaseMultiTapTimer 1.0 ***
; *** Decrease MultiTap Timer ***
; Date: 2006.04.09 v1.0
; Made after request from a43
; When you press a key in Notepad you need to wait 0.8 seconds before it shows, so that you can type a new one.
; This patch reduces the time to 0.5 seconds , for experienced typists.
; Works in any application. Doesn't change in T9 mode, nor with '0' key, nor with '1' key. I could have done it, though.
; Numbers can not be written any more with long-pressing. I like it this way.
; For the curious people: I changed et9eng.dll in
; method CT9Data::T9HandleRequest
; before calling CMultiTapTimer::After
replace:0C009C24A4003019006801F010F80AE09C24:07009C24A4003019006801F010F80AE09C24
; The first byte is the time. 0C=8/10 seconds. 07=5/10 seconds. 03=2/10 seconds
; end of DecreaseMultiTapTimer
Mio
Založen: 22. 11. 2004
10930.24 SMM
PříspěvekZaslal: pá květen 12, 2006 4:23 pm    Předmět: Odpovědět s citátem
Umožňuje spouštět některé JAVA hry/aplikace pro MIDP 2.0
kód:
; Patch № 83
; MIDP 2.0 v1.00
; by Тип-Топыч
; 09-05-2006 21:24
; allows to run some MIDP 2.0 applications
replace:52002D005500730072004100670034003D00500072006F00660069006C0065002F004D004900440050002D0031:52002D005500730072004100670034003D00500072006F00660069006C0065002F004D004900440050002D0032
N95-8GB
Gwin
Založen: 27. 09. 2004
0.84 SMM
PříspěvekZaslal: pá květen 12, 2006 8:05 pm    Předmět: Odpovědět s citátem
kód:
;*** DecreaseMultiTapTimer 1.1 ***
; Date: 2006.04.11 v1.1 Now also numbers are allowed with long-press
; Made after request from a43. Improved for number long-press after suggestions from chencho and Jimmy007
; Works in any application: writing SMS, renaming files, modifying contacts, Notepad, ...
; Doesn't change in T9 mode, nor with '0' key, nor with '1' key. I could have done it, though.
; v1.1 Numbers can also be written with long-pressing.
; And EikSrvUi in CEikServAppUi::ConstructL and EikCore
replace:C0270900801A0600:C0270600801A0300
Gwin
0.84 SMM
PříspěvekZaslal: pá květen 12, 2006 8:08 pm    Předmět: Odpovědět s citátem
Aplikace přes hexeditor, viz.:
kód:
; *** FixTomTomCitymaps 1.0 ***
; *** Fix TomTomCitymaps ***
; Date: 2006.04.23 v1.0
; File: e:\system\apps\CityMaps\citymaps.app
; The application TomTomCitymaps doesn't work on SX1. This patch fixes it.
; Remember that using pirated software is illegal. Support the programmers !
; Transfer file e:\system\apps\CityMaps\citymaps.app to your PC. Takes 430892 bytes onl PC, and 420793 on mobile.
; Open with your favourite Hex editor
replace:BE590010:BD590010
; Transfer to mobile
; For the curious people: At 100048EC it calls CListBoxData::Reserved with some callback
; pointing to loc_100059BC+2 .Because of Arm architecture, this should be loc_100059BC+1 instead.
; Este parche arregla el TomTomCitymaps.
; Recuerda que usar software pirata es ilegal. Ayuda a los programadores !
; Copia el archivo e:\system\apps\CityMaps\citymaps.app al PC. Ocupa 430892 bytes en el PC, y 420793 en el movil.
; Abrelo con tu editor hexadecimal favorito, aplica el parche anterior, y metelo de nuevo en el movil.
; Hasta donde yo he comprobado, no he roto nada. De todos modos yo no me hago responsable.
