:: View topic - C75 - kopirovanie zoznamu
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x72, x75
markus48
PostPosted: Mon Nov 26, 2007 7:17 pm    Post subject: C75 - kopirovanie zoznamu Reply with quote
zdravim,
potreboval by som prekopirovat kontakty zo SIM karty do telefonu
navod som si pozrel ale tam som to nenasiel a v siemensoch sa nevyznam(je to telefon priatelky)
edit. nemam servisny ani iny kabel
@urel
595.45 SMM
PostPosted: Mon Nov 26, 2007 7:28 pm    Post subject: Reply with quote
Je to strašne jednoduché:
Dostaneš sa do -Telef. zoznamu- označíš čísla ktoré chceš prehodiť na Simku a klikneš: -Voľby- a dáš -Kopíruj do- a potom klikneš -Ano- a máš čísla v C75 wink
Siemens večne živý.
My tuning
@urel OS Hacker Edition EL71
@urel Mac OS S65
markus48
PostPosted: Mon Nov 26, 2007 7:30 pm    Post subject: Reply with quote
super dikes
PostPosted: Mon Nov 26, 2007 7:38 pm    Post subject: Reply with quote
Niekedy treba citat aj manual co je k mobilnemu telefonu. On tam totiz nie je pre srandu.
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x72, x75 All times are GMT + 1 Hour
