:: View topic - jak emulovat usb port
Juřa86
3949.22 SMM
PostPosted: Fri Jan 20, 2006 10:53 pm    Post subject: jak emulovat usb port Reply with quote
potreboval bych poradit jak se to emuluje pres ten program co si tady stahnu jak se to vubec instaluje?potreboval bych otevrit skryte disky a mam usb kabel
beardie
7865.50 SMM
PostPosted: Fri Jan 20, 2006 11:04 pm    Post subject: Reply with quote
v navode je vsetko pekne vysvetlene
Juřa86
3949.22 SMM
PostPosted: Fri Jan 20, 2006 11:24 pm    Post subject: Reply with quote
tam ale neni jak to emulovat abych otevrel ty skryty disky?! Shame on you
beardie
7865.50 SMM
PostPosted: Fri Jan 20, 2006 11:35 pm    Post subject: Reply with quote
normalne naumuluj na nejaky com port,spusti VSFE, nastav spravny port a daj service/open hidden disks
Juřa86
3949.22 SMM
PostPosted: Fri Jan 20, 2006 11:36 pm    Post subject: Reply with quote
nojo ale jak normalne naemuluj to prave nevim jak se dela
PostPosted: Fri Jan 20, 2006 11:37 pm    Post subject: Reply with quote
V sekcii drivery nájdeš ovládač na kábel. Ten ti to naemuluje.
Juřa86
3949.22 SMM
PostPosted: Fri Jan 20, 2006 11:41 pm    Post subject: Reply with quote
ale jak ten program spustit?
PostPosted: Fri Jan 20, 2006 11:44 pm    Post subject: Reply with quote
Obyčajná inštalácia. Ako na disky sa dočítaš v návode na VNavigatorSFE.
Juřa86
3949.22 SMM
PostPosted: Fri Jan 20, 2006 11:49 pm    Post subject: Reply with quote
uz to mam to sem ale hlupak tak jednoduche d'oh!
ale dekuju
