kilibo kolemjdoucí
Založen: 18. 02. 2006 Příspěvky: 19
Zaslal: ne únor 26, 2006 9:15 pm Předmět: S65 v58 Remove Sub-provider name |
I looked everywhere but I can not find code how to remove second line of provider name
e.g.
First Line: Rogers Wireless
Second: www.fido.ca <- i want to remove only this line?
I found this for S65 v50
;* MainScreen positioning v2 *
; (c) SiNgle, BuG, R KiRiK, arsh0r
; Smelter auto-patch
16B4CF0: 08 12 ; Y - Provider name
16B4D00: 1A 24 ; Y - Sub provider name
169BBAC: A1 A0 ; Y - Time & Date |
D4X (o(^^)o)
Zaslal: ne únor 26, 2006 9:27 pm Předmět: Re: S65 v58 Remove Sub-provider name |
kilibo napsal: | I looked everywhere but I can not find code how to remove second line of provider name
e.g.
;16B4CF0: 08 12 ; Y - Provider name
;169BBAC: A1 A0 ; Y - Time & Date |
_________________ -> Nokia Lumia 800 |
kilibo kolemjdoucí
Zaslal: ne únor 26, 2006 9:32 pm Předmět: Re: S65 v58 Remove Sub-provider name |
davexxxx napsal: | kilibo napsal: | I looked everywhere but I can not find code how to remove second line of provider name
e.g.
davexxxx,
Did you submit reply?
I don't see anything?! |
kilibo kolemjdoucí
Zaslal: ne únor 26, 2006 9:53 pm Předmět: |
Here is the screenshot.
beardie táta fóra
7865.50 SMM
Zaslal: ne únor 26, 2006 10:09 pm Předmět: |
davexxx did it right
you have to comment (write ";" ) in front of the first and third line:
you have to do it so:
kilibo kolemjdoucí
Zaslal: ne únor 26, 2006 11:20 pm Předmět: |
beardie napsal: | davexxx did it right
Okay. Thanks
Well, i did that and nothing changed.
Since 16B4D00: 1A 24 ; Y - Sub provider name is only to tell phone position of sub provider name,
how was this code going to remove/clear the second line?
I need modified code for v58, that will remove second line?! |
D4X (o(^^)o)
Zaslal: po únor 27, 2006 10:23 am Předmět: |
16B4D00: 1A EE ; Y - Sub provider name
try this... _________________ -> Nokia Lumia 800 |
kilibo kolemjdoucí
Zaslal: út únor 28, 2006 12:30 am Předmět: |
davexxxx napsal: | ;16B4CF0: 08 12 ; Y - Provider name
try this... |
Still not working. No changes.
davexxxx
Is this memeory address correct: 16B4D00
Since that was used for fw50, and I have fw58. Maybe that's the problem? |
lacibogi čestný člen
786.46 SMM
Zaslal: út únor 28, 2006 1:45 pm Předmět: |
kilibo napsal: | Since that was used for fw50, and I have fw58. Maybe that's the problem? |
Sure. _________________ C(ME)75
Lasky |
kilibo kolemjdoucí
Zaslal: út únor 28, 2006 4:15 pm Předmět: |
Lasky napsal: | kilibo napsal: | Since that was used for fw50, and I have fw58. Maybe that's the problem? |
Sure. |
Okay then.
Would you happen to know the correct memory address |
786.46 SMM
Zaslal: út únor 28, 2006 4:18 pm Předmět: |
Use this.
kód: | 16B9028: 1A 23 ; Y - Sub provider name |
Lasky |
kilibo kolemjdoucí
Zaslal: st březen 01, 2006 12:30 am Předmět: |
Lasky napsal: | Use this.
Okay, i think we are on the right track
Applying this code moved sub-provider name one row down.
Can we move it either on x axis to the right or left
or on Y axis down. |
D4X (o(^^)o)
Zaslal: st březen 01, 2006 10:50 am Předmět: |
Use this
kód: | 16B9028: 1A EE ; Y - Sub provider name |
kilibo kolemjdoucí
Zaslal: st březen 01, 2006 10:45 pm Předmět: |
davexxxx napsal: | Use this
IT WORKS!
Thanks again you all for helping. |
