dnteam začátečník
Založen: 16. 12. 2006 Příspěvky: 34
Zaslal: út únor 13, 2007 9:38 am Předmět: Guide to update S88, E61, EF61, CF61, S81, EF91 |
here is a little rewiev
on how to update this phones
first u need and usb-serial controller cable
looks like this
then what u need then is S88 usbcabledrivers
click install whitout cable plug in
then follow the step when prog ask u to connect the cable u do it and windows will look fore new hardware and install it like usb-serial controller
then u open program to install new Firmware whit phone must be turn on
plug in cable and then load the mot files u need and push start when u push start then turn off the phone and keep the power of buttom down and the cable will find the phone and start the update
good luck all
BTW i have last night updatet my CF61 ans S88 |
