:: View topic - jak odblokovat kod tel. A75 ?
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Odblokování
chude
0.00 SMM
PostPosted: Sun Oct 28, 2007 9:29 am    Post subject: jak odblokovat kod tel. A75 ? Reply with quote
jak odblokovat kod tel.A75 ? pres jokera mi to nejak nejde .Mel bych pouzit testpoint ? Asi problem s Skey.
Poradi mi nekdo ?
Diky za pripadne odpovedi.
PostPosted: Sun Oct 28, 2007 10:10 am    Post subject: Reply with quote
Tu bolo nieco pisane, ale mam obavu, ze musis urobit TP.
chude
0.00 SMM
PostPosted: Sun Oct 28, 2007 10:13 am    Post subject: Re: Reply with quote
Zdravim Mario , ale testpoint sem jeste nikdy nedal. Obrazek TP je tak trochu
nesrozumitelnej.nevim co mam spojit .
PostPosted: Sun Oct 28, 2007 10:17 am    Post subject: Reply with quote
Stačí sa k tomu bodu dostať a prerušiť tú dráhu (napr. ihlou vyškriabať) a potom už len pokračuješ, podla návodu - Joker wink
chude
0.00 SMM
PostPosted: Sun Oct 28, 2007 10:20 am    Post subject: Re: Reply with quote
ok ale nevim jestli ho mam potom zase zapajet .no nic jdu to testnout .
PostPosted: Sun Oct 28, 2007 10:21 am    Post subject: Reply with quote
Musí to ostať prerušené, bude aj tak naďalej fungovať, ak to spravíš správne wink
chude: OK držím Applause
chude
0.00 SMM
PostPosted: Sun Oct 28, 2007 10:22 am    Post subject: Reply with quote
ok. drz mi palce
chude
0.00 SMM
PostPosted: Sun Oct 28, 2007 11:04 am    Post subject: Re: Reply with quote
Tak testpoint se mi zdaril a je po problemu !!!Jen tu jehlu si vemte pevnejsi ten spoj drzel docela dost.
Tady je dukaz :
Vypocet skey:
Start...
Loading BootsModel(A75)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com6 460800 BAUD: Ok.
SIEMENS A75 lg3 Sw41
Soft FlashID: 0001/220C
FlashID: 0001/227E-220C-2201
Flash Size: 8Mb, WriteBuffer: 32 bytes
Region(1): Blocks 128, Size 64Kb
Start EEPROM segments at addres 0xFC0000
FSN: AFDB1268 -> PhoneID: 6812DBAF
OTP IMEI: 356475000038657
HASH: FAE5741806728C0009B12568684B7B8A
Boot terminated.
Test and Calc Skey...
BOOTKEY: C57DD331BD23F730042CC406BB77C6AD
SKEY: 57497291
prepocet klicu:
Start...
Use OTP IMEI: 356475000038657
USE SKEY: 57497291
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
BCORE HASH is equivalent - not change.
Read EEPROM addr: 0xFC0000 size: 0x030000...
EEPROM backup in ".\Backup\A75lg3Sw41_EEPROM_071028105123.bin" file.
Write EEPROM addr: 0xFC0000 size: 0x030000...
Change BOOTKEY - Ok.
Change EEP0076 - Ok.
Change EEP5009 - Ok.
Change EEP5077 - Ok.
Change EEP5121 - Ok.
Change EEP5122 - Ok.
Change EEP5123 - Ok
Diky vsem na Siemensmanii.
@urel
595.45 SMM
PostPosted: Sun Oct 28, 2007 11:07 am    Post subject: Reply with quote
Gratulujem Applause Applause
Takže LOCK
Siemens večne živý.
My tuning
@urel OS Hacker Edition EL71
@urel Mac OS S65
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Odblokování All times are GMT + 1 Hour
