:: Zobrazit téma - generating loaders for x65/x75 without testpoint
Jdi na stránku 1, 2  Další
Toto téma je zamknuto bez možnosti úpravy příspěvků a psaní odpovědí    Obsah fóra -> Non Czech Languages Here
beardie
Založen: 19. 01. 2005
7865.50 SMM
PříspěvekZaslal: ne únor 05, 2006 12:11 pm    Předmět: generating loaders for x65/x75 without testpoint Odpovědět s citátem
Papua Utils075
px65v5
V_Klay 3.3
1. copy the java midlet px65v5 into Data/Java/jam/Applications using SiMoCo,MPM or similar software
2. run the midlet
3. confirm "Local Connection? and "Allow Java to access data cable?"
4. wait 10-40 minuts until the midlet generates the keys, do NOT switch it off, when the keys are generated, you can hear "beep"
5. open papuautils and set your COM port (1) and go to the second tab (2)
6. push the "px65v4" key (1) and let papuautils download generated keys, when everything is downloaded , push the button "SKEY/BOOTKEY" (2), papua will calculate SKEY and BOOTKEY
7.switch your phone off and go to the first tab (3)
8. push the "Service mode" button (1) and press the red button on your mobile phone - do NOT hold it, push it only for a second (if something goes wrong, repeat the switching on)
9. when the telephone is in the "service mode", go back to the second tab and generate files for v_klay, x65 flasher and freia and save them (1)
10. than save SKEY to the telephone (2) and switch off your phone
11. copy generated v_klay loader into Program Files/ViSoft/V_Klay/data/Loaders, open V_Klay nad choose x65 (x75) Password boot, than your pnohe should connect with v_klay and you could patch it
Naposledy upravil beardie dne ne únor 05, 2006 9:01 pm, celkově upraveno 2 krát
Vladimir Curcic
Založen: 30. 04. 2005
PříspěvekZaslal: ne únor 05, 2006 8:31 pm    Předmět: Re: generating loaders for x65/x75 without testpoint Odpovědět s citátem
Nice work BIG THANKS for your effort - this was desperately needed!
Only you forgot one important note:
beardie napsal:
2. run the midlet
4a. DO NOT CLOSE THE JAVA MIDLET px65v5 !!!!!
S65(FW58) | IFL-600 (External flash) | DCA500
MY CURRENT COLLECTION: ME45 | S45i | CX65-LtdEd | S65 | SL75
Naposledy upravil Vladimir Curcic dne ne únor 05, 2006 8:40 pm, celkově upraveno 1 krát
beardie
7865.50 SMM
PříspěvekZaslal: ne únor 05, 2006 8:39 pm    Předmět: Odpovědět s citátem
I wrote "wait 10-40 minutes", so I hope that everybody understands that he should not switch if off
edit: tutorial updated
Vladimir Curcic
PříspěvekZaslal: ne únor 05, 2006 8:46 pm    Předmět: Odpovědět s citátem
Cool!
As I understood the java application px65v5 should be left ON when it finishes calculations. It must be on when you start PapuaUtils (x65Flasher... or similar)
This is just to clarify the things... but you have really done great work translating this for all the people who do not speak Czeh.
beardie
7865.50 SMM
PříspěvekZaslal: ne únor 05, 2006 9:01 pm    Předmět: Odpovědět s citátem
Vladimir Curcic napsal:
yes, I wrote:
2. run the midlet...
4. wait...
5. open papuautils...
7. switch the phone off...
otherway, papuautils couldn't download the keys from the phone
mobile
Založen: 01. 01. 2005
PříspěvekZaslal: so březen 11, 2006 2:09 am    Předmět: Odpovědět s citátem
i have typed the codes manualy and i recieved an eroor when i wanted to generate the skey. it said that the esn was wrong! Neutral another problem was that the java aplication didn`t detect the cable... it was asking "please connect the accesorry" i thoungt that manualy should work ... but it didn`t. i doubt that automaticaly will work...
zoxir
PříspěvekZaslal: so březen 11, 2006 8:34 am    Předmět: Odpovědět s citátem
Use new java midlet px75v1.jar.
HASH: 123456-7890-.....
HASH for PapuaUtils: 123567890... (without "-")
ESN: ABCD-EF12
ESN for PapuaUtils: 12EFCDAB
lunasicc
Založen: 18. 08. 2006
PříspěvekZaslal: pá srpen 18, 2006 8:10 am    Předmět: Odpovědět s citátem
I have a DCA-540 cable; will I be able to use it with this program??
Also, I transfered the px75v5 to my siemens S66(S65) and got all neccessary codes. But when I start up Papua Utilis 0.7.9c and click on px75v5 I get this error:
Awaiting answer from Chaos midlet...