; end of FixTomTomCitymaps
Naposledy upravil Gwin dne pá květen 12, 2006 8:19 pm, celkově upraveno 1 krát
Gwin
0.84 SMM
PříspěvekZaslal: pá květen 12, 2006 8:11 pm    Předmět: Odpovědět s citátem
kód:
; Patch No 84
; *** Убрать подтверждение Включить громкую связь beta***
; *** Remove message: Do you want to activate handsfree?***
; by Vovan888 (vovan@oslik.ru) 29.01.2006
; oslik.ru
; changes CPhoneAudioManager::ToggleIhf(int)
; есть глюк - в момент включения слышен щелчок.
; 509378BA 0C D1 BNE loc_509378D6
replace:0CD1139013A9684620F0D1FC002810D1201C00F012F8:0CE0
;50936BE2 01 21 MOV R1, #1
replace:012100F062FE2DE0101CA0300068002100F05BFE26E0:002100F062FE2DE0101CA030006801
Gwin
0.84 SMM
PříspěvekZaslal: pá květen 12, 2006 8:12 pm    Předmět: Odpovědět s citátem
kód:
; Patch No 61 updated
; * Отменить очистку списков вызовов при смене SIM*
; * Disable_clear_logs_after_SIM_change*
; oslik.ru (updated 11.05.2006)
; Использован список функций O2_14 от FCA00000
; Made with help of O2_14 func list from FCA00000
; Отключает функцию CSysApAppUi::DoSimChangedFromPreviousBootL(void)
; 0x50854846
replace:03F01BFF041C03F01EFF002C05D0:10BC01BC0047
; Отменить вопрос о новой SIM в phonebook.app
; (disable CPbkCheckNewSim class)
; 0x50783012
replace:00F0C3FB341CA434206000F004FC002815D009481890199620681899199A:0028002800280028002800280028002815E0
Sirus
7909.00 SMM
PříspěvekZaslal: út červen 06, 2006 12:29 pm    Předmět: Odpovědět s citátem
Zvysenie hlasitosti handsfree
kód:
; *** BoostHeadsetVolume ***
; Author: Bryan , yanzhengdao@gmail.com <mailto:yanzhengdao@gmail.com>
; Date: 2006.01.19
; FirmWare: Siemens-SX1 Possibly all versions. Tested on V15 uk-it-de and Simplified Chinese V15
; This patch can boost headset volume in any case you use headset.
; If you use some special headset the volume may be very low. Then you can try this patch.
; This patch don't affect speaker.
; Warning: Too loud volume can hert your hearing!!!
; Thank you for FCA00000 for his O2_14.symbol
; CMdaRecordUtilityImplData::MaxGain(void)
; CMdaRecordUtilityImplData::MaxVolume(void)
replace:05680E68684669462C222C23:05680E686846694648224823
Sirus
7909.00 SMM
PříspěvekZaslal: po červen 12, 2006 8:51 am    Předmět: Odpovědět s citátem
kód:
; Patch No. 85
; *** Decrease jpeg compression in camera ***
; *** Znizenie jpeg kompresie pri foteni ***
; High = 100%, basic = 85%
; vysoka = 100%, zakladna = 85%
; remake of xbi patch by dan_av (Z-Team) 2005
; prerabka xbi patchu od dan_av-a (Z-Team) 2005
replace:3C2001E0AAA95520886119A80421AAAA06F0CEFE:552001E0AAA964
; Right available free space information (640x480 100%)
; Spravna informacia o volnom mieste (640x480 100%)
; Actually, photo size may vary between 150 and 300K. Default size is set to 230K
; Velkost fotiek 150-300K. Standardna velkost nastavena na 230K
replace:08CF00008AA806F071FE024C00190249:009803
Sirus
7909.00 SMM
PříspěvekZaslal: po červen 12, 2006 8:56 am    Předmět: Odpovědět s citátem
kód:
;Patch 86
; *** AvoidHiddenMenu 1.0 ***
; *** Zobrazenie skrytych menu ***
; Date: 2006.05.28 v1.0
; Firmware: All
; Some menus are hidden (dimmed)
; Niektore menu su skryte
; This patch shows them. Be aware that some of them might not be usefull, and the applicacion will close.
