steel_in_back kolemjdoucí
Založen: 03. 08. 2007 Příspěvky: 19
6.48 SMM
Zaslal: pá květen 09, 2008 6:37 pm Předmět: question about Gameboy.elf |
Hello, actually i test roms of gameboy for the emulator gameboy.elf in the version 0.91, I like the pokemon yellow and silver.
My first question is; Future versions of this emulator will compatible with the gameboy sounds?
Well my cx65@70 is good but in some games is slow (pokemon silver for example). Can I overclock my mobile with a aplication for more performance or I`m crazy?
Or you have the solution for expand the cache folder?
Thanks for the help |
D4X (o(^^)o)
Zaslal: pá květen 09, 2008 7:17 pm Předmět: |
there is no overclock on x65...
gameboy emulator is very slow on x65 (x75 is much faster)
sounds - ask the author of this elf
I think, the patch is already done or it's possible to make... _________________ -> Nokia Lumia 800 |
6.48 SMM
Zaslal: so květen 10, 2008 6:18 am Předmět: hello |
I need to buy a cx75, but it`s very rare in mexico (too rare...).
Well 8-12 fps not are too bad if I compare the performance with the meboy.jar.
Maybe in a future, a hero find a overclock for a cx65
However the vista tuning is good!  |
D4X (o(^^)o)
Zaslal: so květen 10, 2008 9:39 am Předmět: |
Thx , but I didn't mean x75 (C75, CX75, M75) because it's still x65 HW; I mean S75 or SL75 and BQS equivalents, there is GB much faster  _________________ -> Nokia Lumia 800 |
