dancas2 kolemjdoucí
Založen: 21. 09. 2005 Příspěvky: 28
Zaslal: so únor 24, 2007 8:28 pm Předmět: Video rec in CSL65 |
Hello...
In the time that i've modified my phone, always i've ask me if it's possible rec video in CSL65...
I understand that isn't possible because the camera don't support them, but, i've be reading in this forum, and i've found a post that says something about them, but in c72@SL65..
My question is if exist any process to do this....
I've tried to install standart map of SL65 v50, but, this doesn't work...
I think that is not possible, but, you know more than me...
Thank's...
Bye |
iver56 kolemjdoucí
Založen: 01. 07. 2006 Příspěvky: 6
Zaslal: pá březen 16, 2007 12:07 pm Předmět: |
I once tried to convert my C72 to SL65, but it didn't work.
When I tried to load back my original fubu, it stopped at 60% and the phone was dead (comatozed)...
I think that it's only possible to convert C65 (and not C72) into SL65. |
dancas2 kolemjdoucí
Zaslal: so březen 17, 2007 2:47 pm Předmět: |
But if you enter a standaart map of sl65 into your phone, you'll can rec in your c72..
Bye |
