:: Zobrazit téma - MCX70 Black Diamond v1.1 (M65 as CX70 v56)
Toto téma je zamknuto bez možnosti úpravy příspěvků a psaní odpovědí    Obsah fóra -> Tuning
delpierwin
Založen: 27. 12. 2007
519.20 SMM
PříspěvekZaslal: po leden 12, 2009 9:35 am    Předmět: MCX70 Black Diamond v1.1 (M65 as CX70 v56) Odpovědět s citátem
Updated 13 January 2009, finally finished collect all needed resources for complete release of my latest patch pack.
MCX70 Black Diamond v1.1 @ M65 crossgraded to CX70 v56
Based on M65@CX70xp: Beyond the Limit! by Mas Qunto (Jan-08), recompiled for BlackDiamond (Jan-09)
Capture Picture :
Patch List :
------------------- Main Patches -----------------
01. API v14
02. AudioHook v3
03. Function Library v70418
04. Big Function Library v71117
05. WAV ADPCM All Freq.
06. Mainscreen Dispather v3.1
07. Elf Loader v2.3
08. Master Patch v14
09. Cut Heap
10. Pictures add-on v5.1
------------------ Independent Patches -----------------
11. Open closed EEPROM Block
12. Open Disk Forever
13. Java Acceleration
14. Show File Extension in card Explorer
15. Disable some messages
16. Remove Softkey from mainscreen v2
17. No start sound in Video rec
18. Disable Aircraft Check
19. Change disk names in menu
20. Change delimiter in menu
21. AutoRedial forever with selected pause
22. Video rec 1 min
23. Setup illumination by 5%
24. Smooth scrolling of long names
25. Smooth illumination turn-on
26. Compress jpeg with maximum quality (100% instead of 75%)
27. Keypad Acceleration
28. Enable Developer Menu
29. Call list saving when SIM is changed
30. Enable Band Selection
31. Enable Built-In WV Client (ICQ AIM)
32. Goto mainmenu from anywhere by pressing ###
33. re-enables "Hide ID for next call"
34. Show current time during call v1.1
35. SVS, SMS view shortcut
36. Disable MMI logging
37. Disk selection menu © SiNgle
38. Toggle HandsFree without question
39. Delete Read-Only Files from Card-Explore
40. Disable AUMA And UDIAL Debug
41. RMWKL Read Message when Key Locked
42. DSFS Directly Send Flash SMS V1.1
43. Change some *#06@ info
44. Turn phone ON while offline charging v1.0
45. Mark Files by Left SoftKey in Card-Explorer
46. No SIM Card Phone Operation
47. Add Elf-Folder to the MyStuff
48. Remove the comma between name and surname in address book
49. Disable ringtone "Net found" (3beep)
50. Enable Vibra With Plugged-In Cable
51. Turn on by Alarm clock
52. Disable Retarget Exit
53. Show Hidden Files In Card-Explorer By Default © 1nvisible
54. Change dialing ringtone "No connection" © B-727
55. Disable More Nasty Debug © benj9
56. Change sw version to XX
57. Disable ASP
58. Disable displaying "netsearch" [!]
59. Vibra on/off when keypad locked/unlocked
60. Start elf on a shortcut
61. MyStuff = Disk Menu
------------------ MP-Patches -----------------
01. Date at the bottom of maincsreen as "We, 11 May"
02. Mainscreen Changer v1.3
03. Music Progress Bar Changer
04. Change Illumination Turn Off Time
05. Keylock Beep
06. Short Vibra at connect
07. Drop Call On Certain Time
08. BlackList v3 beta
09. Missed Events Indicator v2.1 CX70 Ed.
10. Extra Info on ProgressBars
11. TextInfo on The Mainscreen
Change Language Pack:
01. SuperFonts
Download Link :
MCX70 BlackDiamond v1 (Updated 13-Jan-09)
Bugs :
So far so good Very Happy
Update History :
v1.1 (13-Jan-09, 14:00)
*Change to diamond turn off skins
*Change to diamond volume control image
v1 (13-Jan-09, 00:00)
*First release, v1 download link
Thanks
SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM
Naposledy upravil delpierwin dne út leden 13, 2009 8:14 am, celkově upraveno 4 krát
Založen: 01. 03. 2007
PříspěvekZaslal: po leden 12, 2009 2:07 pm    Předmět: Odpovědět s citátem
wow Shocked great Applause
When will be available for download?
delpierwin
519.20 SMM
PříspěvekZaslal: út leden 13, 2009 5:25 am    Předmět: Odpovědět s citátem
Thank You, resources updated Very Happy, see above
SiemensXP | My Blog
fish
Založen: 06. 11. 2005
97.20 SMM
PříspěvekZaslal: so leden 24, 2009 6:39 pm    Předmět: Odpovědět s citátem
is coooool Wink
and here + 4 u bro Wink
umim malo cesky =)
i collect tnns and all icons here and still i do XX-MSP more a few =)
with pleasure i'll place on madfish-company.com ur tngs Wink successes and a creative 2 u! i wait ur works Wink
tunings icons tng sources and more
Založen: 11. 08. 2005
133074.34 SMM
PříspěvekZaslal: so leden 24, 2009 9:15 pm    Předmět: Odpovědět s citátem
Yeah, that's great...
I love black color and HTC Diamond is cool..
I Loaded it in my M65 Smile
What about mp3 player with skin which looks like HTC Audio manager?
btw. -> Mr. Green
delpierwin
519.20 SMM
PříspěvekZaslal: út leden 27, 2009 2:51 am    Předmět: Odpovědět s citátem
Thank You pip@, it's nice to see You again Very Happy
About HTC Audio Manager, i search spare time to do that, thanks for nice idea.
About, pics, nice Very Happy i would get my Kaiser as Your Kaiser ROM had.
SiemensXP | My Blog
Založen: 03. 03. 2006
39.00 SMM
PříspěvekZaslal: ne srpen 02, 2009 6:53 pm    Předmět: Odpovědět s citátem
It´s final version?
Toto téma je zamknuto bez možnosti úpravy příspěvků a psaní odpovědí    Obsah fóra -> Tuning Časy uváděny v GMT + 1 hodina
