:: View topic - SL91 a BREW cez BT
SL91 a BREW cez BT
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Telefony na platformě BREW
whito
4279.78 SMM
PostPosted: Tue Jun 26, 2007 10:55 am    Post subject: SL91 a BREW cez BT Reply with quote
potrebujem sa uistit, ked som sa cez BT adapter xcel dostat do BREW, tak som musel cez kabel nahrat *.bar subor. Teraz budem mat SL91 a tiez xcem nejaky ten tunnig, preto sa potrebujem dostat do BREW a DCA-140 este nemam. Preto xcem vediet, ci ma SL91 standardne nastavene BREW cez BT, alebo tam treba nakopirovat cez kabel ten bar?
Motorola Rokr E1
SE P1i
whito
4279.78 SMM
PostPosted: Thu Jun 28, 2007 11:25 am    Post subject: Reply with quote
takze kecal som s kraze1984 a on mi napisal toto..."For Sl91 you need other bar then for sxg/ef" Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
takze do SL91 sa cez BT nedostanem do BREW Crying or Very sad
Motorola Rokr E1
SE P1i
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Fri Jun 29, 2007 6:50 pm    Post subject: Reply with quote
LOCK a pokud bude chtít autor topicu něco dalšího nechť si založí další topic.
-> Nokia Lumia 800
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Telefony na platformě BREW All times are GMT + 1 Hour