; Tento patch ich zviditelni. Ale pozor niektore z nich nemusia fungovat spravne a zatvoria aplikaciu.
; For example, now you have Menu->Extras->Memory->Options->Set password
; Napriklad teraz je Menu->Extras->Memory->Options->Set password
; and Menu->Extras->File Manager->Options->Developer Menu->Send raw IrDa
; a Menu->Extras->File Manager->Options->Developer Menu->Send raw IrDa
; For the curious people: I changed EikCoctl.dll in
; Pre tych co to zaujma: Zmenil som EikCoctl.dll v
; method CEikMenuPane::SetItemDimmed
; metode CEikMenuPane::SetItemDimmed
; to use always the second parameter (the flag) as False
; aby pouzivala vzdy druhy parameter False
replace:141CFFF7ACFF021C002C03D0:0024FFF7ACFF021C002C03D0
; Patch moze byt nebezpecny. Autor sa zrieka zodpovednosti za skody sposobene patchom.
Sirus
7909.00 SMM
PříspěvekZaslal: po červen 12, 2006 9:04 am    Předmět: Odpovědět s citátem
kód:
;Patch 87
; *** nGage mode 2 ***
; *** nGage mod 2 ***
; Author: Vovan888 (vovan at oslik ru)
; Date: 10.06.2006
; Firmware: 15
; remove shadowing of many system libs
; Odstrani cashovanie vela systemovych kniznic
; this patch slowdowns a bit but frees up to 2 megs of RAM
; Patch sice trocha spomali telefon, ale uvolni az 2 MB RAM
; useful mainly for nGage games players
; Vhodne hlavne pre hracov nGage hier
; greeting goes to FCA00000 !!!
; Podakovanie FCA00000 !!!
; disable most of the 501B631C ; CEStart::DoShadowing(void)
; zakaze cashovat skoro vsetky
replace:0BAC9949201C00F0D5FB301C211CFFF795FF0DAC9549201C:00204DB0F0BC02BC0847
; completely disable shadowing
; zakaze cashovat vsetky
;501B66D8 FF F7 20 FE BL CEStart__DoShadowing_void_ ; CEStart::DoShadowing(void)
;replace:FFF720FE6846FFF763F96846FFF7B2F96846FFF7DDF96846:68466846
Mio
10930.24 SMM
PříspěvekZaslal: po srpen 07, 2006 12:20 am    Předmět: Odpovědět s citátem
A mame tu fantastickou novinku a to patch na zvetseni disku C az na 11,8 MB, bohuzel pouze pro "vyvolene" kteri maji v telefonu 32mb chip pameti.
kód:
 Patch No 90
; *** Zvetsi velikost dicku C na 11,8MB u telefonu s 32mb flashkou***
; *** Increase disk C size to 11.8 Mb for phones with 32mb flash ***
; Po patchovani je treba naformatovat disk C
; after patching one should format disk C
; by Vovan888 (oslik.ru)
; 05 Aug 2006
; thanks to FCA00000
; 50039D7C 76 38 A0 E3 MOV R3, #0x760000
replace:7638A0E35C3085E50500A0E1060000EA48AD0350:F4
Jakou flash pamet mate v telefonu zjistite touto aplikaci - http://vovan888.nm.ru/flashsize.exe
Aplikaci nakopirujte do telefonu a spustte.
Pokud se zobrazi 24mb, nepouzivejte tento patch.
Vse provadite na vlastni nebezpeci a autor se zrika odpovednosti za pripadne nasledky.