No answer from midlet!
1) Neglected to run midlet px65v5 in phone...
2) At request "Connect Accessory" press button "Px65v5" and connect cable to phone.
3) Wait for the midlet to finish and again press button "Px65v5"...
*Midlet can be found at http://chaos.allsiemens.com/download/px65v5.rar
I followed all your instructions and nothing? What am I doing wrong?
***Also, when I manually type in the HASH, IMEI and ESN and click calculate, the program gives me:
Calculation of keys...
Key not found!
whitewash
Založen: 08. 11. 2005
0.00 SMM
PříspěvekZaslal: pá srpen 18, 2006 10:00 am    Předmět: Odpovědět s citátem
Because you have a DCA-540 cable - that's why it can't communicate with the midlet (and even if it could communicate, it's no use for you, as 540 doesn't communicate with the phone when it's off - all service operations require phone to be OFF while establishing a connection)
lunasicc
PříspěvekZaslal: pá srpen 18, 2006 9:23 pm    Předmět: Odpovědět s citátem
What kind of cable do I need? Also why cant it calculate the skey even when I manually typing in the HASH and ESN?
hungeri
Založen: 21. 02. 2005
PříspěvekZaslal: st listopad 29, 2006 5:02 pm    Předmět: Odpovědět s citátem
If no this kind of question was asked, what to do?
Ok, I've M75, how could I make a loader? x65flasher runs well, but Papua couldn't make a loader for V-Klay, however it could unlock it. Now I have fw05, I also want to enable using shootx65 or something like that, and of course patching.
So what is the method for M75?
Thx in advance![/i]
vdragoslav
Založen: 01. 02. 2006
Telefon: C75, E71
170.64 SMM
PříspěvekZaslal: po leden 22, 2007 11:07 am    Předmět: Odpovědět s citátem
It worked okay using px75v1 and PapuaUtils v0.7.5c; first generated well the ESN and HASH, then PU calculated the SKEY and BKEY, as it was supposed to. I've noticed there's a window for HWID and another one near it, where I chosed my fon from a list (M65=321), as PU downloaded from the fon and showed this info in the large window in the right. From now on I work with the fon powered off; took care to the com1 ('cos PU keeps changing the com port) and pressed "Service Mode" and immediately the red button at the fon. Now there's at least a problem, 'cos I got different messages (among tens of tryings to do the job):
Autostart....
Íåò îòâåòà íà çàãðóçêó!
Ïðîâåðüòå íîìåð ïîðòà, êàáåëü, òåëåôîí, mode!
, other times:
Autostart....
boot not loaded!
Òåëåôîí íàõîäèòñÿ â "Ôîðìàò äèñêîâ?"!
Then "Service Mode" button comes back by itself, displaying what I wrote. I've noticed that, when displaying that text ended "mode!", the bar progress keeps staying at less than a quarter (I left that for an hour and nothing happent) and if I press again the "Service Mode" (and the fon's red button, to reinitialize the job) it displays:
"Booting in Service Mode"...
Òûêàé êíîïó!
and then again:
Autostart....
I have a (chinese, I guess) cable I used to patch my old M55, to which I attached two 15k resistors, to make the PC "see" the 65 serie fons.
Tell me please, what might be the problem here?!?..
Zobrazit informace o autorovi Odeslat soukromou zprávu Odeslat e-mail Yahoo Messenger
Cieniu
Založen: 14. 04. 2006
Bydliště: -Poland- .:Szczytno:. Telefon: EL71 v45 PL I Csl65 v53
PříspěvekZaslal: po leden 22, 2007 5:02 pm    Předmět: Odpovědět s citátem
citace:
Shame on you Brick wall
download english PU
www.forum.siemensiak.pl
AK74
Založen: 09. 02. 2009
Telefon: me45i & m_cx70sw56_elfpac2.3russianretail
110.64 SMM
PříspěvekZaslal: st březen 02, 2011 9:56 pm    Předmět: Odpovědět s citátem
Cieniu napsal:
citace:
download english PU
Phone is in the disc format.
(translation is done through 0:\ZBin\TED\TED.elf)))
my home: http://forum.allsiemens.com
majen99
Založen: 17. 05. 2011
9.44 SMM
PříspěvekZaslal: út květen 24, 2011 11:46 pm    Předmět: Odpovědět s citátem
1.my phone siemens me75 sw22 lg7 stdmap1 dmap 16 variant a700 Sad
2.cable data pl2303hx pin 5,7 short connect 10ohm to ground pin6 cts
3.papuautils 019b
service mode ok
Toto téma je zamknuto bez možnosti úpravy příspěvků a psaní odpovědí    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
Strana 1 z 2
