Stoka543 kolemjdoucí
Založen: 27. 09. 2006 Příspěvky: 3
Zaslal: po leden 15, 2007 12:52 pm Předmět: Extension.cfg(ELFS) |
Can someone tell me all about extension.cfg. I have gameboy emulator on my s75 and i cannot make extension support for gb and gbc.
My gameboy emulator is in 0:\ZBin\GBA\GAMEBOY.elf and this is the code: "gb:0:\ZBin\GBA\GAMEBOY.elf
gbc:0:\ZBin\GBA\GAMEBOY.elf"
What am i doing wrong?
I tried with Tex editor, Cfg Editor but its the same, the txt,gbc,gb,bcfg files are not usable! |
mart22 elfmaster
56669.28 SMM
Obeebok kolemjdoucí
Založen: 29. 05. 2006 Příspěvky: 2
Zaslal: st leden 24, 2007 9:58 am Předmět: |
Could you explain it? What should I do? What is ExtD.elf or ExtDx32.elf and where can I find it? |