N95-8GB
Sirus
7909.00 SMM
PříspěvekZaslal: st září 20, 2006 10:44 am    Předmět: Odpovědět s citátem
Dve novinky: zvysenie hlasitosti pri telefonovani a automaticke zapnutie pri budiku
kód:
Patch N. 92
; *** Увеличение громкости во время разговора ***
; *** Increase volume during call ***
; by Vovan888 (vovan at oslik ru)
; 11.09.2006
; начиная с 500B6760 стало
; BEQ loc_500B6764
; ADD R2,#1 // прибавляем громкости +1
; Для любознательных. Громкость во время разговора регулируется командой AT^SNFV=0..9, где громкости 0..4
; используются в режиме разговора, а 5..9 - в режиме HandsFree.Этот патч добавляет 1 к громкости. (или 2)
; +1
replace:00DD09222C1C1C3400941349201C7EF025FD686923F088FC6869291C009A23F0:00D00132
; +2 - для тех кому мало Smile ОСТОРОЖНО - Будет громко!!!
;replace:00DD09222C1C1C3400941349201C7EF025FD686923F088FC6869291C009A23F0:00D00232
; +3 - для тех кому мало - почти HandsFree Smile ОСТОРОЖНО - Будет громко!!!
;replace:00DD09222C1C1C3400941349201C7EF025FD686923F088FC6869291C009A23F0:00D00332
Patch N. 93
; *** Авто Включение по будильнику ***
; *** Auto Power-up by alarm ***
; 11.09.2006
; 50BFD1BA
; последние 4 байта - время проигрывания мелодии звонка, после которого телефон включится
; если поставить маленькое время - то мелодия играться совсем не будет
; last 4 bytes = alarm melody play time, after it phone turns on
; 1 сек = 000F4240
; 3 секунды = 002DC6C0
; 5 секунд = 004C4B40
; 10 сек = 00989680
replace:25C5BF50C0448403:39DBBF5080969800
;50BFDB38 new proc
replace:A08601000320A060201CFFF7FFFE03B010BC01BC0047000000477047084770471047704718477047:A08601000320A060201CFFF7FFFE03B010BC01BC004700000047704708477047104770471847704741B5061C8830022100680840002801D00349084741BC02BC8E4602490847C046A1D1BF5031C5BF50
Sirus
7909.00 SMM
PříspěvekZaslal: st září 20, 2006 10:45 am    Předmět: Odpovědět s citátem
A este jeden na komplexne nastavenie funkcii joysticka.
kód:
Patch 94
; *** EnhanceMenuJoyStick ***
; Author: Bryan
; Date: 2006.09.18
; Firmware: Siemens-SX1 Possibly all versions. Tested on SX1_2_RUSSIA-RETAIL-uk-de-ru_15_0001
; Modified Omap(Z1) phone.app
; This patch is the enhancement of patch N0.30 and patch No.75
; With this patch you can set JoyStick LEFT,RIGHT,UP,DOWN and JoyStick_OK as shortcut of any application.
replace:814214D10648006806490968064A1268064BEFF702FF012030E0:814214D10648006806490968064A1268064BEFF702FF012026E0
; The last 40 numbers is UIDs for the shortcuts.Each one marked with a different color
; The order of these UIDs is JoyStick_LEFT,JoyStick_RIGHT,JoyStick_UP,JoyStick_DOWN,JoyStick_OK
; The UID in the patch must reversed like in patch No.30
; For Example: UID for BlueTooth is 10005951, then in the patch it should be 51590010
replace:1168054881420BD1186C044909680022:5B38814201D10E4912E00130814201D10C490DE00130814201D10B4908E00130814201D1094903E03B30814204D10849186C0022EFF77EFE002002BC08470000JoyStick_LEFTJoyStick_RIGHTJoyStick_UPJoyStick_DOWNJoyStick_OK
; you should change the last string in the above code to 40 numbers(5 UIDs)
; End of Patch
Toto téma je zamknuto bez možnosti úpravy příspěvků a psaní odpovědí    Obsah fóra -> Siemens SX1 Časy uváděny v GMT + 1 hodina
Strana 3 z 5
