prod kolemjdoucí
Založen: 02. 11. 2007 Příspěvky: 1
Zaslal: pá listopad 02, 2007 12:34 am Předmět: How to remove and change cover from my BenQ-Siemens C81 ??? |
Hello , I'm very confused and angry because i dont know how to remove and change my cover from Benq-Siemens C81 .This phone is very good ang 'powerfull' but my cover is little bit damaged ..
I search in internet but this site - www.siemensmania.cz is best !
I Think that i find answer in this board..
Greetingz from Lodz , Poland |
juraset kolemjdoucí
Založen: 06. 07. 2006 Příspěvky: 12
Zaslal: čt leden 24, 2008 10:00 am Předmět: I translate it . . . and maybe someone help you |
I don't know your mobil type,but I can help at least with translate.
Maybe someone doesn't understandt what you meant and just he or she can help.
Translation / Překlad:
Jsem velmi zmateny a rozcileny, protoze nevim jak rozdelat a vymenit kryt na Benq-Siemens C81. Telefon je skvely, ale muj kryt je trochu poniceny ..
Nasel jsem na internetu tenhle vas web - www.siemensmania.cz a je nejlepsi!
Myslim, ze tady najdu odpoved .. |
D4X (o(^^)o)
Zaslal: čt leden 24, 2008 11:54 am Předmět: |
If the phone has same screws as other phones (Torx 5), try remove them with Torx5 screwer _________________ -> Nokia Lumia 800 |
delpierwin badatel
Založen: 27. 12. 2007 Příspěvky: 146 Bydliště: Sukabumi, Republic of Indonesia
519.20 SMM
Zaslal: pá leden 25, 2008 2:18 am Předmět: |
It's not a tutor to open casing of C81, but it's pdf's document that describe part of C81 when it's deassembled. Link Here _________________ SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM |
