witiko rozumbrada
Založen: 25. 08. 2005 Příspěvky: 349
Zaslal: so duben 14, 2007 5:10 pm Předmět: |
matus201 napsal: | to sa deje na kazdom siemense ... je to dost nelogicke.. mozno by na to mohol byt patch.. |
To je tím, že máte verzi beta 1.0 a už dávno je venku beta 5.1, která toho umí mnohem víc a má mnohé bugy fixované.
Viz.:
kód: | TO DO
* !!Suprise!! (MAYBE for Beta 6+)
* More than browsing for Internal
* Language Change
Beta 5.1 25.02.2007
+ Bugfix: Bug at GET progress.
Beta 5 19.02.2007
+ Improved speed. Both Browsing & Transferring.
+ Delete Files & Folders. (Sometimes Requires Permission)
+ Create Folders.
+ Alphabetical sorting with Quicksort Algorithm.
+ File Properties.
+ Functions via keypad.
+// 0 - Properties
+// 1 - Create Folder
+// 2 - Up
+// 5 - Get
+// 8 - Down
+// c - Delete
+// Back - (Guess what?!? ) Back
+// Tested on K750
- Writes NULL bytes (hex:00) to files, randomly between everywhere.
- Bug at GET progress.
Beta 4.1 29.01.2007
+ Very little 2 bugfix.
- Unicode Problem.
Beta 4 29.01.2007
Logging Ready. If you have problems, send here the log. Every time you open MiyuX, log file be refreshed. Log file is in your incoming path.
+ Bugfix: Damn Connection Problem.
+ Bugfix: Computers still respond SERVICE UNAVAILABLE for an unknown reason.
+ Bugfix: Just works with K700.
+ Connection codes rewritten Again. Browsing is smooth.(Tested with K700 and Computer)
+ Lots of optimizations in code.
+ Logging.
Beta 3 05.01.2007
+ Bugfix: Duplicates folder contents sometimes.
+ Bugfix: Title should become the folder you're browsing, but it doesn't work properly.
+ Bugfix: Cannot read Ascii chars like çığöşü.
+ Can Get Files.
+ Can Put Files. (Warning: Example, If you're in 'other' folder on remote, and you wanted to put a picture, It won't go to the 'other' folder.It's not MiyuX's fault anyway.)
+ Internal File Browsing for Get/Put.
+ Some menu fixes(Example: You're not going to see Disconnect option until you're connected).
- Computers still respond SERVICE UNAVAILABLE for an unknown reason.
- When browsing, title just stay's as the Device name.
- Just works with K700.
Beta 0.2 01.01.2007 Happy New Year!!
+ Bugfix: Disconnect doesn't work.
+ Connection codes rewritten. Browsing is smooth. (Tested with K700i)
+ Can Save & Load & Delete devices.
+ OBEX Response Codes
- Computers respond SERVICE UNAVAILABLE for an unknown reason.
- Duplicates folder contents sometimes.
- Title should become the folder you're browsing, but it doesn't work properly.
Beta 0.1b
+ Bugfix: Crashes when a folder contains too much, more than 15-20 files or folders.
Beta 0.1
+ First Release
+ Supports browsing files and folders.
- Disconnect doesn't work.
- Crashes when a folder contains too much, more than 15-20 files or folders.
- Cannot read Ascii chars like çığöşü. |
Download: kód: | http://www.sendspace.com/file/ix75vp |
_________________ Siemens není špatný, to jen Benq je zlý! |
Fijo666 rozumbrada
Založen: 20. 10. 2006 Příspěvky: 333
382.24 SMM
Zaslal: so duben 14, 2007 7:32 pm Předmět: |
witiko napsal: | matus201 napsal: | to sa deje na kazdom siemense ... je to dost nelogicke.. mozno by na to mohol byt patch.. |
Nejde to spustit, vypisuje Neznamy autor certifikatu. Instalacia neuspesna _________________ N95, 2GB SD fw 30.0.015 + hack sw
SX45i + 32MB MMC
jenda^^ čestný člen
Zaslal: so duben 14, 2007 7:55 pm Předmět: |
Tak do telefonu nenahrávej JAD _________________ Teď mám: Nexus S
Fijo666 rozumbrada
382.24 SMM
Zaslal: so duben 14, 2007 8:00 pm Předmět: |
jenda.69 napsal: | Tak do telefonu nenahrávej JAD |
spravil som tak ale teraz pise ze Chybaju Java APIs! Instalacia neuspesna _________________ N95, 2GB SD fw 30.0.015 + hack sw
SX45i + 32MB MMC
ccd98 táta fóra
8031.04 SMM
Zaslal: ne duben 15, 2007 10:23 am Předmět: |
Ta 5.1 je nějaká porypaná; na SC (Supercrooo? ) jsem našel betu 5 a pak nějakou odnož téhle verze, o které se tam mluvilo v souvislosti s CX75, takže tahle verze možná jede na starších Siemensech.
