alex61 kolemjdoucí
Založen: 05. 03. 2007 Příspěvky: 12
Zaslal: út červenec 17, 2007 1:37 pm Předmět: HELP ON HOW TO INSTALL ELF's in E71 |
Guys is it possible to tell me (with all the details) how to install elf's and where to find the appropriate programms? My phone is E71 ver45. THANK YOU in advance! |
ccd98 táta fóra
8031.04 SMM
Zaslal: ne červenec 22, 2007 5:01 pm Předmět: |
Hi 8)
How to patch E71 was described very recently on MoDoPo.com: HOW TO (German).
For better understanding you could translate the whole text by the great Google Translator.
ElfPack 2.2 for E71v45 is here.
If you are a German, it will be no problem. There could be a similiar "How to" in Russian language, too, because Germans and Russians are the main pioneers in patching new Siemenses.
Good Luck _________________ S LXXV |
alex61 kolemjdoucí
Zaslal: po červenec 23, 2007 7:23 am Předmět: |
ccd98 thank you my friend, I am Greek. I will try to do my best but the translation is difficult. I understand English but Russian and German nothing. |
TUFF Stough kolemjdoucí
Založen: 13. 02. 2007 Příspěvky: 27
43.28 SMM
Zaslal: po červenec 23, 2007 12:07 pm Předmět: |
For v2.2 and above, it's very tricky compared to v2.0 and below that. Until now, I never succeed on applying it to my S75. It always turns out dead, so I have to undo the patch.
As for E71, it requires test point as been pointed by ccd98. _________________ From Indonesia with Love. Viva Siemensmania! |
alex61 kolemjdoucí
Zaslal: po červenec 23, 2007 12:56 pm Předmět: |
Using patches and elf's is the same thing? Both need test point or buying the code for E71? (Then I have to forget everything. With my S55 was very easy) |
43.28 SMM
Zaslal: út červenec 24, 2007 4:33 am Předmět: |
You only can apply elfpack thru patch. This means you'll need to perform testpoint in order to bypass the bootcore so you can connect your E71 with patching application such as VKlay.
There's another way to connect it to VKlay, but I'm not sure how to do it. May be you can search this forum using keyword 'buying bootkey'?
Funny that you've bring up this elfpack, I also would like to know, is there anybody in this forum that succesfully update the elfpack 2.0 to 2.2 and above? _________________ From Indonesia with Love. Viva Siemensmania! |
alex61 kolemjdoucí
Zaslal: út červenec 24, 2007 5:44 am Předmět: |
Thanks TUFF Stough. If I buy a key what next? Where can I find and what to do then?
By the way does anybody here know how can I listen to the radio through the phone's speaker and not through the handset's speaker? |
43.28 SMM
Zaslal: út červenec 24, 2007 7:50 am Předmět: |
I'm afraid that I'm not capable to provide you the solution step-by-step.
There are still further steps to be followed once you get the bootkey, such as calculate the Skey and generate ke bootloader for VKlay.
After that, you're still need to apply the patches one by one to avoid sudden error.
To be able to listen the radio directly from speaker-phone, you'll need to apply this patch:
kód: | ;* Play radio on handset instead of headset *
;(c) Miha_r
;Version: 1-MP
; ready for ELFPack v2.2+
;065B178: 0124002A C34CA047 ; E71v41
;065B484: 74680A0D00000000 680A0D00016E06A0 ; E71v41
065B0AC: 0124002A C34CA047 ; E71v45
065B3B8: 74680A0D00000000 680A0D00016E06A0 ; E71v45
#pragma enable old_equal_ff
0066E00: 01B50848C4DF06D004480078002802D0
0066E10: 0024002A01BD0124FBE7C046C44EEFA8
0066E20: 0xB1C2D3E4,0x0000FE00,0000000000000000,"\
{p=`Radio on Handset` cp=Miha_r id=FE00 ver=1}",00
#pragma disable old_equal_ff |
It's master-patch based, so you'll need to apply master-patch first (and all other patches related to master-patch). _________________ From Indonesia with Love. Viva Siemensmania! |
