adigehalil začátečník
Založen: 07. 07. 2006 Příspěvky: 34 Bydliště: sakarya/türkiye
Zaslal: so srpen 04, 2007 6:27 pm Předmět: urgent...: EL71 FF problem |
a friend wrote my fubu to his el71. now he can't power on it. after pressing the power button there is only a bip. he doesn't have bootcore and eeprom backups or fubu. what can we do to repair it...? |
Orpheus čestný člen
14900.34 SMM
Zaslal: so srpen 04, 2007 10:27 pm Předmět: |
You need to unlock the phone.. then youll get it to work |
Zaslal: ne srpen 05, 2007 6:50 pm Předmět: |
how to unlock it...?
i searched in gsmhosting.
citace: | Use the Attached File (EL71 v9) open with hexeditor and enter ur Hash and IMEI
Save the New bcore and Flash with Vklay
Set VDown is in Adress 0x03E020 |
i found this and he applied. after that he lost the connection with v-klay and papuautils... |
Orpheus čestný člen
14900.34 SMM
Zaslal: ne srpen 05, 2007 9:03 pm Předmět: |
wtf? you edited something in hex and burned to bcore? The phone is probably dead..
All you needed to do is to open the newest x65, x75 Papua Utils 0.9.1 EN and in the "Various" section of the program click on the "5008 Unlock" button.
Unlocking the phone means, you burn your IMEI to EEPROM so its the same as in BOOTCORE. If they are the same, the phone turns on, if not, it beeps. |
Zaslal: ne srpen 05, 2007 9:11 pm Předmět: |
but he had written the fubu including bootcore... |
Orpheus čestný člen
14900.34 SMM
Zaslal: po srpen 06, 2007 9:03 am Předmět: |
He wrote the bootcore also? How is that possible? V_klay is default set not to write the bootcore. Well.. the phone is dead, you could try to make a testpoint if some exists |
P4priX ostřílený diskusník
Založen: 25. 12. 2004 Příspěvky: 538
128.03 SMM
Zaslal: po srpen 06, 2007 9:16 am Předmět: |
Yea, testpoint exists... I did make one _________________ Siemens C60 -> Siemens M65 -> BenQ-Siemens EL71 -> BenQ E72 -> HTC Touch Pro -> HTC Desire Z -> SE Xperia Mini Pro |
Zaslal: út srpen 07, 2007 4:51 pm Předmět: |
thanks...
he gave it to service... |