Mně šly na S75 spustit obě; v provozu je budu ale moct vyzkoušet až zítra. _________________ S LXXV
Naposledy upravil ccd98 dne ne duben 15, 2007 1:32 pm, celkově upraveno 1 krát |
coyotelada22 všeználek
Zaslal: ne duben 15, 2007 1:23 pm Předmět: |
Fijo666 napsal: | jenda.69 napsal: | Tak do telefonu nenahrávej JAD |
spravil som tak ale teraz pise ze Chybaju Java APIs! Instalacia neuspesna |
meviem ale toto mi tiez ukazuje, taktiez som aj ten program certifikoval
pre moju S 65 bohuzial nejde _________________ > Siemens A 50 podsvietenie biele
> 1 GB MS DV RS MMC Apacer
> 16 GB Micro SD class 2
>JBenchmark1 27 638 bodov
Fijo666 rozumbrada
382.24 SMM
Zaslal: ne duben 15, 2007 5:00 pm Předmět: |
ccd98 napsal: | Ta 5.1 je nějaká porypaná; na SC (Supercrooo? ) jsem našel betu 5 a pak nějakou odnož téhle verze, o které se tam mluvilo v souvislosti s CX75, takže tahle verze možná jede na starších Siemensech.
Mně šly na S75 spustit obě; v provozu je budu ale moct vyzkoušet až zítra. |
Mne na S65 nejdu obe _________________ N95, 2GB SD fw 30.0.015 + hack sw
SX45i + 32MB MMC
P4priX ostřílený diskusník
Založen: 25. 12. 2004 Příspěvky: 538
128.03 SMM
Zaslal: pá srpen 17, 2007 8:56 pm Předmět: |
Zpátky k BT_Info... Když to zkouším z EL71 -> k750i (autorizovaný a důvěryhodný) tak se mi to připojí, ale žádná funkce nefunguje (ani Informace)
Nemáte někdo zkušenosti s funkcí téhle aplikace na Sgold3 ? _________________ Siemens C60 -> Siemens M65 -> BenQ-Siemens EL71 -> BenQ E72 -> HTC Touch Pro -> HTC Desire Z -> SE Xperia Mini Pro |
stream řád zlaté antény
5506.00 SMM
Zaslal: čt září 06, 2007 3:21 pm Předmět: |
pujde bt_info i na telefonech který nemaj HW bluetooth? ... podle článku o něco víše je návod na bt_info přez irda _________________ Trance, disko forever :-)
I love mobile tuning ...
sssugi táta fóra
667.50 SMM
Zaslal: čt září 06, 2007 3:56 pm Předmět: |
slape EL71-K600i
skoda ze ale nejde prezeranie suborov _________________ Benq-Siemens EL71+DCA 110+Micro SD 512Mb
Siemens M65+S65+C55+DCA 510 |
pip@ administrátor
Zaslal: čt září 06, 2007 4:10 pm Předmět: |
stream napsal: | pujde bt_info i na telefonech který nemaj HW bluetooth? ... podle článku o něco víše je návod na bt_info přez irda |
podle mě ne, skoušel jsem to na M65, a tam se to zasekne v podmenu hledat asi právě proto, že nemá BT _________________ Siemens: C35i, M35i, SL45i (aka U35), ME45 (aka Panther), C65 (aka Hera), M65 (aka X-cite), S75 (aka Minos), SG75 (aka Wolf4), SXG75 (aka Wolf5), EF81 (aka Kestrel)
5506.00 SMM
Zaslal: čt září 06, 2007 4:17 pm Předmět: |
pip@ napsal: | stream napsal: | pujde bt_info i na telefonech který nemaj HW bluetooth? ... podle článku o něco víše je návod na bt_info přez irda |
podle mě ne, skoušel jsem to na M65, a tam se to zasekne v podmenu hledat asi právě proto, že nemá BT |
škoda... zkusim si s tou aplikací pohrát aby byla jen pro irda _________________ Trance, disko forever :-)
RDT táta fóra
6964.82 SMM
Zaslal: út září 11, 2007 2:56 pm Předmět: |
Kdyby někdo reuploadnul tu betu 5.1, byl bych docela vděčen. Na SXG mi to totiž funguje . Chěl jsem to stáhnout na (asi) oficiálním fóru, ale je třeba registrace, která mi nějak nejde dokončit ( http://forums.se-nse.net/index.php?showtopic=5653 ) Díky _________________ | Právě používám: HTC Touch HD |
erikerik věrný diskusník
Založen: 04. 08. 2007 Příspěvky: 491 Bydliště: NITRA
Zaslal: út září 11, 2007 3:42 pm Předmět: |
RDT napsal: | Kdyby někdo reuploadnul tu betu 5.1, byl bych docela vděčen. Na SXG mi to totiž funguje . Chěl jsem to stáhnout na (asi) oficiálním fóru, ale je třeba registrace, která mi nějak nejde dokončit ( http://forums.se-nse.net/index.php?showtopic=5653 ) Díky |
ja us som tam no neviem ako som sa k tomu dopracoval...ked na to dojdem dam vediet _________________ SIEMENS C 75 , CX65 @ CX70 , S 65 , cx 75 , S75
SXG 75 ,
Nokia 5800 XM - šit |
Zaslal: út září 11, 2007 3:53 pm Předmět: |
mam to:hore najdi register...ked ti vihodi tabulku tu si nevsimaj...daj ok ...potom nad coppa form najdes continue...potom dole zaskrtnes male okienko i have read.........okienko register dole.......vipises a das dole submit my registracion....potom si us zaregistrovani.... _________________ SIEMENS C 75 , CX65 @ CX70 , S 65 , cx 75 , S75
SXG 75 ,
