:: View topic - FOTO a EL71
FOTO a EL71
iqlogic
109.18 SMM
PostPosted: Fri Dec 29, 2006 3:05 pm    Post subject: FOTO a EL71 Reply with quote
Mam problem s fotenim a nahravanim videa...po malej dobe po zapnuti sa mi uz neda fotit ani nahravat video... pri foteni naskoci len cierna obrazovka a pri natacani videa sa vypne... kraticku mam KINGSTON 512MB... telefon nema ziadne patche ani nic podobne... FW je original od TMO verzia 31
Xperia Arc S @ DoomKerneL Smile
whito
4279.78 SMM
PostPosted: Fri Dec 29, 2006 3:15 pm    Post subject: Reply with quote
bug vo TM FW podla mna Whistle
EDIT: skus prehrat new FW
Motorola Rokr E1
SE P1i
iqlogic
109.18 SMM
PostPosted: Fri Dec 29, 2006 3:16 pm    Post subject: Reply with quote
keby som mal cez co tak aj prepalim... tiez si myslim ze to mobilom nie je ked zo zaciatku to funguje... az asi tak o 5 minutach sa uz fotit neda....
whito
4279.78 SMM
PostPosted: Fri Dec 29, 2006 3:20 pm    Post subject: Reply with quote
jj bude to otazka FW...uz len servisny kablik a ides na to...
Ja mam spraveny z DCA510 Anxious
Motorola Rokr E1
SE P1i
iqlogic
109.18 SMM
PostPosted: Fri Dec 29, 2006 3:27 pm    Post subject: Reply with quote
No ved idem si ho objednat z GSM Cables.... lebo uz ma to nebavi ked s nim nic robit nemozem... Dancing
14311.82 SMM
PostPosted: Fri Dec 29, 2006 3:38 pm    Post subject: Reply with quote
Alebo reklamovať, ak sa dá? Think
iqlogic
109.18 SMM
PostPosted: Fri Dec 29, 2006 3:39 pm    Post subject: Reply with quote
No da sa ale radsej ee.... bo ak mam byt mesiac bez mobilu a tym aj bez icq tak asi zomriem....
whito
4279.78 SMM
PostPosted: Fri Dec 29, 2006 3:52 pm    Post subject: Reply with quote
ja by som ho poslal na zaruku, ved kabel ti tak skoro nepride
Motorola Rokr E1
SE P1i
14311.82 SMM
PostPosted: Fri Dec 29, 2006 3:57 pm    Post subject: Reply with quote
Ak bol mobil cez operátora, vyžiadaj si nejaký na ten čas ako náhradu, dá sa to, niekedy síce so zálohou, ale tá sa Ti vráti.
iqlogic
109.18 SMM
PostPosted: Fri Dec 29, 2006 3:58 pm    Post subject: Reply with quote
No a este detail ako zrusim objednavku v GSMCables??? Som nechtiac potvrdil Confused .... a konecna suma je 923,-Sk takze sa mi to zda nejak moc... ked tu ludia spominali do 750... Crying or Very sad
14311.82 SMM
PostPosted: Fri Dec 29, 2006 4:22 pm    Post subject: Reply with quote
Neviem, nemám skúsenosť, ale cena je vysoká.
Vidím, že niekto ponúka kábel DCA-110 za polovičnú cenu.
raceman69
PostPosted: Sat Dec 30, 2006 5:27 pm    Post subject: Reply with quote
ja som skusal prerobit podla topho DCA 140 ku mobil to rozoznalo potom ako boot-box ale mi to nefakci.nespoji sa len s X65 flasher om a aj to len vie natiahnut info z telefonu vypocita skey stiahne zalohu ff ale zapisovat uz nic...kde moze byt chyba? Question Think
