siesea kolemjdoucí
Založen: 27. 08. 2007 Příspěvky: 4
Zaslal: st únor 13, 2008 3:18 am Předmět: |
hi,unfortunately, I can't download the file on that website |
delpierwin badatel
Založen: 27. 12. 2007 Příspěvky: 146 Bydliště: Sukabumi, Republic of Indonesia
519.20 SMM
Zaslal: st únor 13, 2008 4:31 am Předmět: |
Which link siesea? _________________ SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM |
delpierwin badatel
519.20 SMM
Zaslal: st únor 13, 2008 6:30 am Předmět: |
Sorry i had a question, i use sMenu 9.0 to get transparent background image, but things won't do exactly, here's my capture of the problem :
Menu is stuck down and not laying vertically, i use this setting parameters on menu.cfg :
;this is simple menu config
Price :0.00 $
Copiright :captain_SISka 2007
;data here
MainBGimg :bg.png
ItemTopImg :
ItemImg :
ItemBtmImg :
ArrowItemTopImg :
ArrowItemImg :
ArrowItemBtmImg :
ItemOneImg :
StartButtonImg :
MainCursorImg :mcursor.png
SubCursorImg :
ItemColor :64FFFFFF
ItemBorder :6400000F
SmItemColor :64FFFFFF
SmItemBorder :64000000
SelItemColor :6400FFFF
SelItemBorder :64000000
SmSelItemColor :640000FF
SmSelItemBorder :64000000
X0 :0
Y0 :21
Item_h :14
ItemXofsMain :2
ItemXofsSub :2
ItemYofsMain :10
ItemTextXofs :2
If anyone had any clue, please give me advice, thank You.
Rgds,
Ep
Oh, here's below link of my last update on WM06 S75
Download _________________ SiemensXP | My Blog
maugliknm badatel
Založen: 06. 03. 2007 Příspěvky: 140 Telefon: EL 71,E71 645.34 SMM
delpierwin badatel
519.20 SMM
Zaslal: st únor 13, 2008 10:13 am Předmět: |
Wow thank you so much maugliknm, it's really helping, are those identifier valid on all sMenu version menu.cfg? Thanks
And on more thing could we change space between menu in vertical direction, i set Item_h but it won't change the space.
Those sample above, i mean space between New SMS and Chat etc. word, it's to wide for me. _________________ SiemensXP | My Blog
maugliknm badatel
siesea kolemjdoucí
delpierwin badatel
519.20 SMM
Zaslal: pá únor 15, 2008 1:37 am Předmět: |
Try this then
@maugliknm
Long way today, i was difficult to find higher version than 9.0 for NSG, all i had found just v9.4, and it was for ELKA
Could anyone had any invention for NSG?
Thanks _________________ SiemensXP | My Blog
alania1 kolemjdoucí
Založen: 21. 11. 2007 Příspěvky: 5 Bydliště: Russia,Vladikavkaz
2.50 SMM
maugliknm badatel
delpierwin badatel
519.20 SMM
Zaslal: ne únor 17, 2008 7:21 am Předmět: |
Thanks a lot maugliknm, my friend _________________ SiemensXP | My Blog
siesea kolemjdoucí
Zaslal: ne únor 17, 2008 1:39 pm Předmět: |
delpierwin
thank you for your reply ,but i can't open that link ,either
can you send the file via email?
my email is: sie_sea@163.com
thank you |
delpierwin badatel
519.20 SMM
Zaslal: st únor 20, 2008 2:42 am Předmět: |
Sorry for waiting so long, file allready sent to Your Mailbox _________________ SiemensXP | My Blog
siesea kolemjdoucí
Zaslal: st únor 20, 2008 3:03 am Předmět: |
thank you very much,delpierwin
your turning is great |
delpierwin badatel
519.20 SMM
Zaslal: st únor 20, 2008 4:15 am Předmět: |
You're wellcome siesea , and thank you. _________________ SiemensXP | My Blog
