maxi-cx75 kolemjdoucí
Založen: 24. 11. 2006 Příspěvky: 8 Bydliště: Poland
Zaslal: pá srpen 31, 2007 3:36 pm Předmět: [CX75v25] Problem with elfs... |
--== ENGLISH ==--
Hi,
I've got a problem with elfs. I've been applied APIv14, FL, BFL, KeyHook, SWI-Hook & Elfpack 2.0 (I haven't got MP14 'cause it was a conflict with Elfpack). The most of elfs works correctly, but it's a problem. Phone isn't reading extension.cfg, if I copy ExtD.elf into 0:\ZBin\Daemons it shuts down after net searching.
It was two errors while applying patches: in APIv14 [FWRITE32] and SWI-Hook some data in phone was like new data in patches, but it shouldn't generate errors.
Have U got any ideas?
--== POLSKI ==--
Cześć,
Mam problem z elfami. Wgrałem APIv14, FL, BFL, KeyHook, SWI-Hook i Elfpack 2.0 (nie mam MP14, bo konfliktuje z Elfpackiem). Większość elfów działa, ale jest problem. Telefon nie czyta extension.cfg, jak skopiuję ExtD.elf do 0:\ZBin\Daemons to wyłącza się po szukaniu sieci.
[ZRZUT POWYŻEJ]
Były dwa błędy przy wgrywaniu patchy: w APIv14 i SWI-Hook niektóre dane w telefonie były takie same jak nowe dane w patchu, ale to nie powinno powodować błędów.
Czy ktoś ma jakiś pomysł? _________________ AlleJaja.yoyo.pl admin
DHTML & PHP programmer
Vista Premium user
P O L A N D ! ! !
Naposledy upravil maxi-cx75 dne so září 01, 2007 3:46 pm, celkově upraveno 1 krát |
TUFF Stough kolemjdoucí
Založen: 13. 02. 2007 Příspěvky: 27
43.28 SMM
Zaslal: so září 01, 2007 2:12 am Předmět: |
AFAIK, elfpack is not compatible with SWI-hook. For full compatible with MP, use elfloader.
As for extension.cfg, should be in folder ETC, not in Daemon.
CMIIW. _________________ From Indonesia with Love. Viva Siemensmania! |
Zaslal: so září 01, 2007 3:40 pm Předmět: |
i'll try to remove SWI Hook.
extension.cfg is in ZBin\etc, ExtD was in ZBin\Daemons
[EDIT]
ExtD still doesn't work, phone isn't reading extension.cfg. I don't need MP, last time I've installed elfloader it was same problem like with MP+Elfpack _________________ AlleJaja.yoyo.pl admin
Vista Premium user
P O L A N D ! ! ! |
